Question about Avid Xpress DV 3.5 (0500-03677-01) for PC, Mac
NTSC DVD from QT files from PAL project in AVID
AM working on AVID EXPRESS DV .PRJECT in PAL... Outputted QT files,,, then compressed the QT files to MPEG 2 NTSC
Burned DVD...all successful...
Will this NTSC DVD work ?
0 characters
1 Points
Is "NTSC DVD HQ" Blueray?
Hi tomblasio
BluRay is the latest video technology on the market and has nothing to do with NTSC DVD HQ . First came VHS , followed by VCD ( video cd ) and later DVD ( digital video disc ) . NTSC is the standard manufacturer's technology in use mainly in the States and Japan . Europe generally uses PAL system .
Bluray discs produce superior image quality and offer 5x more stockage capacity than the dvd discs .
They are also the far more expensive than other products . DVD and BluRay are NOT compatible .
Best regards ,
fanaudi .
Aug 24, 2011 | Geeky Dads Software WinFX Free Video...
I bought serious magic visual communicator pro 2 on but the product key is not working. I called adobe and they said that I should ask for a refund. I am not sure that the seller will give me a...
Issue Activation fails when you attempt to install and launch a legacy Serious Magic product.
Reason Adobe has chosen not to renew the hosting account for the Serious Magic web site. The hosting contract expired on Nov. 3, 2008. Activation for Serious Magic products that rely on this server is no longer supported by Adobe. SolutionDo one of the following:
1. Upgrade to the latest Adobe-branded version of the product.Note: DV Rack is now Adobe OnLocation. The most recent version of Adobe Ultra was Ultra CS3. Ultra was not included in CS4, however, color keying is available in After Effects CS4. A tutorial on basic color keying is available here.
2. Download and run the Serious Magic legacy product activation tool.Instructions for SMActivate.exe:
  1. Extract the .zip file to a convenient location.
  2. Double-click SMActivate.exe. The application will display a list of Serious Magic products to be activated.
  3. Click OK.
Your product is now activated and ready to use. If no qualifying products are detected, it will display the message: "No legacy Serious Magic applications detected."
This change affects the following Serious Magic products:
  • Ultra NTSC VxxV
  • Ultra PAL XxxX
  • Ultra 2 PAL BPWB
  • Ultra 2 NTSC BNWB
  • Visual Communicator 1 Studio SxxS or TxxT
  • Visual Communicator 2.0 CxBC
  • Visual Communicator 2.0 Web CxWC
  • Visual Communicator 2.0 Pro CxPC or CxQC
  • Visual Communicator 2.0 Studio CxSC or CxTC
  • DV Rack DxxD
DV Rack Express requires a special version of the activation tool, available here. This affects the following Serious Magic product:
  • DV Rack Express FxxF
For DV Rack Express, do the following:
  3. Select the checkbox for DV Rack Express.
  4. Click Activate. This will create a file, smact21.db, in the C: root.
  5. Move that file to c:\program files\serious magic\dv rack express\bin
The following Serious Magic products do not use activation, or use alternative activation and are not affected:
  • DV Rack 2.0*
  • Ovation
  • VlogIt!
* DV Rack 2.0 uses activation through a third party company named Softwrap, which resides on a server that is not affected.
Note: Ultra CS3 is an Adobe product and is not affected.
Dec 21, 2010 | Serious Magic Visual Communicator 2 Studio...
I am a Pinnacle Studio user
Avid is a complete different animal. The logic is backwards from Pinnacle or premiere. If you're used to those, Avid will seem like a forgeign language. Also, projects aren't compatible with Avid.
Dec 30, 2009 | Pinnacle Avid Liquid Version 7 for PC
Avid media composer with windows7
no need it will definitely work on windows 7. because it has xp mode that run all the xp compatible applications in windows 7. u know that windows 7 is really amzing.....
Aug 26, 2009 | Avid Xpress Pro 4.8.1 Full Version for PC,...
Video and audio lose sync when disc is burned
If your video and audio is out of sync you need to repeat burned to your dvd disc again.
Insert your blank DVD disc and then after that do this.
Click on start button of your Studio>video and audio preferences>uncheck background rendering>check used this codec for background rendering>check the pull down arrow and choose MPEG2 for best out put tot disc. Click on prject preferences>look for delete button click it then delete aux file for all project then click okay. You may now try to burned to disc again.
Jun 01, 2009 | Pinnacle Studio Plus Version 11
Techincal solution
Do you mean .omf and .mxf? On mac the souce files are quicktime. Audio, generally works with .aff the best but can use .wav also. Though that message seems to suggest it is an audio card problem. I'd check if you can record in other sofware programmes and maybe if you have an on board sound card as well as an external one (if using PC) turn the on-board on off in MSDos as it could be conflicting.
Mar 31, 2009 | Avid Xpress DV 3.5 (0500-03677-01) for PC,...
''Jerky'' play on Adobe Premiere Pro CS4
Try maxing out your temp file storage from within the options in the program. Also does the file play jerky when compiled as a finished file. Using an external player. When the file is played or previewed from within the app it was created, with the GUI loaded and possibly the file not being saved, the amount of memory consumed is exponentially increased.
Mar 08, 2009 | Graphics Publishing, Design & Multimedia...
Video + audio out of sync with Sony Vegas Movie Studio
Hey guys,
i tried something which worked...but i dont know if this is solution for all video formats....
Unlink the audio layer from video...and delete the audio layer.
Use any program to extract the audio from the video file - i extracted it as a WAV file.
import the wav file as the audio layer....
and render....
the output was alright...
but now i am facing another problem! :( Vegas closes without any warnings during rendering....
hope this was useful....
Sep 27, 2008 | Graphics Publishing, Design & Multimedia...
Avid Xpress DV 3.5 (0500-03677-01) for PC, Mac Logo
22 people viewed this question
Top Avid Graphics Publishing, Design & Multimedia Software Experts
Are you an Avid Graphics Publishing, Design and Multimedia Software Expert? Answer questions, earn points and help others
