Indesit washing machine
When i turn the program dile to the program i want and turn it on it will start to empty and then the dile will start turning and continue to turn
  • 139 Answers
This turning of the dial signifies a fault.. Indesit machines are made this way.. The most likely cause of this is the pump filter is blocked but can be either your carbons on the motor ( the latter is very uncommon). Saying it is the filter then what do is remove the flap at the bottom front of the machine. unscrew the filter and thoroughly clean.. Then to reset the dial what you have to do is leave the door open; turn the dial to a black dot; then press the on and off bottom untill the red light flashes quickly.. then the dial is reset.. try out a wash and see if the problem reoccurs..if it does then you might need to get someone out
Posted on Dec 04, 2007
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
Indesit washer not draining
Check filter not blocked and pump turning freely
May 09, 2012 | Indesit Washing Machines
Hi i have an indesit w 123s washing machine, that set to any program it doesnt move on it just does that setting,then if you turn the machine off and set it to end program you can reset to rinse and the...
hello try restting it before you bin it
  1. Turn the washing machine off with the on off button.
  2. Turn the selector knob to a dot, or any off position
  3. Turn the washing machine back on and watch for rapid flashing on the neon light
  4. Turn the washing machine off and select the new program (or maybe spin)
  5. Turn it back on and the new program should start
NOTE: Resetting the timer selector knob as shown above may stop the clicking round, but if your washing machine has a fault, the clicking round may return when your washing machine encounters the fault again. If your washing machine's program selector knob is clicking round on its own, then read the section above Washing machine stops with lights flashing hope it helps
Mar 13, 2011 | Indesit W 123 Front Load Washer
The washing machine doesn't recognize its washining programs. I have to reset I suppose but how? Indesit w123
u select any program then turn off by the wall then you turn on and select another and turnoff by the wall wait 10 mins then turn on select the program you want and will work, theres another link on the internet somewhere ive seen it.
Nov 29, 2009 | Indesit W 123 Front Load Washer
Program switch of Indesit-WD105T starts rotating
I had the same problem. I followed the signal lamp code and replaced NTC dryer sensor. The same error code came again. After that I reprogrammed EEPROM with original program and start getting different error codes. Finally I replaces all of electrolytic capacitors and it just start working with no problem. So, if you are planing to repair indesit than start with capacitors.
Tip: use capacitors with higher voltage than original, because voltage on PCB is around 16v
Oct 19, 2009 | Indesit Washing Machines
Indesit w123s on daily wash program no8 it starts to fill stops and emptys then starts clicking around on the selector knob the only way to reset it is to switch off and leave for a few minutes all the...
you need to open up the small door where the filter is and clear it out. Mine does this everytime my son puts his trousers in the wash and forgets to empty the pockets! we've had all sorts, elastic bands, wrappers, and money. Usually the machine still has water in it as the filter is blocked it won't continue the programme until this is clear and thats why the continuous clicking happens.
B. Green.
Nov 03, 2007 | Indesit WA 115 Front Load Washer
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
