Question about Xerox DocuColor 12 Printer
9-369 hello, after turn on machine is starting to warm and become ready position.After print start , machıne is code 9-369 while developer unit comleted first action.Also while the front part is open the machine is not appear "close the open door" .Which card of machine is problem?martisantic@yahoo.com.
    Novelist:
  • 208 Answers
: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
or
  1. Power OFF the machine.
  2. Wait 30 seconds.
  3. Power ON the machine.
Posted on Dec 04, 2007
Konica minolta bizhub 601 warming up option donot show ready to copy
Sir/Mam,
Have you had the developer and drum replaced recently, or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum or next to it depending on the series. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure/Developer Charge, and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8/Developer Charge. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 19, 2018 | Konica Minolta Office Equipment & Supplies
Konica minolta 240f error code 18 stands for what
https://printcopy.info/?l=en&mod=erc&brand=Konica-Minolta&model=bizhub%20240F&code=18
Konica Minolta bizhub 240F Error Codes
Quoting from the web link shown above:
Konica-Minolta bizhub 240F Error Codes
Exploded Views and Parts List Free!
Code
18
Description
Fuser Error
(The number indicates the detailed error code) 0 The fuser did not become to the main motor driving temperature in 50 seconds after printing started. 1 The fuser did not become to the paper pick-up temperature in 50 seconds after printing started. 2 The fuser did not become to the main motor driving temperature in 30 seconds after warming up started. 3 The fuser did not become to the warm-up finishing temperature in 30 seconds after the motor started driving. 4 A temperature of 250°C or higher is detected in a mode other than sleep mode. 5 The fuser does not warm after fuser error is solved and the power is turned OFF/ON. 6 A low temperature of 10°C is detected in 10 seconds after printing started. 7 A temperature of 190°C is detected in ready mode after printing finished.
Remedy
1. Turn on the power again, and verify the fuser warms up. If it does not, see step 4. 2. Check the contact between Fusing thermistor and Connect A PCB(P89). 3. Check the contact between Connect A PCB (P80C) and the main board. 4. Replace the Fuser. 5. After replacing the Fuser, verify the fuser warms up when the power is on. 6. Replace the main control PCB.
Apr 07, 2018 | Konica Minolta Office Equipment & Supplies
I need help to clear error 18 on konical minolta 240f.
Code
18
Description
Fuser Error
Remedy
Nov 19, 2017 | Minolta Office Equipment & Supplies
HI.How can i reset a copier minolta konica bizhub36?
  • Code: 0501
  • Description: Fusing heaters trouble (edge)
    • Detected temperature of the heating roller thermistor (TH2; edge) does not go up a given range of temperature even after a lapse of given period of time at warm up. • The warm-up is not completed even after the set period of time has elapsed after the warm-up is started.
  • Remedy: 1 Check the fusing unit for correct installation (whether it is secured in position). 2 Check the open/close operation of the right door. 3 Check the fusing unit CN30-PRCB CN16, fusing unit-relay CN4AC-DCPU CN2 for proper connection and correct or change as necessary. 4 Change fusing unit 5 Change PRCB 6 Change DCPU
This is from manual, try to reset trouble code:
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
Hope it helps
May 29, 2017 | Minolta Office Equipment & Supplies
WHY OUR MACHINE Di2011 DEVELOPER AND DRUM ARE BRAND NEW. BUT STILL BRINGS PROBLEMS E.G SERVICE CALL AND MACHINE TROUBLE SHOOT.
Was the counters cleared first? for the drum and developer, has to be done because the machine uses the counters to tell the copier what voltages to apply to certain assemblies. If not done causes codes and image problems. That is also how the copier has a new drum and developer, after the drum and developer where replaced was Toner Density procedure run. And no prints copies or faxes where received after the developer was replaced and running the Toner Density procedure, and any did get ne developer and start again. Must disconnect network cable and fax cable before changing developer also.
Jul 01, 2014 | Konica Minolta Bizhub c203 Copier
Warming-up
MODEL #######################
Power off the machine. Then remove the toner bottle, be careful the hole might be on the bottom and the toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KNUB on the side of the bottle is damage put a new one in. That KNUB is what the toner motor uses to turn the bottle, if it damaged you get a code. If that does not work, you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad.
OR
Have you had the developer and drum replaced or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done, so that equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared. Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer, FIRST? IF not then the copier thinks the new drum and new developer are old. The copier works on the counters that is how it knows it got a new drum and developer. Get new developer and a new drum and have it installed correctly. Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE A VACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you will start all over again with new developer and a new drum.
Try this site for parts as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Apr 02, 2014 | Konica Minolta Office Equipment & Supplies
My bizhub 600 is showing message warming up ready for next copy
Sir/Mam,
Mar 31, 2012 | Konica Minolta Bizhub 600 750 Image...
Hello, I am having problems with a Di2510 machine. When it is turned on I get the 'Please Wait' screen, and then nothing? It just stays frozen on that message
sir, Have you had the developer and drum replaced or does the screen say Replace PC Drum? There are certain house chores the copier does before "Ready to Copy" it is waiting for them to get done equals "Please Wait". One big item is making sure the developer and toner are properly mixed inside the image unit underneath the drum. Might want to have the developer replaced and drum/cleaning blade normally done all together, then run the F8 procedure and make sure the counters where cleared Did you recently replace the drum and the developer if so did you clear the counters for the drum and developer. IF not then the copier thinks the new drum and new developer are old. Copier works on the counters that how it know it got a new drum and developer. Get new develop and new drum and have it installed correctly, Counters are clear before the unit is yanked out of the machine, then you remove the image unit/drum unit replace the developer/drum and cleaning blade. (DO NOT USE AVACUUM CLEANER WHEN REPLACING THE DEVELOPER static electricity can destroy the sensor located below the developer unit. Then reinstall and RUN F8. Make sure the fax line and Ethernet cable is removed can't print anything until the F8 is run. Or you start over with new developer and new drum
Aug 11, 2011 | Minolta Di2510 All-In-One Laser Printer
When is turn off the swıcht rpm indicator is not comıng zero..
Battery condition? Make sure battery connections are clean and tight this is a very common problem.
Mar 12, 2009 | 2004 BMW F 650 GS Dakar
Error code
SC No. Item Definition Possible Cause Related
SCs Troubleshooting Procedure Type
SC
393-
001
TD sensor error
during warming
up
393-001: K
393-002: Y
393-003: C
393-004: M
The development-unit drive
starts. TD sensor signal is 0.78
V or less.
• Loose cable
connection
• Positioning plate out
of place
• Defective TD sensor
• Development unit not
found
1. Turn the main switch off and on.
2. Check that the development unit is
correctly installed.
3. Remove the development unit and
check the connector on the rear.
4. Check the positioning plate.
5. Replace the development unit.
Hope this can help you , seems the problem is on the black development unit
Aug 12, 2008 | Office Equipment & Supplies
Xerox DocuColor 12 Printer Logo
713 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
