Question about Hitachi PJTX100 Multimedia Projector
No input detected on projector
I have a hitachi pjtx-100 ceiling mounted projector that worked great when connected the following way: DVD Player>Component video cables>reciever>component video cables>projector.
I recently remodeled my house, and opted to run an hdmi cable instead of component video cables. Then I discovered that my projector does not have an HDMI input! -But it does have a DVI input. I thought the problem would be solved by buying a HDMI-DVI adapter. -No luck. The current configuration is: DVD>Component video cable>reciever>hdmi cable>hdmito DVI adapter>projector.
Maybe related- I bought a new Sony Reciever (STR DG 510) to take advantage of the HDMI output. Whenever I select "DVD" the message "unlock" appears on the display. There is now reference whatsoever to this message in any manual, so I can't get rid of it. Is the unit "locked, thus inhibiting the signal?
I'm pretty technically adept, and have gone through all of the motions of changing the input signal on the projector.
Also, the dvd player is about 5-6 years old...might the signal not make the transition from component video cable to hdmi? Thanks for your help!
Dave
  • 1 more comment
  • Anonymous Mar 17, 2014
    We had some electrical problems in the house which stopped our HDMI from functioning...as of now we can only use S Video...how can i replace the HDMI input for my Ben Q MS616ST?
  • Anonymous Mar 26, 2014
    I want to connect my laptop to a benj projector - what cables do I need to use
  • Anonymous Mar 28, 2014
    I WANT TO PLAY MY MEDIA PLAYER ON MY PROJECTOR BUT THERE IS NO HDMI INPUT I HAVE TRIED HDMI Male to VGA HD Video Cable Converter Adapter 1080P AND HDMI Male to 5RCA 5-RCA Audio Video AV Component Cable BUT THEY DO NOT REGISTER. WHAT AM I DOING WRONG
  • 752 Answers
It sounds like the A/V reciever does not upconvert the component signal to HDMI. Not many do. The Marantz recievers will (SR6001, SR8001, etc..). Also bear in mind that HDMI cables are finicky and may require amplification over a few meters long.
Posted on Dec 04, 2007
PJ-TX300 suddenly not detecting HDMI input
I think that its a port issue, if all the other ports are working but hdmi is not then one of the pin on the circuit board may have come loose. I have the same issue. Could try to solder it back on or use a glue gun. let me know if this helps?
Sep 21, 2014 | Hitachi PJ-TX300 LCD Projector
Digital Coaxial not working on DVD player
There might be several problems. As the projector has component only connections and the DVD player none, then if the Receiver has component out, you can hook it up to that. If the receiver has HDMI inputs then you can connect the DVD player via the HDMI socket to it. The Coax sockets on the DVD player will be for sound. Number one should be connected to Digital coax 1 and assigned for it.
It's possible that the sound on the DVD player is switched off on the coax or has the wrong format selected. You will need to see the player's menu for this, so if you can't see the screen using the projector, connect a TV instead.
However if the receiver has no component out and no HDMI sockets you will have real problems connecting the DVD and using the projector with it. Though you should be able to hear the sound via the Denon.
May 28, 2017 | Denon Audio Players & Recorders
I see no red and green colors on screen projected by pjtx 100, the rest of the colors are visible.
If you are using a component video cable (Red, Green, Blue) you may simply be missing the Red cable. It may not be fully plugged in.
You can verify that this is the case by: 1. Unplugging all video cables 2. Plug in the green cable, you should see a black and white image. 3. Plug in the blue cable, you should see some colours coming through. 4. Plug in the red cable, you should see all colours properly.
If not, unplug the blue and red cables and plug the blue cable into the red port. The colours will look incorrect, skin tones will be blue. If the colour comes through the problem is the cable. If the colour does not come through, the problem may be the projector.
Feb 28, 2011 | Hitachi PJTX100 Multimedia Projector
There is blue shadows in the picture, my hitachi cp-rs55 just got a new lamp, but the problem is still there???? How do i solve this problem??
Hi
The problem could be caused by the connection or configuration of your video equipment. Check the following:
  • Make sure your component-to-VGA video cable is properly connected.
  • Select Component Video as the Computer Input setting in the Signal menu.
  • Make sure the connected video equipment is set up to output video to component video.
Hope this helps
Apr 01, 2010 | Hitachi Performa CP-RS55 Multimedia...
What size are the mounting screws?
The brass mounting holes on the bottom of Hitachi data projectors require a 4mm bolt.
Typicall 4mm x 10 is the shortest bolt I will use if when installing a projector on a ceiling mount, and 4mm x 20 will be the longest. I also recommend picking up 3 washers and spacers of varying sizes if you want to insure the projector is mounted level without warping whatever it is you are attaching it to.
BMS makes great locking mounts that come with all the mounting hardware you'd need to attach a projector to it.
Jan 03, 2010 | Hitachi CP-S240 Multimedia Projector
Denon AVR 1610 hdmi to component video conversion missing?
hello i believe your problem is that you are trying to downconvert from hdmi to component connections and Denon receivers will not do that.
I have a 4310 and I know it will UPconvert from an analog signal to HDMI but won't do it the other way around.
you may have to use component inputs for all your equipment. You will also have to go into the receivers menu and designate which signal is being used for each component as it won't auto select between analog and digital signals when it comes to video.
hope that helps
Dec 30, 2009 | Denon AVR-1603 Receiver
MY VIDEO PROJECTOR SONY VPL -HS10, CONNECTED TO COMPONENT VIDEO OUTPUTS IS DIPLAYING DATA ON THE SCREEN UPSIDE DOWN. HOW DO I CHANGE THIS PLEASE
There should be a menu option for orientation. The selection may be for ceiling vs standard. You have the unit set for ceiling mount.
Dan
Sep 12, 2009 | Sony VPH-G70Q Video Projector (VPH G70Q,...
Hitachi XGA cp-x275
Yes, this unit is made for either or solution. If you look at the under side, you will see three screw holes, these are for your mount kit which you can get form http://www.mountsandmore.com/Projector-Ceiling-Mounts-C13810.html?refid=G6435.%22projector+ceiling+mount%22&gclid=CIyfl7G_2pgCFQEoGgodXmajdw
There are other sites as well.
Hope this is not too late.
Oct 02, 2008 | Hitachi CP-X275 Multimedia Projector
DVI connection
on your projector first, set it on auto search, power on the DVD player. Check the cable or replace the cable.
Nov 18, 2007 | InFocus ScreenPlay 4805 Multimedia...
Hitachi PJTX100 Multimedia Projector Logo
1,827 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
Steve Allison
Steve Allison
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
