Question about GE Refrigerators
My refrigerator worked fine until I took everything out of it a couple of days ago, cleaned it out and put everything back. By the next morning, my milk had spoiled, and even on the highest setting, nothing is cold enough and the freezer is defrosting
  • GE Master
  • 4,655 Answers
I will need your model number to help you solve this problem. Thanks, Sea Breeze
Posted on Aug 25, 2009
  • John Tripp
    John Tripp Aug 25, 2009
    You could have turned it of just cleaning it.
  • John Tripp
    You could have turned it off just cleaning it.
SOURCE:
I have a GE GSS25XSRSS Side By Side refrigerator
no defrost taking place
a clock
b heater element/hot gas valve
defrost terminator or safety fuse
Mar 17, 2010 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
Headlamps on when cars off and kills the battery
Likely either the delay module or the relay has gone bad and is sticking on. Till you find it and get it replaced you can pull the headlight fuse (in underhood fuse box) to prevent the battery form going dead.
Aug 09, 2009 | 1998 Chevrolet Malibu
My fridge won't cool down or freeze
Your condenser is likely dirty clean it. the compressor could be tripped out on over load (to hot) unplug the fridge a couple hours should do it . plug it back in make sure the thermostat is on and set correctly if that does not work you will need service. Tom
Jun 17, 2009 | LG LFD25860
Nokia 6500: Dodgy screen?
simply check the connections of the lcd to the board... or just tighten the screws... i had repaired a phone of that problem and this was my solutions.
May 31, 2009 | Nokia 6500 Slide Cellular Phone
Kenmore side by side model 596.55662500
have you tried pouring bleach water through the drains in the fridge?
Nov 08, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Bottom mount freezer not getting cold enough
You have a failed component or components in your automatic defrost system. This is why you have excessive frost inside the freezer along the back wall. The timer could be stuck in run mode. The defrost thermostat (bi-metal) could be defective or the defrost heater could be open or shorted.
Sep 18, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
Brad Goodale
Matt Sicignano
Level 1 Expert
JP Meneide
JP Meneide
