Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Camera not available
Whenever i connect the camera to the computer, a dialogue box appears n it reads:
"the camera is not available."
plsssssssssssss help...tis very urgent for me...
  • 3 Answers
I had a simliar problem with my sisters camera on her computer, although sometimes it would appear, then disappear shortly after.
i checked drivers and re-installed and all the normal stuff most do, but the actual problem was that the USB port it was plugged into was the problem... since i got them a new USB expansion slot which was USB 2....but what i can only come up with, is that since the USB ports on the motherboard are only USB 1...the expansion slot i put in was running too quick for the computer to receive the data, and it just wouldn't recognise the camera.
i don't know if that's true or not, but when i plugged the camera into the USB port on the main computer board, everything worked fine....
but i could be steering you in the wrong direction if this seems like a load of bull.
Posted on Dec 18, 2007
Cannot import pictures from camera to computer
If your computer is having poor earthing the currant leakage spoils the IC inside the USB port of camera. try in another laptop and confirm the same.
May be we can supply the manuals for servicing and spares
Sep 29, 2013 | Sony Cyber-Shot DSC-H1 Digital Camera
No dialogue box
Consider NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Apr 22, 2012 | Canon PowerShot A1100 IS Digital Camera
I have tried to upload pictures on my computer and it won`t open at all...no dialogue box or anything..
Consider NOT connecting the camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Nov 09, 2010 | Canon PowerShot A460 Digital Camera
Pics from nicon 2200 will not download to pc. used to work fine reloaded software no luck just makes a the usual noise when camera is pluged it but no dialogue box or transfer window?
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Nov 05, 2010 | Nikon Coolpix 2200 Digital Camera
V505 Dell Printer Connected by USB
Try to check the USB in the device manager if did not disable. To goto device manager right click the My Computer on the screen and click properties. Dialogue box appears click on the Hardware and click Device Manager. Another dialogue box appear then just see at the bottom of the dialogue box if the Universal Serial Bus Controllers are did not have question mark (?) with yellow color. If don't have mark like that try to change your USB cable then insert it again to your printer. But if they have a mark like that you need to right click the Universal Serial Bus Controllers and click Update driver.
May 28, 2010 | Dell V505 All-In-One Printer
Can't connect to PC
(for windows only)
1- connect ur device in the computer.
2- go to my computer.
3- in the left task pane click system information.
4- the system properties dialogue box will appear.
5- click the hardware tab and then the device manager.
6- the device manger dialogue box will appear click on the portable devices and click the name of your device.... the device dialogue box will appear.... you will see the device usage....
7-enable it... and then click ok....
thats all....
Jun 07, 2009 | Goodmans GPDR40 Digital Media Player
Vista supported drivers for GE camera
EasyCam Installation Instructions For Microsoft® Vista 1. If your computer is connected to the internet, you will have to disconnect from internet temporarily until the installation is complete. 2. Insert the CD that came with your EasyCam a. Do not install the driver b. Close the ?Auto Run? window 3. Remove the sticker from the end of the USB plug on the camera and plug the camera into an available USB plug. 4. ?Found New Hardware window will appear. 5. Select ?Locate and install drivers software (Recommended)? 6. A Permission Dialogue box may or may not appear, depending on the version and security that is set up. a. If the dialogue box appears, click ?Next? b. If the dialogue box does not appear, perform step 7 7. Window?s dialogue box will appear, ?Insert the disc that came with your USB Camera?, click ?Next? 8. Window?s dialogue box will appear, ?The software for this device has been successful installed? click on ?Close? 9. A ?Power Frequency? dialogue box will appear, click ?NO? 10. Click on the start button 11. Click on ?Computer? 12. Open the ?Local Disc (C:)? 13. Open Program Files 14. Open VGA USB Camera 15. Double click on AMCAP 16. AMCAP will open into a screen displaying what the camera is focused on. If this does not occur, follow the steps below. a. Click on ?Capture? b. Click on ?Start Capture? c. If you still do not receive a picture, follow the steps below. i. Click on ?Device? ii. Make sure ?CIF USB Camera (2110A) is checked iii. Check on ?Options? iv. Make sure ?Preview? is checked v. You should now be able to see what the camera is focused on.
Jul 04, 2007 | GE EasyCam Plus Webcam
I'm not a blonde- but the damn GE Easycam is making me crazy.
Marueen, GE computer accessories are now sold and supported by Jasco. Their download page has drivers for your webcam; unfortunately they don?t have any Vista certified drivers. Unfortunately lots of hardware manufacturers are not creating new Vista capable drivers for older equipment and I suspect Jasco will follow the trend as well. You can try downloading the latest XP driver from their site and seeing how it works but in the long run you may just be better off getting a more mainstream product with Vista drivers. Jasco download page: http://www.jascoproducts.com/cgi-local/SoftCart.exe/online-store/scstore/pro/computer_software_cams.html?L+scstore+ndrt4702ffcebece Let us know if you have any other questions and please don?t forget to rate this post.
Apr 03, 2007 | GE EasyCam Webcam
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
35 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
