Question about Sharp AL-1641CS Laser Digital Copier
L and 3 error
Tried the reset procedure and no go.. How do you fix the problem with the optic drive and sensors?? Help
  • Sharp Master
  • 1,113 Answers
Check lock on roof where paper exits is not locked, round turny thing is its tecnical name then off and on with power
Posted on Dec 07, 2007
I have a toshiba satellite pro c850 -1he and I reset my computer and it crashed and now it gives me a error message saying " no bootable device -- please restart system" Ive tried that it dont work I
It is not recognizing your hard drive. Put your Windows installation DVD in the optical drive and try restarting again. It MAY be able to help you but the data on your hard drive may be permanently damaged. You may have to reinstall Windows and all of your applications.
Feb 16, 2015 | Toshiba Computers & Internet
Sportsart 1050l gives error 1
ERR1 Definition: The display board CPU didn't receive the optic sensor signal. • Explanation: After processing by the drive board, the optic sensor signal travels the 16-pin cable to the display board CPU, which determines motor speed. Components involved include the optic sensor, optic sensor wheel, 16-pin cable, drive board, display board, and connections. http://www.sportsmith.net/images/product_support/sportsart/Repair%20Manuals/General%20Treadmill%20Svc%20Manual.pdf
Aug 01, 2014 | Sportsart Exercise & Fitness
What is E-1 error in Sportsart Tradmills
Jun 23, 2014 | Sportsart Treadmill Doctor Walking Belt...
Sportsart 1080 treadmill error 01
Mar 17, 2014 | Proform Power 1080
Universal password
There is no universal password for Apple laptops. If you have your installation disks, you can launch your laptop from the optical drive and reset the password. In more recent models without optical drives, the procedure differs. More specific information about your situation would be necessary to help you.
If you need further help, reach me via phone at https://www.6ya.com/expert/john_77bb351c0c06b354
Nov 21, 2013 | Apple Computers & Internet
How do i fix an e2 error and get a wiring diagram
Dear Sir:
I will try to help you, please be patience and carefully, use basics tools:screwdriver, hex,allen, Dvom.
Troubleshooting: ERR2 - Motor Movement
Since the motor moves when you press speed up, focus on the optic sensor, its wire connections, and the
optic sensor wheel. If all seems well at the sensor, inspect the motor.
Optic Sensor
??? Optic sensor wheel - Make sure that the optic sensor wheel rotates securely, without wobbling, in the
middle of the optic sensor. Realign and tighten if necessary. If optic sensor wheel teeth are missing or
bent, replace the optic sensor wheel.
??? Optic sensor wires - Make sure that wires are inserted securely to the optic sensor and to the drive board.
Check wire continuity.
??? Optic sensor - Turn on unit power. Turn the motor flywheel with your hand. The optic sensor
indicator (LED10, drive board) should light. . If it does not light, and all parts above are
good, replace the optic sensor.
Motor
??? Motor arcing - Does the motor show signs of wear - irregular arcing, carbon dust?
??? Motor brushes - Do brushes show signs of irregular wear - cracks, dents, lines? Replace the
motor brushes.
??? M+ M- Wires - Make sure wires are connected properly.
Other
??? Display main IC - To ensure proper signal processing, press down on the main IC on the display
board, marked U5. .
??? Ribbon cable - Ensure that the ribbon cable is attached at the drive and display boards. Check cable
continuity.
If you need additional help, please reach me.
sincerely. God bless you.
E.CUADR
MANAGUA, NICARAGUA
Oct 21, 2011 | Proform 730 Folding Treadmill Model...
E2 error on pro form 730 key in belt and motor run about 5 sec and shuts down sensor light blinks but not a steady light
Dear Sir:
I will try to help you, use the patience and carefully: need screwdriver, hex, allen+Dvom(DigitalVoltemeter)
Optic Sensor
Motor
motor brushes.
Other
board, marked U5. .
continuity.
Troubleshooting: ERR 2 - No Motor Movement
Turn unit power off and then on to clear the ERR2 message from the display. To test whether the drive
board is putting out power to the motor, insert multimeter probes on the M+ M- connectors and press
the speed up key. . (Note: To avoid ERR2.)
Power to Motor
If the drive board puts out power to the motor, but the motor does not operate, either the motor wires or
motor is malfunctioning. Test wires for continuity. Inspect connections. Perform an ohm test on the
motor . Inspect motor brushes.
No Power to Motor
If there is no power to the motor, either the signal is not arriving at the drive board, the transformer
or inductor is bad, or the drive board is bad. Inspect the following:
??? Display - Does the display beep when you press speed up? If so, the display has sent its signal.
If not, inspect overlay-to-display connections. And press down on the main program IC, marked U5.
??? Wires and their connections - inspect data cable connections from the display to the drive board,
test data cable continuity, inspect M+ M- wires from the drive board to the motor.
??? Inductor (6310 only) - inspect inductor and its wires and their connections. .
??? Transformer - inspect the transformer and its wires and their connections.
??? Drive Board - inspect the drive board for burnt or cracked components. Inspect LEDs (See DRIVE.03
and DRIVE.04). Press on the drive board IC chips to ensure good connection. If the power indicator on
the drive board, LED8, lights, but there is no power to the motor, and other components are good,
replace the drive board.
wITH THIS YOU FIX IT. If you need further assistance, please reach me
SINCERELY. GOD BLESS YOU.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 20, 2011 | Exercise & Fitness
Giving error msvcrt.dll
To fix msvcrt.dll errors such as a lost _resetstkoflw routine, the Msvcrt.dll file has to be reset to its default state. A Windows XP installation disc is required to do this remedy. Follow these simple step by step procedures:
1. Put the Windows XP installation disc in the optical drive and boot from this drive.
2. Press R to go to the Recovery Console menu upon seeing the Welcome to set up display.
3. Choose the number that corresponds to the OS that needs to be repaired, should your pc have a multi-OS system.
4. Log in as an administrator.
5. When on Recovery Console already, input these commands and hit the enter key after typing them to run the commands:
cd system 32
ren mscvrt.dll mscvrt.bak
F: (where F is the optical drive, and C is the root drive where windows resides)
cd\i386
expand msvcrt.dl_ C:\windows\system32
exit
Sep 12, 2011 | Rockstar Games Grand Theft Auto III & Vice...
KODAK ESP 7 AIO Carriage stuck on left handside Paper jam message but no paper or bits stuck inside Have tried reset procedures of internet tried when -feed rollers turn but carriage cradle appears...
optical encoder is known as the timing Strip film that guide the carriage of the cartridge, you have to clean softly with a cotton and alcohol.
Oct 30, 2010 | Kodak 5500 ALL-IN-ONE PRINTER
System resetup procedures for canon iR2016
hi you error code is referring to the fixing film in your fuser unit is not aligned, in other words its moved to one side and the sensor is detecting it as not aligned. order a new fixing film and replace it or order new fixing unit.
canon tech
Jun 03, 2008 | Canon PC-940 Black and White Copier
Sharp AL-1641CS Laser Digital Copier Logo
26 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
