Question about Paradyne (1740A1400) Router
How to setup vpn passthrough for paradyne 6211-i1
Cisco VPN client is no problem .
When I use Nortel VPN client it´s problem.
How can I solve the problem?
SOURCE: 6381-A3-302,6211-I1-300 Paradyne ADSL 2+/Bridge Router
Admin/Admin default id and password
Posted on Mar 06, 2008
SOURCE: trying to set up pptp on a Paradyne 6381
I have modem 6381-A2-200, sw ver.03.00.10. As far as I know this model does not support pptp-connection.
Posted on May 21, 2008
  • 143 Answers
SOURCE: configuring paradyne 6211 adsl2
i assume that the physical conenction of the modem to the computer is ok. if so,
- you need to access the modem's setup page by entering on your web browser's address bar. the default username is "user" and the default password if :admin"
- click on "device info" and select "quick setup", you can check the box "DSL Auto-connect" that will automatically detect your PVC (vpi & vci) but if you already knew these info, you can just enter it on the screen and click on "next"
- then go to "advanced setup", select "wan"
- if you don't have any "wan setup", you can click on "add" but if you do have one, you can just click on "edit" if it's not the correct internet settings
- then it'll promt you to select more settings like the "vpi" and the "vci", the "service category" (note: for the service category, you can select "UBR w/o PCR" but to make sure that it's the correct setting, you can ask your ISP). click on "next"
- select now "pppoa" or "power over atm"
- then select "vc/mux" for the "encapsulation mode"
- then click on "next", then click on "finish" to save the settings
hope this'll help you.
Posted on Jun 19, 2008
SOURCE: Bridged Mode
Verify this with your ISP, but if you go into your modem settings, click on "Advanced Setup", click on WAN, when page opens, click "Edit". After clicking "Next", you come to the page labelled, "Connection Type". It is there you select what mode you'd like it to work in. When you are through selecting click NEXT till you get to the page with the SAVE button. Click Save and wait for page with FINISH to come up. Click FINISH and wait for the router to reboot(2 mins). Please write down the previous settings so you'll be able to undo whatever you do.
Posted on Jul 19, 2008
SOURCE: what is the username and password for paradyne adsl2+ 6211-A3-304
The default username is Admin and the password is Admin. Both are case sensitive
Posted on Sep 04, 2009
  • 143 Answers
SOURCE: Can the Paradyne 6211 ADSL2+ modem support
ADSL2+ (aka ITU G.992.5) Is a standard that notable for its theoretical max download speed of 24 Mbps. Your carrier is mistaken. Howevver, perhaps they are claiming this because the speed is available on their end and there is a setting in your router causing the low speeds. There also could be high noise on your lines. Your router has a BER test that will tell you statistics about your line. Report that figure as well as your signal to noise ratio to your carrier to see if that changes their opinion.
Posted on Nov 28, 2010
0 characters
1 Points
Cisco expert
I think you're confused. IP Communicator is the unified communications client (IM and Phone) It is looking for a capatible headset so you can use your softphone. This software is not your VPN client. There are two different cisco product: one for your VPN and one for your phone. If you're trying to ocnnect to an old-style Cisco VPN, your IT dept will have to configure that with a certificate.
Solution from Cisco:
This behavior is observed when a user attempts to install or use the IP Communicator on a system that has different names for the Playback (wave out) and Recording (wave in) devices.
In order to overcome this problem, perform one of these tasks:
-Use a USB headset that is recognized by the IP Communicator.
-Upgrade to the latest version of the IP Communicator
Nov 07, 2013 | Arris SURFboard SBG900 Wireless Router...
Belkin N1 F5D8231-4 V3000
are you running the Cisco VPN client from home, where this Belkin is your gateway and connecting to say your work?
If so, have a look in the settings of the Belkin to see if you can enable VPN Pass-through.
Try disabling some of the firewall functions on the belkin to isolate the issue and turn the rest back on.
If for some reason this model doesn't work even after the above, try changing the VPN client's connection settings,there are only two to choose from... (click modify on your connection entry, go to the Transport tab > then choose from:
IPSec over TCP and IPSec over UDP (port 10000)
Sep 07, 2009 | Belkin (F5D8231-4) Wireless Router...
VPN Using XP Servers and D-Link WBR-2310
I had exactly the same problem. The solution is to set up pptp as a virtual server pointing to the lan ip of the server. Port forwarding only forwards the port but not the GRE protocol (pptp passthrough)
Jul 26, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
DLink DI-624s - can't get Cisco VPN Client to connect.
The "Virtual Server" setting is designed to give the general public access to a network resrouce (web/ftp/media server) on your internal network. If your the VPN concentrator is external to your network (meaning you'll have to use the internet to connect to it), then you won't need to define a virtual server on the DI-624.
You'll just need to enable the IPSEC and PPTP VPN Passthrough which it sounds like you've already done this. I've run into some ISP's that block VPN connections out of their network. If you have the ability, try to directly connect your laptop into your cable/DSL modem in place of your router and see if you can make a VPN connection, if not contact your ISP, if you can then verify you enabled the VPN passthroughs because your router is blocking them.
GIve it a shot and let us know your results.
Apr 26, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Belkin N1 Vision (Part # F5D8232-4) and VPN problem
I hade the same problem with mv Cisco VPN v5.0 and Belkin N1 router (F5D8231-4 v4...). I could only solve the problem with a new firmware (f5d8231-4 ww v4.00.18 at ). I think this is a general firmware issue at Belkin. Good luck.
Feb 27, 2008 | Belkin N1 Vision Router
Router is blocking my VPN client
I have the same problem with the Cisco VPN client, but when I turn the firewall off on the SBG900 it works fine.
Feb 20, 2008 | Arris SURFboard SBG900 Wireless Router...
Cisco VPN Client won't connect
You'll want to enable the VPN transparency. In the router's administrative web interface, click the Security Tab, then the VPN Passthrough sub-tab. Cisco VPN's usually use IPSEC, so enable the IPSEC Pass-through and click "Save Settings". If this doesn't work enable the PPTP Pass-through as well and give that a shot.
Dec 31, 2007 | D-Link AirPlus Xtreme G DI-624 Wireless...
Vpn pass through problem with us robotics model 5461
login to the router and check these things
IPSec Passthrough: Enable Disable               PPTP Passthrough: Enable Disable               L2TP Passthrough: Enable Disable
Oct 29, 2007 | U.S. Robotics MAXg USR5461 (738168036790)...
Nortel Contivity VPN client?
Nortel Contivity will work with the your D-Link router, however its functionality depends on the authentication type (AH will not work), NAT compatibilty mode, and disabling keep alives on the server. Contact your Network Administrator to find out how your VPN is configured. Step 1 Verify that you are using the latest version of firmware on your router. Step 2 Login to the Web Management for your router by entering its IP address ( in your web browser. The default username is admin, and the password is blank. Step 3 Click the Advanced Tab to access the Virtual Server Settings. There is a list of pre-defined Virtual Server Rules towards the bottom of the page. Find the IPSec Rule. Click the pen and paper icon to edit its settings. Enable the rule, enter the IP address of the computer attempting to connect to the VPN in the Private IP field, then Apply the changes. Step 4 Create a new Virtual Server entry. Name the Virtual Server, "NortelVPN". Enter the IP address of the computer attempting to connect to the VPN in the Private IP field. For the Protocol Type, select Both. Enter 9550 for both the Public and Private Ports. Set the Schedule to always, then Apply the settings. Step 5 Access the Tools Page, then click the Misc button. Disable IPSec Pass-through, then click Apply. If the VPN Server is properly configured to work with clients behind NAT routers you should be able to connect to the VPN.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Routers Logo
74 people viewed this question
Top Paradyne Routers Experts
 C. Dante
C. Dante
Are you a Paradyne Router Expert? Answer questions, earn points and help others
