Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
Power Adaptor I have misplaced my power adaptor and need to find a replacement.Alternativly could you advise me what the input votage and wattage is to the harddrive.
240 volt power adaptor, what capacity VA?
Considering the lack of detail in your post it is only possible to explain that VA or volt/amp is the same as wattage and that any mains adaptor should have a capacity that greatly exceeds the consumption of the device it is powering.
It is also important to use a regulated supply to power sensitive electronics.
Apr 29, 2018 | Power Computers & Internet
I'm traveling to India where electricity is 240. Do I need to buy a power converter for my Asus laptop?
most laptop power supplies support full range power input. meaning it will accept any normal outlet voltages used anywhere. if you look at the power supply of your laptop it should say vin (voltage in) 100v to 240v 50/60 hz, or close to that if it is.
Nov 01, 2016 | ASUS Computers & Internet
I have a Yamaha PSRE413. on/off does not work with adaptor, but works with batteries
If you are using the correct adaptor then the most likely reason is that the socket where the adaptor plugs in has broken away from the circuit board and will need to replaced/resoldered.
if you need a socket Google : Yamaha PSR power socket ( KPA3 / PA130UK / EPA3 ) (LB30226R)
OR if you have used the wrong mains adaptor and the polarity was reversed you may have damaged the diodes / voltage regulator on the power input.
Jan 24, 2013 | Yamaha Music
My F380 printer did not power on
Check votages of power adaptor 16V & 32V if its OK, replace logic card..
my suggestion is insted of replacing the logic card go for new printer.
Sep 26, 2011 | HP DeskJet F380 All-In-One Printer
Hi. I have a LaCie Hard Drive designed by Poulton with N2870 on it. I've misplaced the external power cord adaptor, and need to know what kind to get. The guys at Radio Shack said they need to know: ...
I have the same one. The power supply I have says input 100-240V output is 24W 12V 2A.
I'm replacing the power supply but my big problem is not knowing the polarity of the tip There is no sticker on the hard drive itself or on the power supply (that I suspect is fried). Can anyone help?
Lisa
Dec 13, 2010 | LaCie Hard Disk 500GB with Hi-Speed USB2.0...
DVE AC ADAPTOR, model :NO.: DV-91A, INPUT :
You dont need an exact replacement for your router to work, just check on radio shack for generic adaptors with the same specifications, they would work fine, make sure voltage is the same as well as wattage...thats all that matters, and obviously input being 120vac, Hope this helps..
Oct 25, 2010 | SMC Barricade g SMC2804WBRP-G Wireless...
I misplaced the power adaptor, and found one the fits in, but don't know if has the coorect powers output.. the power adaptor I have for this I rocks IR 4300 is an eblue mainstay with an output of 5.0...
as per irocks page this is the power info for your device:
Power : Self Power : 5V
Adapter : (input)100~240 VAC , (output)5 VDC
you probably may want to check with someone at radioshack if the adapter you found matches above specs
info on your device can be found here
Dec 26, 2009 | i-rocks IR-4300 4-Port USB Hub
Power Adaptor for 500GB LaCie P3 HD USB 2.0 7200RPM 8MB USA?
Both power adaptors are 4 pin, ITHINK that the Porsche that you have is the same as mine which has the smaller (4 pin DIN) plug 34W power supply.
But check on LaCie's site: http://www.lacie.com/asia/products/product.htm?pid=10857
Hope this helps.
Chris
Jul 23, 2008 | LaCie Computers & Internet
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
78 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
