TV won't turn off
My TV will turn off when I use the remote, but it will turn right back on. The power button on the TV does not work. The only way to shut off the TV is to unplug it.
  • 3 more comments
  • Anonymous Jan 19, 2008
    same problem.  Philips 32pt81s1
  • Hero321 Jul 05, 2008
    JVC AV-27D305 27" TV
    TV won't turn off either using the remote control or the button on the TV. Only turn off if I unplug it.
  • chriscoleary Apr 12, 2009
    Toshiba tv/vcr/dvd combo won't turn on with remote or by manually pressing the on/off button...
  • Anonymous May 02, 2009
    My RCA Colortrak 2000 26" model F26101NG F01 has a similar problem. Worked fine, but occsionally turned back on when you used the on-off button to close. Remote worked fine to turn it off. Now it won't turn on at all with button nor remote--no click. Any suggestions?
    Tim R.
    My RCA Colortrak 2000 26" model F26101NG F01 has a similar problem. Worked fine, but occsionally turned back on when you used the on-off button close. Was fine with remote to turn it off. Now it won't turn on at all--no click. Any suggestions?
    Tim R.
    President:
  • 1,284 Answers
Or ironically the power switch on the TV could be stuck and causing a false on/off command. Don't let the simple things such as that be overlooked.
Posted on Dec 06, 2007
I have the same problem, I have a Vizio E3D320VX! The tv turns on, but won't cut off. I don't have the remote either
Posted on Oct 05, 2011
    Novelist:
    Champion:
  • 232 Answers
Nick, the relay driver circuit has a fault, you need to post make & model number so I can give you more info, BMW Rider
Posted on Dec 05, 2007
Hello I have model number F32650 with the same no power issue. Is there know problems on this unit? Thanks for any info
Chris Hammack
pie1@cristyspizza.com
Posted on May 14, 2008
2 Suggested Answers
Ajkill
  • 2035 Answers
SOURCE: TV auto shut off-power indicator light blinking-won't turn back on
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
If you are having some problems with your Sony Television, then this post is for you. Generally speaking, when there is trouble with your Sony Television set -- it indicates the issue in either the diagnostic mode, or even more commonly by flashing a series of LED blinks or flashes on the front of your television. Each set or frequency of the blinks indicates a very specific problem with the television itself. In some cases, you may be able to repair the television set yourself -- or in the worst case you may need to order parts, call a local repair shop to the have a repairman sent out, or even purchase a new television set.
First off, here are the list of codes and what they generally mean on my set (which applies to many recent model Sony Television sets. Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue. Here are the values of the various blinks.
* 0 times, Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty.
* 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted.
* 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode.
* 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
* 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
* 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
* 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
* 8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
* 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
If you would like to attempt a DIY, you will need a service manual to guide you. You can find one here:
http://servicemanuals.vstore.ca/
However, be aware that there are voltages inside your TV set that can kill, even if unplugged.
Posted on Jul 08, 2008
Need remote code for Vizio D32h-CO. No remote for TV. Have Dish remote
For my universal remote control's manual, all of the VIZIO codes are:
11758
13758
12757
Also, remember that you can have the remote scan for codes on its own. On the remote just hold the "TV" control button (should be at the top near the power button) and the power button turns on. Then hold the power button too, and it shuts back off; keep holding until it turns back on and then it will stay on. Then, point the remote at the TV (it should be on) and press the power button every three seconds. It will test a code every two or three seconds. When your TV finally shuts itself off in response, you've got the right code and the remote should work.
Jan 18, 2018 | Vizio Televison & Video
Need to program samsung tv universal remote. How do I do it?
For my universal remote control's manual, all of the Samsung codes are:
12051
10178
Jan 18, 2018 | Samsung Televison & Video
Power button only one that won't turn power on
Have the remote tested either with a tester that most shops have or in a dark room with a digital camera the display will faintly flash when remote pointed at it and buttons pressed.
Also if button does not work (power) unplug the set for a while to see if it will reset. If the tester shows same problem--no working for power or have to press ******* buttons 99% chance something got spilled onto remote and got inside
Oct 24, 2012 | RCA TruFlat 27F520T 27" TV
ELCHW402 won't turn on
An internal relay may have failed.
Dec 08, 2017 | Element ELCHW402 40 in. LCD HDTV
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
My Dish 5.0 IR remote won't program to my new TV, it's an Emerson, the model number on the back is- LC320EMXF. I've tried holding the TV button until all the top lights flashed and then...
lrsnihe
You were attempting to perform a power scan initially. The second procedure is manually attempting to address the remote to your TV. I will give you the procedures again so you can try one more time. Emerson TV is one brand we have a low percentage of success getting our remotes to work. If it still doesn't work, we could try replacing the remote.
TV code: 623, 667, 666, 233, 516, 537, 544, 642, 655, 699, 000, 999, 888, and 720.
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and hold the clear TV button for six seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press #. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote Power Scan: Basic Remote (Television Only)
  3. Press and release the red TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off once every second.
  5. After the television turns off, press and release the # button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Jun 12, 2011 | DISH Network IR Remote Control
I have a Mitsubishi WS-55909 projection TV. There was a power outage and when the power came back on, the TV won.t turn back on again. There is this light (Timer) that keeps on blinking on the front panel...
Unplug,replug the tv back like 24 hrs later.That the whole tv is resetting itself everythings.Tv now should be working again.If still have the same problems,than ur tv DM power supply board is have dying parts,must repair the tv DM power supply board to fix the tv.
Mar 21, 2011 | Mitsubishi Televison & Video
There is shadows on the insdide of the screen
Turn your TV on by pushing either the power button on the front of the TV or the power button on the remote control, which is located in the upper right corner of the remote.
Step 2
Press and hold the "up arrow" button on the remote control. The up arrow button is located in the middle of the remote, to the left of the "Input" button and below the "Picture" button.
Step 3
Press the power button on the TV while still holding down the up arrow button. The TV will turn off and then turn itself back on.
Step 4
Release the up arrow button. Once the TV turns itself back on, it will restore your TV to its factory settings.
Hope this helpout.......
Aug 03, 2010 | Televison & Video
How do i reboot my konka television?
Step 2
Step 3
Step 4
Release the up arrow button. Once the TV turns itself back on, it will restore your TV its factory settings.
Aug 03, 2010 | Konka KDL32AT23U 32 in. LCD Television
Need remote control code for dish network along with how to instructions. I can't locate my manual for my Zenith
Try this...1) turn on your tv set manually.2) on you dish remote..press and hold the "TV" mode button next to the "SAT" button.when all of the other mode buttons light up, let the "TV" button go...it should be flashing.3) Press the blank power button(The top red button in the top center of the remote).4) press the UP or DOWN button at the rate of about 1 per second until the tv turns off.4) When the tv turns off...press the # key on the bottom right of the remote...this stores the code and you should be ready to go...please try this first..It should work.If the scan doesn't work...The only code for Orion is "694".I hope this was helpful....
Jun 15, 2010 | Zenith C32V37 32" TV
Televison & Video Logo
2,528 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
