Question about Compaq Armada E500 Notebook
Harddisk drive locked
4got my power on password
  • 1 more comment
  • katta2k4 Dec 04, 2007
    which little battery r u referin 2 pls robert c? the normal notebook's removable battery or another 1 somewhere els inside the notebook?
  • katta2k4 Dec 31, 2007
    well ive opened the panel and seen the red and black cable..actually i saw 2 matching the wires description..1 on the left and the other on the right...which 1???..well i tried the 2 and it still asks me 4 the "DriveLock HDD bay password"...what do i do!!!!????
  • Mathew021 Dec 12, 2008
    am facing the same issue...
    i have reseted cmos/bios....
    Then again my HDD is asking for a password...
    Error "Please enter the Hard-drive password and enter"..
    Someone please help me....
Its a little battery inside,like one for a watch but bigger
Posted on Dec 05, 2007
    Problem Solver:
  • 15 Answers
To reset the bios password you need to do the following.
1) Remove the main battery and ac adapter.
2) Disconnect the bios battery.
3) Wait for at least 5 minutes.
4) Connect the ac adapter. The laptop should start powering up.
5) Press the cntrl and F11 keys. The laptop should enter the setup menu.
6) The bios is now reset to factory settings.
Posted on Dec 04, 2007
  • jodell8964 Dec 06, 2007
    Katta2k4,
    The bios battery is located inside the laptop under the plastic control panel strip. This is the strip above the keyboard. You need to remove it to access the bios battery. To remove this strip you will need a torx 9 screwdriver or a small slotted screwdriver. On the back of the laptop, the I/O port side, there are 4 black torx screws. There are 2 on the right and 2 on the left. These screws are aligned one above the other and support the LCD. You need to remove the top torx srew on both sides. Do not remove the lower screws. Carefully swing the LCD back all the way so the laptop is fully open. Then carefully pry up the control panel cover until it comes off. Once the cover is off, you should see the bios battery cable. It's the small two wire cable with a black and red wire leading to a connector on a small module called the LED board. Disconnect this connector carefully. The bios battery is now disconnected. Reverse the above procedure to reassemble the laptop.
    Problem Solver:
Hi is it a bios password, if so you need to remove the little battery inside and power on without it,once you get going you can put it back in, hope this helps.
  • robert c Dec 05, 2007
    let me no if you need any more help
I have a dell inspiron 15R that has a blue screen telling me that its harddisk security and then it says Sata port o wdc wd10jpvx-75jc3t0lock? help? How to fix this??
The hard drive has been locked in the BIOS. If you cannot get into the bios with a password you can contact Dell for a code to unlock the BIOS and drive ... Here is a link that might help.
https://www.dell.com/community/Windows-General/Harddisk-Security-Sata-Disk-0-Lock-on-hard-drive/m-p/4429575
Feb 15, 2018 | Dell Computers & Internet
Aspire one laptop I turn acer on and screen shows Harddisk Primary Master ST9160310AS lock
All solutions point to having to contact the drive manufacturer or laptop manufacturer. There is good explanation in the Tom's Hardware thread at the end, about a 'master password' ...
4.June.2014
Hard disk security primary master lock
harddisk security primary master lock
Jun 04, 2015 | Acer Aspire One D150-1587 Netbook
The harddisk security sata port 0 , how can I open this laptop harddisk because it is locked
If a hard disk is password protected, you must get the password. There is normally no way around it.
However, if the user password has been set, the administrator password on the hard disk can be used to delete it. I am not talking about Windows accounts here, I refer to passwords stored in the firmware of the hard disk.
Jan 18, 2015 | Toshiba MK6465GSX) 640 GB SATA II Hard...
Acer Laptop, hard disk security locked?
It seems that drive lock for this drive is enabled from BIOS. Is BIOS also password protected? Drivelock can be removed from there.
May 06, 2014 | Acer Aspire Computers & Internet
Sata port password
The password was set by the hard drive owner. Nowadays hard drives can be encrypted and therefore locked and a unique password is required.
Oct 27, 2013 | Computers & Internet
To disactive the password of harddisk
LOL, you're out of luck. If you're smart enough to set the hard disk password, you should be smart enough to remember it. 99% of the computers that have a password lock on the hard drive are stolen computers. The original owner put the lock on to keep thieves from getting to sensitive data. The owner could have set the password remotely once the computer is stolen.
The computer is useless to you. The only way the password can be broken is if the original owner who put it on, takes it off? Even if you take the hard drive out of the computer, it can never be used again as long as it has a password lock on it.
Apr 08, 2012 | Acer Aspire 5732Z-4855 Notebook
Blue Screened= Harddisk Security Password
need more info is this a IBM? mechine what OS the password what made (providing IBM) when the drive was activated formatted. was this bought used? is the company that you bought it from still around if not you can try the simple 12345 NOTE!!!! you will only have three chances to try then the drive will lock and become totally useless in which you will have to buy another drive and OS unless you have the install disk
Mar 08, 2010 | Computers & Internet
Ipod lock
try formatting your nano first.
Jun 03, 2009 | Apple iPod nano
How can i change my harddisk password in acer aspire 5600 series..
Power on, enter the bios setup (press F2, F10 or [Delete] when powering up and go to the "security" section.
Locate "drivelock" or "harddisk password", from there disable the HD lock.
Apr 24, 2009 | Acer Aspire 5602WLMI Notebook
Compaq Armada E500 Notebook Logo
385 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
