Question about Dell 1600n All-In-One Laser Printer
Dell 1600n Will only print with sheet feeder open
I've got a Dell1600n multi-function Laser printer.
If I place a piece of paper on the glass of the copier & close the lid (sheet feeder) and press the 'copy' button, the printer reports 'paper jam'. If I leave the printer lid open, then the 'copy' works fine. The printer will also print from computers on my network fine.
Appears that the printer thinks that there is a paper jam in the sheet-feeder lid. I've taken a quick look but its not easy to dismantle the sheet feed.
Any ideas gratefully accepted.
    Scholar:
  • 105 Answers
Rollers may be worn out and not properly grabbing paper or a gear may be broken. You should be able to inspect by lifting cover to feeder and watching as paper is pulled through.
Posted on Mar 27, 2008
Dell1600n will not turn on
Well first you have to check the power supply, seems to be expensive to repair, you need to remove the side covers and rear to see AC board
Apr 29, 2012 | Dell 1600n All-In-One Laser Printer
I have a dell 1600n printer. Though it prints but the copier is not functioning. The copier light does not come up. It brings a command, "Unlock scanner, then press cancel"
1) Remove the label completely from the scanner module by gently pulling it. The scan unlock switch automatically moves FORWARD to the unlock position.
2) NOTE: When you are moving the multi-function printer or do not intend to use it for a long period of time, move the switch BACKWARD to the lock position. To scan or copy a document, the switch must be unlocked.
Please see page 4 of the owners manual for more details. Here's a link in case you've lost yours:
http://support.dell.com/support/edocs/systems/1600n/en/OM/OM_EN_V01.pdf
I hope this response helps you out.
I wish you the very best of luck!
I strive for '4 Thumbs Up'! If I've assisted you, I'd greatly appreciate you taking the time to provide me with a favorable rating. Thanks so much!
Jun 22, 2011 | Dell 1600n All-In-One Laser Printer
My dell Laser Multi-Function Printer 1815dn has a line going straight down on any paper printed through the feeder
If it is from the ADF (Automatic Document Feeder ), it probably is a speck on the scanner glass. Lift up the top scanner cover and clean the glass esp. the narrow glass on the left side. Also, lift the small ADF cover and clean the rollers with a lint free cloth dampened with a mixture of alcohol and water.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 16, 2011 | Dell 1815dn All-In-One Laser Printer
No matter what i do the paper keeps getting jammed before it comes out... It looks like it's getting hang up on something by the front rollers... This is really making me very mad this morning....
I understand your frustration. Try this solution.
* Push down the purple paper lever located on the right side of the multi-purpose sheet feeder and pull the jammed paper upward and out of the feeder.
* Open the scanner cover by pulling the lever located below the control panel, toward you and lifting the cover. Make sure the cover is completely open. Check to see if any paper is left in the paper path.
Close the scanner cover.
Remove the paper in the multi-purpose sheet feeder. Adjust the guides in the sheet feeder to the position for the paper size you are using. Fan the paper well, push down the paper lever. Load the paper with the lever down. Make sure the print side is toward the fax machine and the paper level is stacked below the paper mark. The feeder can hold up to 200 sheets of paper (20lb paper) or up to 10 envelopes.
* Turn the power back on.
I hope this helps you.
Aug 03, 2010 | Brother DCP 1000 All-In-One Laser Printer
Dell1600n showing a document jam, have tried everything eg switching it off but cant find a solution. it prints fine and copies fine as well just isnt taking anything from the ADF. So I cant send a fax...
check the gears in the adf maybe you have one that is misaligned ,run a piece of paper following the paper path check the flag sensor make sure none of them is jammed close or misaligned.
Good luck
Jul 09, 2009 | Dell 5310n Laser Printer
My printer says I need paper. It has paper. Will not print or copy
Try to update the Firmware, or check the sensor of the feeder could be out of place and doesenot recognize the paper.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Jun 17, 2009 | Dell 1600n All-In-One Laser Printer
Scanner Sheet Feeder Malfunction
Change the top pick up roller. Can be ordered through the Dell parts dept. takes about 30 seconds to change.
May 23, 2008 | Dell 1600n All-In-One Laser Printer
DELL 1600N
If it makes verticle lines only when using the document feeder it is most likely a dirty glass strip over the scanner light bar. If it makes verticle lines in all modes (printing, flat bed scanning/copying, receiving faxes) it could be the fuser or a dirty glass over the laser where ever the laser images to a drum roller (usually a larger green roller). It is possible that this green drum roller is inside the toner - if so - replacing the toner cartridge could fix it. Maybe you could try an old used toner to see of the problem changes - if so - it is very likely that a new toner would fix your print quality issue.
Jan 09, 2008 | Dell 1600n All-In-One Laser Printer
Dell 1600n ADF Problem
You have either a piece of dust or a scratch on the scanning glass. This will show up as a line because the paper is pulled across the point.
Nov 12, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n has been ghosting lately
The 1600n AIO (all-in-one) is a laser printer. Laser printer use a statically charged "drum" to place toner on the paper. Your ghosting problem may be from the drum itself becoming too charged or simply dirty and not the cartridge. Servicing laser printers is tricky business because they use a lot of wattage/voltage to create the static charge and also "bake" the image onto the paper. A very quick fix would be to de-ionize the drum and clean it thoroughly.
First, make sure you have the unit completely unplugged for, at least, ten to fifteen minutes before proceeding to ensure that all static charge has had a chance to dissopate.
Second, remove the toner cartridge and place it on some newspaper or paper towels. Inspect it for any residual toner and/or damage that may be causing the ghosting (look for cracks/grooves/lines in the cartridge that shouldn't be there).
Third, take a used dryer sheet (or one that's had most of the chemical fabric softener rinsed off and then completely dried) and wipe the entire drum to completely remove any static charge. Then, using denatured alcohol and static-free, lint-free wipes clean the entire drum to remove any remaining detritus. Allow to dry thoroughly before proceeding.
Last, wipe the drum down, one final time, with a clean dryer sheet or lint-free cloth. Reassemble the unit and replace the toner cartridge.
Run a few clean sheets (blank prints or copies) to further remove any particles knocked loose and check for any more "ghosting."
Final printing will be necessary to check for inconsistencies or success.
Nov 08, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
201 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
