i get fine reception on channels 2-34, but any higher and it just skips. I can't figure out how to reset the channels or to get access to a method to fix this. the menu doesnt give an option for chanel programming or reseting. anyone have any ideas, ide appreciate any help. thanks
If your remote does not have a menue to access auto channel programing, look for it on the TV itself. It may be hiding behind a small panel door, usually toward the bottom of the tv.Once you find it you may have to figure out how to bring the screen up that has programing feature. The screens usually can be brought up by channel or volume controls. Once the auto programing feature appears you push or press ok. If that does not work you should be able to manually key in each channel, one at a time. There as many variations as tvs. Hope this helps. Good luck. Larry
There is no channel search or add delete channels, even when you push in the channel number it wont...
(More)
There is no channel search or add delete channels, even when you push in the channel number it wont go.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
