This is typical. If the heating element is no longer working, the unit doesnt know to turn off due to the clothes still being wet. However, the timer has absolutely nothing to do with the heating of the unit. If the timer doesnt turn off the unit even when the time is short (example: 10 minute timed dry), the timer has a different issue. If you have merely set the dryer to dry the clothes (not a "timed cycle" to dry) then the dryer will continue to run as I have stated before. The dryer will run until the clothes are dry. Now, its time to address the heating part. Your dryer heating element has gone bad. It can be replaced if you are somewhat handy. You can pick one up from your local appliance store and it has simple instructions. Please make sure that you disconnect the unit from its power source prior to attempting any repairs. Safety First. You can also call someone to replace it for you and it shouldnt be too costly. Good luck on either option.
This link will help you in diagnosis/disassembly/parts.
Possibly a faulty heat element is most common failure. Fix the no heat problem and the dryer should shut off ok.
Make sure you have correct voltage to the unit before tearing apart. Again visit the link above
Kenmore is a Sears brand and there isnt too much info on the net as for tech support. Youre best option is to call sears and see if they can give you any over the phone advice, but if the timer switch is getting stuck, it sounds like it may need replacing.
The most likely cause is a bad ignitor part number 279311. It has to glow to open the valve and ignite the gas. You should hear a loud click when you first start the dryer. That tells us there is voltage to the gas valve.
You probably have an open thermal fuse, the dryer will run in some cases and not heat, Just moving air across you clothes will dry them however it takes forever.
If you are electrical or mechanical replace the thermal fuse yourself if not call someone you trust, you can purchase thermal fuses on line from Sears.com just do a parts search for you specific dryer.
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
My dryer is making a loud sound while drying the clothes. The heater still works, but is just very loud while drying. What is the problem with my dryer?
