Question about Refrigerators
Whirlpool fridge/freezer ARC 7050
The fridge part upper compartment is not cooling and remains at room temperature. I suspect the PC board behind the temperature dial any suggestions?
  • handymusic Dec 05, 2007
    handymusic
    Coxy, Thanks for your reply. Yes we have tried defrosting for a day but with no results the fridge did come on briefly and then stopped working again. The temperature dial is completely useless. Since I am looking at this problem for a friend I am a bit reluctant to buy another control panel which I presume I will need to do? I can fit a new unit but I am worried about wasting my friends money if this is not the problem.
    Sergeant:
    Champion:
  • 231 Answers
See if you can remove panel inside freezer to see if its full of ice all over condenser .Even if you already defrosted for 1 day..If its full of ice ..Then the DEFROSTER COIL is not working and not melting the ice on condenser and then stoping the cycle therefore compressor will stop running..Also there should be a a couple of thermal switches on the condenser(two wires) if this is bad then there is no cycle..goodluck
Posted on Dec 06, 2007
My frost free fridge freezer is working but flashing de on the front. I'd like to know what it means
Error codes are brand (and often model) specific. "de" likely indicates something in the defrost process, especially on G.E. Check for ice build-up in the freezer cooling coil. The control board would be suspect, but must be checked to confirm the precise fault.
Oct 20, 2014 | Refrigerators
Kenmore appliances manuals
All cooling is done in the freezer. Refrigerator side gets air from the freezer. Controls are usually in the refrigerator compartment, upper front or center back
Aug 18, 2014 | Refrigerators
The fridge component of our fridge & freezer is not cooling enough regardless of how cold I put the setting. Even at 7, it feels like room temperature. I pulled the fridge out from the wall, there are...
Once ice forms on the freezer coils there is no air flow. I had the same thing. I suspect your defrost cycle is compromised. Could be the bimetal switch, defrost timer or defrost heater element.
Nov 25, 2017 | Whirlpool Gold GB9SHDXP
Refrigerator warm freezer too cold
If you have already adjusted the controls for temperatures in both compartments and allowed 12 - 24 hours to stabilize and the trend is continuing, there may be a problem with the fans that move the cold air from the freezer to the fresh food compartment. The fridge may also start allowing temperatures to rise in the freezer soon, too.
All of these problems originate in the freezer compartment, where the cooling is done. Behind the back wall; inside the freezer - lies the cooling coils, defrost heater, circulating fan(s) and defrost terminator sensor. Unplug the fridge. Empty the contents of the freezer, remove the ice maker assembly and the back wall plate and you should see these components. If it looks like a large block of snow and ice, the problem is with the defrost circuit components. If clear with a minimal amount of frost, the warm fridge is the result of blocked or limited airflow from this area to the fresh food compartment - likely a failed circulating fan. Plug the fridge back in and check to see if the fan is running - since the fridge is warm, it should be running. The fan or the thermostat will probably need replacing if it is not.
If icing or frost is the problem, you'll need to isolate and replace one or more of the following: defrost heater, defrost terminator or defrost timer. The last two are the usual suspects for this type of failure - but the heating element can fail too. Many times, the defrost timer is accessible from the front of the fridge, behind the kick plate below the freezer door on the right side. Other times it is located in or near the temperature control area.
Jun 18, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Side by side thermostat set low seems like it runs a lot more than it use to freezer and fridge are boyh cold
Check your coils underneath the fridge to be sure they are clean.
Check your condensor fan (bottom rear of fridge) to make sure it is blowing air freely.
Make sure you have a good supply in the freezer, All of your cooling comes from the freezer section and a mostly empty freezer will result in more frequent running as ther is not enough stock to help maintian and hold freezing temperatures.
Check your freezer section to make sure there is no visible frost on the back wall of the freezer (down low on the panels behind and slightly above the lowest freezer basket. If you see frost starting to develop it means you have a defrost issue starting and will want to adress it rather quickly. Either a problem with the defrost control board (inside fridge/freezer control compartment) or the defrost thermostat (behind the freezer back panel on top of the evaporator coils).
Hopefully this helps!
Jun 14, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The freezer works fine. The fridge remains at room temperature
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
May 31, 2010 | Refrigerators
My Whirlpool side-by-side model-ED20ZKXBW00 MFG date is 9-94. Freezer portion works great and refrigerator part is now barely cool so I have spoiled food. What could be causing this?
First thing to try is Powering off the FF at the mains supply and leaving it standing for 30 minutes. Make sure that you do not open any of the doors or touch any of the controls during this time. Then reconnect the power and wait for 30 to 60 minutes to see if the fault remains or is cured. Try completely defrosting the FF as despite common belief these units are not totally frost free.
In side by sides if the freezer side is working OK and the fridge side is not working correctly it means that air ducting has iced up or the air vent from the freezing unit to the fridge compartment has stuck in the closed or partially closed position which causes the fridge to not be any where near as cool as it should be. If it is too cold then the vent is stuck in the open position and the fridge temperature will continue to fall and become the same as the freezer, thereby freezing the contents of the fridge compartment. It can also get stuck in another position so that if the temperature is adjusted on the front panel then nothing happens to the temperature in the fridge compartment. The vent, which is usually at the top of the fridge compartment on the side where it joins the freezer compartment, is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up. It can be come iced up by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. If the sync motor and vent are working OK then there may be a fault with the fridge temperature sensor or main on board controller that will mean that the sensor or the controller will need replacing.
Nov 10, 2009 | Whirlpool 19.8 cu. ft. Side-by-Side...
FRIDGE/FREEZER MODEL: SR42NMB Multi Frost
You have a clogged defrost drain tube. best way is to thaw unit out. Your vents are being blocked so no air flow is pushed down.
Jan 05, 2008 | Refrigerators
Freezer side wont freeze
If the Freezer and the Fridge are not cooling enough then check that the condenser is not iced up and that the fan is running correctly. These are located behind a panel in the lower half of the freezer at the rear and can be accessed from inside the freezer compartment.
In side by sides if the freezer side is working OK and the fridge side is not working correctly it means that air ducting from the condenser has iced up or the air vent from the freezing unit to the fridge compartment has stuck in the closed or partially closed position which causes the fridge to not be any where near as cool as it should be. If it is too cold then the vent is stuck in the open position and the fridge temperature will continue to fall and become the same as the freezer, thereby freezing the contents of the fridge compartment. It can also get stuck in another position so that if the temperature is adjusted on the front panel then nothing happens to the temperature in the fridge compartment. The vent, which is usually at the top of the fridge compartment on the side where it joins the freezer compartment, is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up. It can be come iced up by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. If the sync motor and vent are working OK then there may be a fault with the fridge temperature sensor or main on board controller that will mean that the sensor or the controller will need replacing.
Nov 14, 2007 | Samsung Refrigerators
Refrigerators Logo
222 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
