Question about Gateway FPD2275W LCD Monitor
SCREENSIZE OF LG MONITOR
SIR,
MY MONITOR WAS ONCE NOT STARTING ONCE THEREFORE I REMOVED ITS WIRE FROM CPU AND THAN PLUGGED IT AGAIN. THE MONITOR TURNED ON BUT THE WIDTH DECREASED VERY MUCH THAN I AGAIN DID THE SAME THING AND THAN THE WIDTH SIZE INCREASED AND NOW IT IS NOT BECOMING NORMAL
  • 81 Answers
As the Lemmor and the STP162 saying the good solution....
If u still needs more solution then try this....
Open the monitor and resolder vertical section of the monitor coz your monitors vertical section is dry solder but make sure that u don’t touch the near point which is their by so it your solder is touch another so monitor may damage ….
Other wise go to Repairer and tell him that vertical section having the problem needs to resolder…
Best Luck..
Posted on Dec 06, 2007
    Scholar:
  • 132 Answers
Have you tried changing the resolution? right click anywhere on your desktop, except on an icon>>>go to properties>>>go to setting>>>use the slider-bar on the left to change it to 1024X768 it APPLY and then OK. See if that makes a difference.
Posted on Dec 05, 2007
  • 749 Answers
Open your monitor and try to resolder!!! resolder all connections of electronic components with small cracks!
or have it sent to a repair shop if you have no experience in doing it!
I bought a LG Flatron E2240 Monitor & added a new graphics card & it keeps freezing the arrow doesn't move
sir i think it'll be nice if u remove the new graphics card from the PCI slot ... then it''ll play in the normal default graphics now u uninstall the software driver of ur graphic card then insert back it again and once again install the software with care... all will be fine ... there is no problem with the monitor sir ...:)
Sep 04, 2011 | Computers & Internet
S24a300b problem, not detected by pc. message on display say "check signal cable".
Check signal cable means that your monitor wire is not connected properly.
So remove your cable connect it tightly once again.
Tightly connect with cpu and power supply.
Thanks for using fixya
Aug 19, 2011 | Samsung S24A300B Monitor
All the cable are connected correctly and power turned on, but when i start the computer, the computer itself seems to come on ok, but when i turn the screen on it says 'power saving mode' and seems to go...
Does your PC has plugged in video card, you can try reseating it first? If it has integrated video card in the mother board, then there may be not much you can do.
Did you install any new software or update any drivers?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Dec 19, 2010 | LG W1934S-BN 19" Monitor
SIR I have a lg 19 monitor having problem is
It sounds like the monitor is shutting down after you have it on for a 1/2 hour or hour, is that right? If so, and you can turn the monitor off and back on, and it's ok again, that means you probably have a temperature problem with some component in your monitor. It will have to be serviced and troubleshot to get it working again. You can use it the way you're doing now, and it will probably work like that until you can get it fixed. Make sure you get an estimate from a repair shop first, because often the cost of repair can be almost as much or more than a new monitor. Good luck, and hope this helps.
May 13, 2010 | LG Flatron L1919S LCD Monitor
LG W1934S monitor. It displays an image for about 3 sec and goes black. It does not turn off but loses image. Unplug monitor cable and plug in again and the problem repeats. I tried "jiggling" plug but...
first you ensure that it is a problem with TFT or CPU. you can check it with another monitor. if it is working with another monitor then your TFT has been faulty.then you can repaired it from service center.
Nov 04, 2009 | LG W1934S-BN 19" Monitor
Monitor looks as if there is no CPU
If the power supply is coming to CPU before activation of CPU then it must be receiving current from UPS. Don't try unplugging, You may get shock. Thank you, Sir.
Sep 17, 2009 | Computers & Internet
L1932TQ Fails on Desktop, works on Notebook
it simply means that your cpu is not giving back signal to your monitor to process, in fact, it is a cpu problem that is why there is nothing to display in your monitor.
Your cpu froze because of that usb thing. the only way to unfreeze it is to manually reset your hardware in this order.
1. RAM modules. If you can unplug your RAM (memory modules) connected in your motherboard, please do it. Just unplug the modules and then plug it back in. if you have 2 rams, then interchange them when plugging it back. this will force your mobo to refresh its resources.
2. CPU. if you can pull out your cpu chip, then do it. this will refresh your cpu setting in your mobo. (mobo = motherboard)
Regards!
Jul 12, 2009 | LG L1932TQ LCD Monitor
Screensize of acer 5670 laptop
Yes the TV could have changed your screen settings (probably to 640X480 resolution).
Go to the Control Panel, then click on Display, then the Settings TAB, then change the Screen Resolution to at least 1024X768 pixels or higher to suit your requirements.
NOTE :- The higher the resolution the smaller Icons and text will be displayed also a lower color quality display ie the best is 32 bit color.
Jan 13, 2009 | Acer Aspire 5670 Notebook
Monitor screens doesn't stop
It is a compatibility issue. If you plug the monitor/tv into the PC after you boot the PC it should show fine and not hange.
Jan 07, 2009 | LG Flatron L1718S LCD Monitor
No signal from cpu
i think you should check if the sync wires are properly connected both on the db15 connector and the main board
Jan 30, 2007 | Samsung SyncMaster 753S 17" CRT Monitor
Gateway FPD2275W LCD Monitor Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
