Question about Acer Aspire L100 PC Desktop
Acer L100 wont power up
My acer L100 wont power up, the blue led on front wont light up, the thing is dead!! the transformer is lit up but nothing on pc,
    Problem Solver:
  • 10 Answers
Bad PSU
Posted on Aug 25, 2009
Testimonial: "thanks for that about the psu, but i have been told by a local pc repair guy that psu's are as good as rockin horse poo to get cos the L100 is mini?"
My acer L100 wont power up ! no light at all .power is 19vdc at power supply- all this, after warranty fixed it twice in texas then they sent me a new hard drive worked for a couple months now its dead and no warranty . Thanks Acer
Posted on Sep 01, 2009
SOURCE:
Passenger power window not working on 2002 Saturn L100. Fuse OK, so is relay. Anything I am missing?
Hi Lance
Just a process of elimination
Run a power lead from Battery directly to motor & test.
Cable to motor may be broken internally from flexing at door joint?
Good Luck
Sep 21, 2015 | Saturn 2002 L-Series L100
Acer aspire l100 will not boot but fans run
Try removing/disconnecting the hard drive and see if the BIOS boots up, if it does the HDD is causing the problem. Are you getting any beeping codes on start up, if so how many and hoe long in between?
Dec 06, 2011 | Acer Aspire L100 PC Desktop
Acer l100 just died a death can any one help please pc repair man said that it was a common fault with this product what is the common fault
He should of fixed it if it's a common fault! It's probably the power supply if it's dead. Do you get the power light to come on?
Dec 15, 2010 | Acer Aspire L100 PC Desktop
My aspire L100 will not boot. When on button pressed blue light comes on and then goes off straight away and fan starts Ok but nothing else
You may need a new power supply....also check your internal fans to make sure they are spinning. Make sure memory is seated properly. Motherboard may also be in question. Try unplugging letting it sit for a few then plugging back in.
Aug 05, 2010 | Acer Aspire L100 PC Desktop
Computer wont start acer aspire L-100
CPU overheated? When you cool it down it will start. You can check whether there are lots of dust on the CPU fan and the chase of the machine, they might block the air flow and overheat the CPU.
Jul 08, 2010 | Acer Aspire L100 PC Desktop
My Acer Aspire L100 PC Desktop won't start.. when i press power button it only flash LED light jus one time but no HDD sound or CDROM working sound. only CPU fan works thas bout it...Any help? pls
Do you see anything on the screen?
Try the following things:
  1. Try starting the computer with only the battery
  2. Remove the battery and try booting with only the power adapter
  3. Try removing and replacing your memory
Could be a bad power supply or bad battery. After you try the above steps, report your results.
May 22, 2010 | Acer Aspire L100 PC Desktop
The acer l100 does not power on at all no lights or fan running
If the computer is not starting then and the power supply is ok then you need to try a different charger. If the problem still exist this may a sign that the motherboard is dead and need to be replace, because when a motherboard is dead it the computer will not receive any power.
Thank you
May 16, 2010 | Acer Aspire L100 PC Desktop
Acer aspire 3610 power lead transformer green light is on before plugging into laptop then goes out when plugged in.acer has nothing working, totaly dead any ideas?
If the power LED is lit before connecting to your laptop and then goes out as soon as you connect to your laptop, then you either have a short circuit in the power supply module of your laptop, or you battery is causing the fault.
Remove the battery and try again. If it powers up the battery needs replacing. If the problem is still the same then you need someone to look at the power supply module in the laptop
Mar 09, 2010 | Acer Aspire 3610 Notebook
Acer won't turn on ,no battery being used only ac power
I have the feeling that the battery has to be in place to allow the AC power to be transferred to the mother board
Jul 06, 2009 | E-Machines eMachines Desktop PC
Acer Aspire L100 will not power up
Power supply is bad. Replace the power supply.
Dec 30, 2008 | Acer Aspire L100 PC Desktop
Acer Aspire L100 PC Desktop Logo
692 people viewed this question
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
