Question about Intermec EasyCoder PC4 Label Printer
Printer not responding
Actully i have lost my driver CD. and i downloaded it from the ftp server. while installing i gave the port as LPT1 and set the printer as the default printer. after installing the printer it is showing ready too. but when i give 'print test page' it's not responding and after some time it is showing that 'printing failed'. Please give me assistance soon.
Thank you.
Check the ink in the printer, clean its nozzles and then try for the test page.
Posted on Dec 09, 2007
It can't.
DOS printing need LPTx parallel port because DOS don't understand/support USB.
YOU can share the printer with windows printer driver, then
go to CMD prompt
Net use lpt1 \\<computername>\<printersharename>
Then print DOS job to LPT1
May 12, 2014 | Parallel USB Print Server 2 Port USB&1...
Unable to connect Dell 3000cn to wireless network (cable from printer to Linksys router). Printer shows ICP address, laptops set to share files, but computers do not "see" printer at all. Ideas?
The printer driver needs to be installed and the printer port changed from LPT1 or USB to a TCP/IP port.
Please refer to my tip on Setting up HP network printer. the principles are the same for setting up network printers with a print server.
Dec 02, 2009 | Dell 3000cn Color Laser Printer
I have an Epson Stylus Photo R220 Printer connected to a linksys print server, but
Well, The first thing you should do is to try to test of the print server is properly connecting to the printer. Check the linksys printserver manual and look for how to print a status sheel from the print server. Once done, get the IP address of the print server. Go to your laptop and navigate to control panel/printer. See if you have the driver installed or download the Vista Drivers from During the installation, it will ask you what connection type your computer uses. cancel out of the installation or choose LPT1 as the port. Once done, go back to control panel/printers.Right click the R220 icon and navigate to properties. Select ports after that and add a new port. Select Standard TCP IP port after that. Once done, the wizard will appear. Input the IP address of the printer and finish the wizard. you should be good to go after this.
Sep 30, 2008 | Epson Stylus Photo R220 InkJet Printer
Zebra printers & MS Word
HI Les1810,
You should be printing faster with Zebra fonts.
Which driver are you using? Version?
I strongly recommend the Zebra Designer V1.3.08, available at
To isolate the problem, capture the output to a file.
Define a local port as C:\output.txt and set that as the port in driver properties.
Now print your document. The printer commands will be in C:\output.txt.
Send c:\output.txt directly to your printer.
For LPT1, use the DOS copy command to send the file. (Copy C:\output.txt LPT1)
For serial connections, use Hyperterm to send the file.
For network connections, use ftp.
No easy USB method is readily available.
Does this print faster than printing the original document from Word through the driver?
If yes, then update your driver.
If no, debug your communication to the printer (LPT1, serial, network, etc.)
Sep 24, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Lost Installation CD for Wireless Router WBR 1310
Here's the link to the setup file on the d-link site:
I had to special request this link. If you go through all their information on their site, it states you should be able to obtain a copy of their installation CD as a download file. But you can't find it anywhere. So, after I requested it, they gave me this FTP link, directly into their server. I don't know how long this link will last. It worked as of 4-21-10.
Sep 15, 2008 | D-Link 802.11g Wireless Router WBR-1310...
HP Laser Jet 1320 Printer installation
Just downloading the PCL5 driver was not enough for my computer. Maybe it is enough for other users' computers. But in addition to downloading the drivers, i had to also download and install the "HP Laserjet 1320 plug and play print driver solution" at the bottom of the driver list. Save the file to your desktop, double-click it and follow instructions to install, then reboot. Then when I checked my printer list, the HP Laserjet 1320 was there. I printed a test page, and now i am good to go. Hope this helps.
Aug 05, 2008 | HP LaserJet 1320 Printer
Intermec EasyCoder  PC4 Label Printer Logo
171 people viewed this question
Top Intermec Office Equipment & Supplies Experts
Paul Bade
Don  Farrell
Don Farrell
Arizona Information...
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
