Hdd data back
Once i suddenly lost power from ups and the whole system gets shutdown,when i restarts it shows data read error even i was not able to install win xp again what to do?please help me.i ve some imp. data with it.
model: WD800BB
I got messagewhile installing xp "setup cannot access this disk"
what to do plz suggest me?
Posted on Dec 12, 2007
  • 70 Answers
Hey... whats the error message you are getting when trying to installl Win XP...
Posted on Dec 05, 2007
    Champion:
  • 209 Answers
Setup your operating system thru repair, how? install your winxp by pressing the repair instead of INSTALL NEW FRESH WINXP. in this way you can recover the corrupted parts of the operating system. don not reformat. i hope that this will help you and i am expecting a positive response from you.
My Hp compaq PC showing problem about HDD - Disk Read Error . But This HDD was run very good to another PC ?
Test all leads that attach to your hard drive power and data cables IDE SATA the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty Make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty. Computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error. Even something as small as a faulty electrical or fan lead can cause you problems Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail. b> 1: Download a disk read error repair tool,install this error repair tool.
2: Open disk read error repair tool and scan you computer for free
3: Then click the Repair All Button again and your done! It is very easy to repair disk read error.
Here are the url of disk read error repair tool:http://www.RepairErrorInstantly.com/ttfi... or rather than doing this try the alternative which is windows own repair Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice Select safe mode with networking to download http://www.RepairErrorInstantly.com/ttfi... Then restart again into safe mode with command prompt. Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer Hope this helps. b>
Jan 05, 2013 | HP Compaq dc7700 PC Desktop
Tip
CARRIER WINDOW ELECTRONIC CONTROL
CONTROL PANEL ERROR CODE
PROBLEM
REMEDY
E4
Thermistor problem
Shutdown unit and restart
E3
Unrecoverable of E2RAM data
Shutdown and unit and restart
E2
Loss or corruption of stored data
Using remote control go to Cool mode and shutdown the system, and then restart.
E1
Code validation check fail
Shutdown and unit and restart.
FL
Filter check warning
Press the “MODE” and (DOWN) “▼” buttons together until error code disappear.
Note: If the problem persist replacement of control board is needed.
-Push arrow up and arrow down together for 5sec. the room temp. will show.
on Mar 02, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
I have a Iomega LPHD120-U, it was working fine but in the middle of a program a msg saying content lost popped up and since then the hadr drive doesnt open up. on connection it the green light appears for...
You might try opening it up and seeing if you can pull the HDD and put it in your PC as an auxiliary drive. If it works, the interface or power supply was bad.
If it's intermittent, get all the data off it ASAP, because you'll probably not going to get much use out of it.
Apr 07, 2017 | Iomega 1TB Desktop USB 2.0 Hard Drive
Drive is not ready to be read ?Error Check/device/harddisk1/DR7 ?
if you external hdd do not show on other computers, usually it meant that power supply on these casings die... but in this particular case it is possible that power supplied by usb port is insufficient to support data transfer. connect recommended power supply (on the back of this particular model you have usb plug and power plug, power supply is/was sold separately) usually hdd inside is still fine and retain data.
if this did not solve your problem, i would suggest purchase little powered universal hdd craddle, they cost about $15 to $25, remove, hdd from casing and connect to the craddle. data should be then accessible directly from your usb port.
as long as hdd is turning, data is accessible and recoverable, even if disk was wiped off.
Jul 20, 2010 | LaCie Design by F. A. Porsche 160 GB Hard...
Computer suddenly shut down and won't restart
This type of shutdown problem occurs mainly due to following few reasons, 1) SMPS problem 2) RAM failure 3) Over heated mother board chip(s) or seldom over heated CPU 4) Virus or worm problem or OS problem. 5) Over heated power cords
Do the following steps one by one (to detect the exact source of problem) First replace the CMOS battery, change SMPS, check power cord, run the PC directly (without UPS), remove the data cable from hdd. if it runs well then set the data cable with hdd, if it does not work then definitely there is mother board/cpu problem. And if it creates same problem after fitting the data cable - change the hdd or format hdd and reinstall os. your problem would be solved.
Jun 05, 2010 | Gateway GT5465E Refurbished Intel Desktop...
No main menu, just wavy lines with sony entertainment
This is a hard reset of the system, used when there is a catastrophic error etc. I have trawled these kind of sights and the main concensus is to ensure you have a back up of all important data. I experienced the same issue but the method above was advised by my games shop.
Nov 03, 2008 | Sony Playstation 3 (PS3) Console
Ps3 update 2.5
This is a major problem caused by this update, some wont read discs, other wont load the menus. Consult the Sony website for updates or solutions but a popular solution is to enter recovery mode on the ps3, which restarts ps3 totally but formats the ps3, losing data. If you think this is viable, i have linked to the process but here it is:
Turn off Ps3
Hold the power button down; the system will turn on and turn off once again
Once the system has been shutdown, re-press your finger until you hear dual beeps
When you hear the 2 beeps remove finger power button
You will be asked to plug in your controller and press the ps button
This will enter recovery menu, which is:
Recovery menu
- restart system
- restore default settings
- restore file system
- rebuild database
- restore ps3
- system update
Each setting does a different function, consult the manual or PS3 site for consequences but be warned: YOU RISK LOSING ALL DATA IF YOU DO THIS. BACK IT UP. This is not a proven fix for this issue as it is the update which seems to have totalled many PS3's but has proven effective and worked when my discs stuck on title screens, i selected first restart system, then restore default settings the 2 times i have done it and it fixed the ps3 but i lost all of my data.
Nov 03, 2008 | Video Game Consoles & Games
Problem with booting my device
seems your file system was corrupted. try to boot your laptop through cd..installation would show the partition details. here just check all partition are in gud file system. if it shows like "unknown" u need to format the partition. if u have any important data in that partition just connect that hdd as a secondary disk and try to copy the data's
Jul 24, 2008 | Microsoft Computers & Internet
Computers & Internet Logo
200 people viewed this question
Alun Cox
David Payne
David Payne
