Question about NorStar M7310 Corded Phone
M7310 I have a m7310When i pick up a handset on any phone , it now uses line 2.It has always used line 1 and we have not changed or added anything in over a year.I can manually push line 1 and it works fine and when a call comes in it will go to line 1 unless busy and roll to line 2Please help.Mike
    Problem Solver:
  • 17 Answers
Go and edit ur phone settings..its not ur fault it is by the operator..just contact ur gsm operator at call cantre and edit all the settings as he guides u........
Posted on Dec 04, 2007
Change the line selected when lifting the handset (from #4 to #2)
that is not a user option it must be programed by a tech. it is a feature called idel line prefrence the other way iy can be accomplished is by using a hunt group but you will still need it to programed by a tech, you can contact me by email @
May 05, 2010 | Comdial Impact 8124S Corded Phone
Norstar m7310 needs rls button pushed after every call
I've seen this many times; Check the Handset cable. It is probably plugged into the Headset connection on the phone.
Sep 23, 2009 | NorStar Meridian M7310 Phone
Meridian M7310 intercom key not working on anyphone
Do Feature **CONFIG, go to CONFIGURATION, select the second option, should say Line something, keep scrolling and it will say I/C: #,. press change, you can have a max of 2 Intercom keys, if you need other info, go to and search for "thenortelguy"
Aug 28, 2009 | NorStar Meridian M7310 Phone
I want to be able to just pick up the handset and have it
Depending on the software level, there is a possible chance for this to work...
first question though... can you dial a 9 to get a line out?
If this is possible, that means that we can change the PRIME LINE for a line pool access rather than intercom.
-> Get into system programming
-> get into TERMINALS&SETS and type in your extension
-> enter LINE ACCESS and hit next till you find PRIME LINE it should say I/C (this is intercom)
-> press change till you see PoolA
-> hit next and RLS to end programming.
Now everytime that you pick up your handset, it will pick the first available line out!
Feb 22, 2009 | NorStar Meridian M7310 Phone
No dial tone on receiver only on voice
make shure handset cord is Not pluged in to the Headset jack on the bottom, needs to be in the handset jack (look at the icons)
Jan 29, 2009 | NorStar Meridian M7310 Phone
Nortel M7310 Phone moved to another jack, now no incoming calls
you need to go to your previous location and get the jack number, than go to the new location and get the jack number. now go to the phone system closet and look for these cable numbers on the 66 blocks. Swap the cross connect of the jacks and wallah your phone will be your s again!
Jan 20, 2009 | NorStar M7310 Corded Phone
Line programming
That is a feature under system programming for your set. your admin person would need to make that change fir your extension.
Dec 01, 2008 | NorStar Meridian M7310 Phone
Answering call
Feature ** 266344 password 266344 (assuming the default passwords are set)
A. Configuration
2. Line Access
Show set (enter the telephone extension set number that needs to be changed) ex 34
Then press enter 4 times until you see the 'Prime Line'
Press the change button to set the desired line that will activate when the handset is picked up.
(It will probably display 'None' at present before change)
Press enter and release.
Aug 19, 2008 | NorStar M7310 Corded Phone
Sounds like you have two seperate line groups programmed in the system, Program 32 " Automatic Preference " controls the lines the phone will automatically be connected to when the telephone handset is taken off hook or the Spkr button is used.
Apr 24, 2008 | Toshiba DKT-2010 Corded Phone
NorStar M7310 Corded Phone Logo
156 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
