Question about Gigabyte 7VM333M-RZ (GA-7VM333M-RZ) Motherboard
Hard disk installation
Can it support a 320 gb hdd (IDE) to my 7VM333M-RZ mobo ?
  • Anonymous Dec 04, 2007
    why the power supply can"t supply the board,memory,and others
  • aashit shah Sep 30, 2008
    What is the max ide drive size supported by 7VM333M-RZ mobo?
    Also can it work with usb converter?
  • 2,351 Answers
Bummer I couldn't even find that MB on Gigabyte's site, however a more to the point question for you would be: Are you going to use a XP operating system? If yes than down load the drive's Mfg disk software. Usally you can than creat a boot disk to setup your drive. Pay attention to the jumper settings listed on the drive. If its a PATA drive = serial ATA-133/66/33 you will need to set the jumper for a master or slave or master with a slave. If its a SATA and your board supports SATA II you will need to remove the jumper to allow up 3.0gig transfer rates. If your board does not support SATA II than leave the jumper on. If your board does not support SATA I = 1.5gig tranfer rate, than you can not use this in your system.
Posted on Dec 04, 2007
  • Mike Peluso
    Mike Peluso Dec 05, 2007
    To the point. Yes it will support 320gb drive:
  • Mike Peluso
    Mike Peluso Jan 13, 2008
    Its people like you who need some time alone. Got a wee bit too much information. Should have known you were simple minded. Yeah! my bad. Silly me. As long as ppl like you are around the world will always be looking for free.. H.A.D.
Mthr brd FC-GB/ 7VM333M-RZ not working ???
you want to take an format cd an insert it and format the full system and install an windows xp pro as ur operating system and put an 1 gb ram in it
Mar 30, 2012 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Machine boots gives a startup beep then blue dump which fades to black screeen.
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
test or replace all the leads that attach to your hard drive make sure the connections are secure including electrical extensions + IDE,SATA the ones that attach from your
((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Mar 19, 2011 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Will this motherboard support 250 gb harddrive ide seagate
is it SATA? it shouldn't have a problem with hard drives unless the plugs are different. if the HDD is sata and you got a sata connection on your motherboard then you're all set
Feb 21, 2010 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
P4m80-m4 mobo not detecting SATA hard drive
go to bios setup,thn go to advncd settings thn u have to change the settings for hdd from ide to sata mode
Jul 23, 2009 | Seagate Barracuda 7200.10 320 GB SATA Hard...
How to detect two IDE drives with same brand
You need to set one of the drives to be 'master' and the other to be 'slave'.
This is done by positioning jumpers on the back of the harddrives.
Pretty sure that on the drives is explained somewhere how to position the jumper, for several options.
Good luck,
Please post some feedback.
Apr 23, 2008 | Dell OptiPlex GX280 PC Desktop
Mother board problem
need more info. ? have you tred other drivs. ?
Jan 07, 2008 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Hard disk
This will help you.
Dec 28, 2007 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Upgradation for vista
Gigabyte 7VM333M-RZ - motherboard - micro ATX - KM266
There is a cool way to find out just what it takes to run Vista on your current system. Download and run MS Windows Vista Hardware Assessment. It will help you prepare and suggest just what you need to upgrade either hardware or software. Make it simple! Download below.
Dec 11, 2007 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Hdd installation
The capacity that a motherboard can support is designated by the BIOS.... a few years ago when HDDs started to get big, there was an issue in supporting disks above 137GB as this exhausted the old HDD addressing system..(BIOS), to rectify this the BIOS code was re-written to support 48bit LBA (Logical block addresses) so as long as you have up to date BIOS for this motherboard, it should be alright.
you should be able to install any capacity available on IDE as long as you have updated the BIOS to the latest version (check the Giga byte website to download this)
If you wish to upgrade your PC further you can get a SATA/PATA adapter, or you can get a PCI SATA, IDE or SCSI controller card. Effectively there are very few limitations to the number of disks nowadays.
Dec 05, 2007 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Gigabyte 7VM333M-RZ (GA-7VM333M-RZ) Motherboard Logo
122 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
