Whirlpool ACQ158XP Thru-Wall/Window Air Conditioner
Problem for Whirlpool ACQ158XP Thru-Wall/Window Air Conditioner
Motor will not keep running after i help start it
By stevenso_g on Aug 25, 2009
motor will not keep running after i help start it turning
Best Solution
posted on Aug 25, 2009
Very Helpful)
blvl777
Rank: Guru
Rating: 88%, 91 votes
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Whirlpool ACQ158XP
Questions and Unsolved Problems for Whirlpool ACQ158XP
Do you recommend Whirlpool ACQ158XP Thru-Wall/Window Air Conditioner?
Answer
Answer
the passenger floorboard on my daughters Saturn Vue is wet. Could it be a plugged air conditioner... (More)
Answer
I am attempting to remove the front cover so I can clean my unit. I have already removed the screws,... (More)
Answer
The air fan does not work. Can I replace it myself? The compressor turns on but the air does not... (More)
Answer
i have a whirlpool ac it has leaked from somewhere my floor and everything around it is soaking wet... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Whirlpool ACQ158XP...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
