Bosch Axxis WTA 4107 Electric Dryer
Problem for Bosch Axxis WTA 4107 Electric Dryer
Asko 7705 dryer shut down
By mk66 on Dec 04, 2007
It seems that if I put more then 8 or 10 articals of clothing in the dryer the breaker on the back of the dryer trips. I feel this is not a excesive amount considering it is all shorts and T-shirts. Is there a sensor that I might be able to replace or by pass.
Same Problem
May 19, 2009
-   Same as described above, if any "normal sized" load is put in the dryer it trips the reset on the back after like 7 or so minutes. -   Guest
Aug 03, 2008
-   I am having a problem with my Kenmore dryer, model 110.63102101 shutting off after about 20 minutes of drying time. It started about 3 weeks ago. I took the back off, cleaned it all out, cleaned the lint duct, whatever I could reach. It ran fine for a couple of weeks, but now the problem is back. From a cold start, it will run normal for about 20 minutes, then shut down. Restarting it after about a half hour, it will run for about 5 minutes. If I immediately restart it, it may run for less than a minute, or not start at all. If I come back after a while, it will restart, but run only for a short time. Something inside needs to cool down first.
This condition is in high heat, and low heat is not much better. I can run a normal cycle in air dry.
Any suggestions?-   ALE37
Jan 04, 2008
-   After 1 medium load at high heat setting, dryer shuts down requiring a reset with the button on back.  -   DaveWK
Dec 20, 2007
-   We are having the same problem. We clean the lint filter after each load, and wash it with soapy water after every few loads. We do not use fabric softener sheets. Water collects in the cubby that holds the condensor unit, and we have to mop that water up after every load, which involves unscrewing the front panel. Is there any hope for fixing this lemon, or do we need to buy a new dryer?-   eatmoresushi
Best Solution
posted on Mar 23, 2008
Helpful)
Askoman
Rank: Apprentice
Rating: 93%, 3 votes
Solution.
Take the plate of at the backsite.
All screws out,en than you can see,that your machine is ful of dust.
Make the machine totaly clean,and he wil drying again.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Bosch Axxis WTA 4107 Electric
Questions and Unsolved Problems for Bosch Axxis WTA 4107 Electric
Do you recommend Bosch Axxis WTA 4107 Electric Dryer?
Answer
Answer
Trying to replace belt on Performa Model PYE22000AYW. Spring on idler is attached to idler arm, but... (More)
Answer
I have a Braun AXXIS Dryer that I just got that is leaking water onto the floor. It does not have an... (More)
Answer
My dryer appears to be working fine but ther is no heat - Bosch are quoting £139 call out and... (More)
Answer
My machine has stopped working. If you select a programme, the 'Drying' LED (the bottom one) starts... (More)
Answer
can you please send me a wiring diagram for a WTA 2000 electric dryer via e-mail to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryers Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
