Hi All,
We have run out of disk space on 2600 server array0 raid1 so I added 2 more drives and setup another array1 raid1. So I just wanted to boot of hiren's boot cd and use norton ghost to clone array0 over to array1. Then remove array0 from the machine stock the drives away and run off the new array1 which are larger drives.
I cant get it to boot of the cd or even a floppy boot disk even though its set in bios. The system just wants to boot from array0 and go straight into windows server.
Windows can see the new drive and at the moment it's no allocated.
Is it possible to clone the drives in windows including the partitions?
Many thanks, PaulC
I should assume the CD drive is SCSI? What sequence is it set to come up in? Set it at 2 if possible. Have you checked, or better yet replaced the CD drive? Will it boot with ANYTHING else?
That Hiren's CD is not uuummm, kosher? People having problems booting with it and all, plus the utilities may not have full function anyway. No matter what, you will need to f/disk the destination drive. You will still need the CD drive to install the program too.
Backup software will still make an exact copy of your drive also. You might want to consider a little better product, especially concerning disaster recovery. not to get off topic but, a quote from J. Bolton on backup & recovery
"What will you do if a user overwrites a 1000page doc with a blank file with the same name?
What will you do if one of multiple server apps goes bonkers?
If the mainboard dies how will imaging get your system back? Do you
stock a spare board so the image restore will work on the exact same
hardware? After a system crash, Acronis True Image Enterprise Server
allows you to perform a full system restore, a bare-metal restore or
just a restore of individual files and folders.
Complete
system restoration can be performed to an existing system, to a new
system with different hardware or to a virtual machine. You could setup a whole new system and dump the image on that.
