Question about Intel BLKD915GAVL (BLKD915GAVLX10U) Motherboard
Motherboard should on .but later after 10 hours should not ON . then reset bias then board on
    Sergeant:
    Champion:
  • 270 Answers
Relpace bois battery with a new one
Posted on Dec 04, 2007
Bios password removed
hi to remove the password off the bias, u need to take the bias battery out of the motherboard or change the bias jumpers depending on the motherboard inside of the laptop.
Most motherboard manuals will show you how to do this. The bias battary normally works for all motherboards. You bias setting will reset so it should work.
May 07, 2011 | Toshiba Computers & Internet
Panasonic hdtv, TC-P42X1, no picture, no sound. Power light flashes 10 times, pauses and then repeats. TV will not come on.
Tries tv unplug,replug it back like about an hour later.The tv will be resetting itself back to the factory setting.Now the tv should be working again.If it still have the same problems.The tv have a power supply board problems.That the board,where the a/c power cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Jan 19, 2011 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
We were watching TV and the TV just turned itself off. We try turning it back on and we have a black screen for 10 seconds and then the TV turns itself off again. Called Sanyo and they said to unplug it...
Yes,unplug,replug the tv an hour later.The tv should reset itself back to factory setting and work.Not,than the tv power supply board have problems.That the board,where the power a/c coard plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 07, 2010 | Sanyo 42 in. LCD TV
The red light is flashing 10 times what do I do
Tries unplug,replug the tv an hour later.The tv now will reset it self back to factory setting.Now the tv should work again.Not,than the power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Sep 30, 2010 | Panasonic TCP42C2 42 in TV
I lose volume on HD channels with Directv
Reset the Directv box,by unplug it,replug it and hour later to let the last software to update.Replaced the HDMI cable,goto ur tv menu,goto sound functions,go down to reset it back to the factory setting.After this the the sound functions should be stable,and work.Not,than ur Tuner signal board have some kind of intermittion short in the board.Than must replaced the Tuner board to solved this problems.
Apr 16, 2010 | Samsung LNT3242H Television
How do I hook up the 2 audio outputs from CD-ROM on Intel D101GGC
You shouldn't need to connect audio connections from drives to the motherboard unless you are using A Win 9x operating system. Digital Audio Extraction is used for WinXP and later and the analog cables are no longer needed
Sorry no info on the pinouts
Mar 29, 2010 | Intel D101GGC Motherboard
The bias was messed up and i need to know the bias for all of it
Find an option that says Reset Defaults or Load Defaults. Try resetting your BIOS using the option. On most systems, its either Ctrl + E, or F9. That should bring your system BIOS to defaults. You can modify your boot order, drive configurations later according to your choice and taste.
Mar 13, 2010 | Computers & Internet
Need help with a ricoh color 6513 with code c400
I assume that should be "SC400"... This is an error which can be reset by turning the MAIN power switch off for a few seconds and then on. The code will be cleared, provided the problem does not happen again.
SC400 - Image transfer belt bias error
Detected Conditions:
- Timing -
While the image transfer belt bias is ON
- Condition -
The feedback voltage is 4.8V or higher, or PWM value is 50% or higher for 500ms continuously.
Possible Causes:
• Poor connections
• Defective high voltage supply board (T1/PCC/BR)
• Defective I/O control board
• Defective main control board
• Worn Transfer Belt
Troubleshooting Procedure:
1. Make sure the high voltage cable and trigger lines are properly connected to the high voltage supply board, I/O control board, and main control board.
2. Replace the high voltage supply board (T1/PCC/BR).
3. Replace the I/O control board.
4. Replace the main control board.
[Signal Check]
• Feedback signal: CN209-9, TP264, or CN211-A4 on I/O control board / CN302-A6 or TP106 on main control board.
• PWM: CN209-10 or TP272 on the I/O control board.
Dec 16, 2009 | Ricoh 6513 Copier
Award bias bootlock
removing the BIOS (small watch battery on the motherboard) for about 45 seconds will reset the password..
then disable the floppy drive controller in the BIOS
May 07, 2009 | AOpen (MX4SGI4DN2PRE) Motherboard
Intel BLKD915GAVL (BLKD915GAVLX10U) Motherboard Logo
29 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
