Question about Western Digital 250GB ELEMENTS EXTERNAL USB 2.0 250 GB Hard Drive
Why won't My external Hard drive work on a Macintosh
I just bought a new western digital 250 GB 2.5" external hard drive with no external power supply. I formated it on windows vista but need to back up info on a Mac as well which it does not work on. Whenever I try to drag and drop to the icon it says that this item is unchangable. Please help, the only reaon I bought this was to back up items from all my computers.
Did I format it improperly or with a particular setting?
thanks in advance!
Kyle
Don't worry just download NTFS-3G for mac its free. Then you will be able to write to Windows NTFS formatted hard drive and drag and drop. Just search for it on www.sourceforge.net
Posted on Sep 28, 2010
  • 77 Answers
You probably formatted it with an NTFS filesystem. The Mac won't read NTFS drives. You will need to reformat the drive (after backing up the data that's on it) with a FAT32 filesystem. AFAIK FAT32 is the only filesystem that can be read by both Mac and Windows.
Posted on Jan 19, 2008
  • wells2452 Sep 07, 2011
    Initially my WD drive was not seen on PowerBook g4. Then, it worked on Pc. I formatted and it probably formatted with NTFS. I have backed up some files on my Pc, but would like to back up my Mac files as well. Can i reformat to a Fat32 and not lose everything? In addition, do I need to select to reformat as Fat32, how is that done?
Describe your Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Problem Do you have a picture of the voltage and amperage adapter for the Western Digital 250GB MyBook External HD ?
I don't have a photo of the AC adapter, but if you look on it the Voltage and Amperage specifications are;
Input: 100-240VAC / 50~60Hz
Output: 12VDC / 2A
This means the Input power can be from 100 volts to 240 Volts AC, and at 50 to 60 Hertz
The Output power is 12 Volts DC at no more than 2 Amp's. (Amperes)
Asian Power Devices Inc. has a model DA-24B12 that fits these specs.
Also a Wattac AC adapter model number - BAO362Zl-8-A01 will work.
Otherwise just use a 12 Volt, 2 Amp power pack, with a positive on center contact, and a 2mm pin hole
Nov 23, 2010 | Western Digital 250GB MyBook External USB...
Ac adaptor will not work
Go to any computer-store, and buy a new "empty" external drive enclosure.
Then, "transplant" the disk-drive from your W.D. enclosure into the new enclosure.
All your files will remain accessible, and the new power-supply will power your disk-drive.
Nov 04, 2010 | Western Digital 250GB ELEMENTS EXTERNAL...
Dear Sir/ Madam, I have TWO Western Digital USB
first of all , you are looking at the wrong voltages. The important voltage is the DC OUTPUT, which is the voltage the external harddrives use AND the polarity of the plug attached to the harddrive end of the cable.
if both the harddrives have say 12v dc output and both have the insignia of the center conductor being + (posative) then you can interchange them. and you CAN run a 9volt unit with 12volt DC power, but not the other way around.
Look at your power adaptors again for the OUTPUT and polarity.
should be a half-circle with lines depicting the polarity(+,-) of the center and sheild connections to the hard drives printed on both the harddrives and the power adaptors . This can also be tested with a dc volt meter while the adaptors are plugged into the wall.
DO NOT try to test the AC end while plugged in!!
Regards
Aug 09, 2010 | Western Digital 250GB MyBook External USB...
Hello my hard drive quit working. It say it working properly but won;t show up on my computer can u help
Hello Klpook, Hi, 1. scan your PC with an antivirus software, if the action failed to work, 2. use another PC to check if your Hard drive is good. if the other PC failed to detect you hard drive. 3. Use Hard drive utilities, such as Disk manager for Western Digital to diagnose your HD. If by chance no positive work is done. Your drive is bad.
Feb 23, 2010 | Western Digital Elements powered by WD 320...
What voltage and amperage the western digital wd25001032-001 will work. I lost the original power supply and need replacement.
Mine has a 12V 4A power supply. This is not generally available as a generic replacement, due to the high current required. Good luck!
Feb 21, 2010 | Western Digital 250GB MyBook External USB...
Western Digital 250GB ELEMENTS EXTERNAL USB 2.0 250 GB Hard Drive Logo
2,369 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
