Question about LaCie d2 Extreme FW800 (300878) 200 GB Hard Drive
Lacie harddrive problems
I connect the Lacie drive to my mac and it turns on fine and makes noise like if it's booting up and everything but it does not appear on the desktop and I can't access it. I tried the disk utility but it does not appear there either and I also tried different cables. Is there anything else that I can try? I have a lot of Final Cut Pro files and videos that I really need to recover. Thank You.
  • Anonymous Jan 25, 2008
    same ´problem
4 Suggested Answers
  • 3587 Answers
SOURCE: Lacie 1TB external hd won't mount!
check wires connecting them together first, ok?
then, turn off the LaCie, connect to your MacPro, and then turn on the drive..
that should show as a mounted drive.
need printer drivers update?
Posted on Mar 09, 2008
  • 55 Answers
SOURCE: My lacie drive will shows up on the desktop and you
I'm going to have to guess a bit based on limited information I have on this, but did you create a Final Cut Pro sequence on the Lacie on one computer and then are trying to open the sequence on another computer?
That won't work if that's the case ...
The FCP sequence refers to files, but doesn't include them in the sequence file ... All of the referred to files will have to go along on the Lacie and be transferred to the same folders on the second computer so the FCP sequence will find them.
You can try consolidating the project in FCP to make the transfer easier ... after consolidating it, the files needed for the project should be trimmed and all located in one place (scratch disc selected in preferences)
Once again, the sequence file does not contain your movie clips, audio or other assets .... they are located in different places on the computer where you create the sequence, and if you move to another computer everything has to move into exactly the same place ...
Hope this helps
For my latest DVD on PA systems for Small Groups see my website at
Posted on Mar 07, 2010
SOURCE: DSR-45 connected to Mac pro 8Core with 3 FW-800
SDR-40p dont finded to WinXP SP3, and requiring driver.
Sorry, i am russian.
Posted on Mar 16, 2010
Lacie External Drive won't turn on (blue Light doesn't go on)
Inside the LaCie D2 250GB (300770) external harddrive's case, is a 250GB IDE (PATA) harddrive that is 3.5 inches across in width.
A desktop computer sized harddrive. (May be a Western Digital WD25000JB)
The harddrive plugs into a small circuit board, (Bridge board), and the circuit board has a USB port on it.
Using this Western Digital Passport for an example,
Scroll down to the second photo, and left-click on it. The case of the external harddrive is shown open.
Inside is a 2.5 inch laptop sized harddrive.
An aluminum tape strip covers the small circuit board, attached at the back of the harddrive.
The second photo down on this page, shows you the small interface circuit board, that the harddrive plugs into, with the aluminum tape removed.
(Another design has wires coming from the small circuit board, to an interface the harddrive plugs into )
It is this small circuit board that goes bad in a LaCie. QUITE common.
1) Obtain a 3.5 inch IDE external enclosure
2) Remove the 3.5 IDE harddrive from the LaCie's case.
3) Install the harddrive out of the LaCie into the external 3.5 IDE enclosure.
An example of a 3.5 IDE (PATA) external enclosure,
For additional questions please post in a Comment.
Jul 19, 2012 | LaCie (300770) 250 GB Hard Drive
I connect my Lacie d2 quadra to my mac with firewire 800 and it works fine, but when I connect the same hard disk with esata, it appears on the desktop screen, but the blue light won´t stop...
I have had simular problems with one of these. It can be due to the drive not starting up or shutting down properly or a powers issue.
I woud recomend dissconecting all leads from the back of the hard drive.
Now plug in just the mains power. Now turn the drive on and let it boot up until the light stops flashing. Let it stay constant for a while, now press the power/led button to let it shut down properly on it's own.
Now turn of your mac. with the hard drive still OFF, connect the fire wire to you're mac and HD. Now power up the Mac. If the HD does not power up on it's own, turn it on now.
Hopefully all should be ok now.
If not, try to test it on a PC. It may sound strange, but it can make a difference. Now do all the above again.
Any Luck?
Ok another thing is to try a psu. Hopefully you know someone with a drive you can ask to test their power supply with.. Try all of the above things again? Any joy? if it all workd ok with their power supply and not your's, your mains transformer is bust. It's caused by a capcitor that blows (quite common). If your drive is recent, you may be able to harrass Lacie for a new one, if not I managed to get a Lacie psu from ebay for around £25.00+p&p on ebay.
A final thing to check is what firewire version your mac is against the firwire version of the lacie. Sometimes this can give issues.
Hope this helps.
Jan 13, 2011 | Computers & Internet
We understand that your problem is: We understand that your problem is: Hello, I have Lacie porsche external hard drive. I also have a seagate firewire external drive which us working fine. Unfortunately...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: for a "no data - no charge" guarantee.
Dec 18, 2010 | LaCie F.A. Porsche (301177) Hard Drive
My lacie hard drive 200GB several years old, I turn on and just get a repeating click sound, as though something's turning but can't quite connect. is there anything I can do to get it working at least...
Last time I saw this problem the harddrive was accessible, but not within Windows. I had to resort to booting into MSDOS at a lower level. The harddrive failed and the portion of the drive that had the problem was visible, but inaccessible. I was able to recover everything but the most accessed portion of the drive which happened to be what I was needing. The client then was required to send the drive to Silicon Valley to which it was taken apart in a clean room and the data was extracted for a price of $3500.
Dec 03, 2010 | LaCie (300769) 200 GB Hard Drive
Strange noises, disk won't fully spin or start up...
Your AC adapter is "dying", and must be replaced.
Is it still under "warranty", i.e., you contact LaCie,
get an RMA (Return Materials Authorization) number,
they ship you a new adapter. If you ship them the old adapter,
within a week, they will _not_ charge your credit-card the $30.
Sep 19, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
I have a Lacie 320gb external harddrive which was connected to an eMac and is now connected to an Acer laptop. I've reformatted it as NTFS and it shows up in disk management as healthy but does not appear...
you need to give it a drive letter
A more reliable way to do this is via the computer management console
Start / Control Panel / Administrative Tools / Computer management / Disk Management.
Your drive should show up in here.
if it says Healthy and just above that gives the file system eg. NTFS or FAT32 etc it should be fine but may just need a drive letter.
If it does dot say any of those then right click on it and use the format option. Select how you want to format it (NTFS for XP is preffered)
and then tell it to do a FULL format. and also give it a drive letter !
It may take a while but I find it more reliable overall.
If it didn't have a drive letter then right click and use the Change Drive Letter and Paths option, then add a drive letter and use the one it offers.
I like to re-boot just to be sure windows sees it properly
Aug 28, 2009 | LaCie Hard Disk 320GB with Hi-Speed USB2.0...
Sometimes the hard drive will connect and sometimes it won't.
There have been problems plaguing the LaCie external harddrives, for quite some time now.
The issue directly relates to the interface, inside the external enclosure. I don't know if you are acquainted with harddrive designs, or the interface that they plug into. If you are, disregard the following.
This is an average example of an IDE harddrive,
Looking at this illustration, note where it points to -> IDE Connector. The illustration isn't very good, but those dots are metal pins.
The connection inside your external harddrive,
that connects to the harddrive itself, is called an Interface. This is a plug that has socket holes, to match those metal pins.
Now we go a little deeper. There are two types of harddrives. One is an IDE harddrive, the other type is a SATA harddrive. Your LaCie
will have a SATA harddrive inside.
Instead of the 40 pins that an IDE harddrive has, the interface for a SATA harddrive has 7.
(It has 15 pins for the power connection)
Now my solution:
Should you wish to save data that is on your LaCie external harddrive right now, I suggest you buy an external enclosure, (SATA), take out the hardrdive thats in your LaCie, and install it in the enclosure.
Since, the dimensions of the, LaCie design by Porsche 160GB external harddrive are:
Height -> 1.4 inches, (About 1-1/2 inches)
Width -> 4.4 inches, (About 4-1/2 inches)
Length -> 7.4 inches, (About 7-1/2 inches),
I'm willing to bet the harddrive inside is a desktop harddrive size. (3.5 inches across in width)
These are examples of 3.5 inch SATA external enclosures,|c:2778|&Sort=0&Recs=10
(A $25 or $35 unit will work just fine)
Jul 18, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Lacie 1TB External Drive flashing blue light, not being found
I know this arent a solution
Tho I have the same problem atm, this is just a networkstorage device, and this is a newly 1.
Feb 04, 2009 | LaCie d2 Extreme 250GB External with...
Does not mount, Fan not spinning. 500gb D2 quadra
take the drive out and put it in a external case and see if that helps. if not the drive is dead.
Dec 13, 2008 | LaCie d2 Extreme (300793U) 500 GB Hard...
My new Imac won't recognize my cannon zr65 camcorder help please.
Some FireWire cameras do not play nice with other FW devices. Try unplugging the LaCie drive and any other FireWire device, then connect the camera directly to the Mac. iMovie should detect it then.
Nov 21, 2008 | Apple iMac 24" Desktop
LaCie d2 Extreme FW800 (300878) 200 GB Hard Drive Logo
49 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
