Question about Infinity Reference 1211a Car Audio Amplifier
Amp prob wire that come from the speekers came loose from the amp , a + and - wire, and now the amp and sub wont come on
    Problem Solver:
  • 10 Answers
The speaker wire will not shut off the amp. Make sure that your power wire and ground are all connected properly. Check for any break in connections with these wires. Also check to see if your remote wire is connect properly and that there is no break in the wire. If there is a break or disconnection in any of these 3 wires, the amp will not come on. Also, check the amp fuse to see if the fuse has flown. Also check the fuse that is connected to your 12V source. If the fuse is blown, there will be not power on the amp. Check all your connections and fuse and you should find your problem
Posted on Dec 04, 2007
I am wanting to put my subs in the bed of my truck, how can I do this without rain or any other type of weather messing them up ?
Hello. Putting more speekers are a hassle. You will need to put them inside the cabin. You will need to get truck speeker boxes and they have to be the right size for the subs. You will also need to get the right kind of amp for them and the right kind of wires you will need. Good Luck.
Jun 01, 2014 | Cars & Trucks
I install a sub amp but I put the remote where the power goes and now the radio wont turn on
you prob just blew the fuse check the fuse box on the car the remote wire and power are the same thing power on the amp gives it power the remote wire tells the amp to turn on and off
May 19, 2012 | Car Audio & Video
My amp green light is on and fan but no sound
make sure you have good connection to all your wires something coulda came loose, but the popping sound could be that two wires were touching and could result in blowing a fuse
Mar 04, 2010 | Car Audio & Video
1000 watt amp problem. Speaker + Wire
hey wats up, let me see if i cud help u out here...i will give it a try and use bigger wire, the prob. cud b the wires cnt take pwr thts running through them, but tht cud only b the reason if ur wires are small...other thn tht u cud check 2 see if all ur fuses are correct & thy aint letting 2 much pwr through tht cud the prob as well...let me kno how tht gose & if those dnt wrk there might b sum thing else we cud *** up wit.
Jan 28, 2010 | Car Audio & Video
Speekers no sound
Sounds to me like the amp needs power. Is it usb powered? or have a wall plug?
Oct 28, 2009 | Boston Acoustics BA735 Computer Speakers
Subs dont work
To test speakers.A. Unplug speaker wires.
B. connect a 9volt battery to each speaker,touching one wire to the negative and the other to the positive breifly. The speaker should extend outward or inward, simulating the pumping of the cone. Depending on the polarity of the DC voltage hooked to the battery.
That's why it is important to wire the speakers correctly. Pos to Pos Neg to Neg.
You should know if the speakers or wired in series or parallele.
Google speaker wiring. Very informative.
Aug 12, 2009 | Harman Kardon HK695 Computer Speakers
Kicker 750.1 Amp wont play music
it is probably the rca inputs on the amp may have fried. was your cd decked turned up loudly before the power went out? did any wires accidently touch each other? If had worked fine and then suddenly stopped, than either a wire came loose or the inputs fried. try using different cables and I also suggest disconnecting power for 24 hours and then reconnect. If the green light is on then it is getting power and the problem is in the rca cables or the inputs
Jun 03, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Infinity Reference 1211a Car Audio Amplifier Logo
81 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Richard Lukszys
Richard Lukszys
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
