Question about Gateway FPD2275W LCD Monitor
Samsung monitor problem
I have samsung 56v monitor. the monitor does not turn on when i press power switch . But when I repeatedly press power switch ,at some instance it turns on.
  • 3 more comments
  • suhas2001 Dec 07, 2007
    There is no problem in switch my dear friend DRSS
  • Anonymous Dec 25, 2007
    In this problem I change 5v regulator ic .problem solved. Dilip
  • apsin Jan 04, 2008
    I have the exactly same problem with my SAMSUNG 56V monitor as Suhas. Any help is welcome
  • suhas2001 Jan 20, 2008
    Hi friends
    Many thanks for your solution.My problem is solved now.Hope that you will continue to give such guidence.Thanks again
    - Suhas
  • Anonymous Mar 06, 2008
    my screen dasent show any thing in one ench on the botoome of the scren
    samsung 720n
Dear friend,
this problem is not power switch because this problem creates LM7805 ic because its take 5 volt if volt 4 or 6 after then this problem will.So you can replace this ic.If this problem is not solve after then you replace the micro proccesser ic DM024.finally this problem will solve because i solved this problem last week.
Posted on Jan 16, 2008
In This problem I change 5 volt Regulator Ic This problem solved. dilip
Posted on Dec 25, 2007
  • 81 Answers
Dude u knows the repairing part of the monitor or u knows the basic electronics…
You need to do one thing that is open the CRT i.e. Monitor and after that remove the On/OFF switch u can open the switch and clean it ….
Replace the switch by new one….
Posted on Dec 06, 2007
  • DRSS..
    DRSS.. Dec 07, 2007
    If You are right then this must be the Power supply section problem low current when pressing the switch?
    their is one regulater in power supply section so you need to concentrate on the POWER SUPPLY SECTION!!!
Samtron 56v pc monitor video background with gray vertical lines
How to Tell If A Computer Monitor Is Going Bad
Computer monitors are designed to work properly for years.
Whether it's from a defective part or power surge, they go bad eventually, and you'll probably know it when it happens.
Look for vertical or horizontal lines across your monitor screen that shouldn't be there.
Time how long it takes for your computer monitor to come out of sleep mode. It shouldn't take more than 5 or 10 seconds for the screen to be fully operational when taken out of sleep mode or turned on after being turned off. If the screen is not operating as quickly as it should, it could be a sign it's getting old.
Read more :
How to Tell If Computer Monitor Is Going Bad eHow
Oct 13, 2015 | Samsung SAMTRON 56E/57E/56V
I am using samtron 56v monitor since 10 years, since 6 months I am facing problem in switching on the monitor, i have to press the knob or fix some packing to knob how to solve other wise mointor is w
Sounds like the power On/Off switch has been damaged. Replace it. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
Jun 09, 2014 | SAMTRON 55V 15" CRT Monitor
Samsung samtron monitor does not work
Please check whether the power cable is properly inserted...
The power button of this model fails with time.You need 2 press it tightly and hold it till the LED is on....
try this...
Hope this helped...
Dec 21, 2009 | SAMTRON 55V 15" CRT Monitor
Samsung 56V, difficult to switch on the monitor
check the capacitors inside the monitor, as they may be broken, and they start screen up, just change em and it should kickstart fine
Sep 19, 2009 | SAMTRON 55V 15" CRT Monitor
Control Lock Issue in Samtron 56V
d problem is in a transistor costing little, situated near d monitor's osd control ic (microprocessor), it is probably short....[refer the connection n area around the front panel cn connector and crystal clock generator]..beware u must b a professional
Jul 12, 2009 | SAMTRON 55V 15" CRT Monitor
In my SAMTRON 56V monitor problem
my samtron 56v problem stand by when i power off yet i power on it is off position whats problem with me.switch is many time pressing then is on position.what is parts of my monitr suplly fault.wich part is spoil
Jul 02, 2009 | SAMTRON 78DF 17" CRT Monitor
Samtron 56v monitor control is locked
To unlock your monitor, Press and hold the Menu button for 5 - 10 sec. and the OSD menu should be released.
May 27, 2009 | SAMTRON 55V 15" CRT Monitor
Samtron 56v monitor
HI all,
The problem im facing is, im using a Samsung samtrong 56V monitor, there is horizontal line appearing in the both ends of the monitor screen which gives a mirroring effect. ( for ex: if ya move the cursor on that it will show multiples of cursors displayed in that line only.)
Please suggest me a method to solve this issue. are there any patch avail for this if so please send a link to download.
thanks a lot
Jan 10, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Samtron 56v
change the 5v regulator 7805 which is the supply for microprocesor
Aug 26, 2007 | SAMTRON 55V 15" CRT Monitor
SAMSUNG 56V Monitor
If this behavior is relatively consistent, I would suspect the "mains capacitor", an electrolytic cap on the output of the AC bridge. If vibration affects behavior you may have cold solder joint(s) in the SMPS circuit. Knowing what current the monitor is drawing at turn on would be helpful.
Aug 13, 2006 | SAMTRON 55V 15" CRT Monitor
Gateway FPD2275W LCD Monitor Logo
153 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
