Question about Twinhead SlimNote N12PI Notebook PC
Twinhead 12D Laptop
How to open twinhead laptop 12D casing ?
  • 4 more comments
  • starcity Dec 04, 2007
    All screws already removed, but seem one thing holding the casing from opening. Btw, do I need to dismantle the lcd sreen first ? tqvm
  • Anonymous Dec 11, 2007
    add ram
  • AndyHat Jan 06, 2008
    I have a Philips Freevents X51 which I think is a rebadged Twinhead slimnote Twinhead F12DT Twinhead F12DT N12PI . Wehave removed all screws but it still will not open to let us open the case to fix a failure to boot up. It is as if there is still something preventing it open.
    Any help greatly appreciated!
    Andrew
  • Anonymous Feb 26, 2008
    keyboard not function
    keyboard not funstion
  • wai2001 Jan 29, 2009
    Am having similar problem, still stuck, even all screws at the bottom has been removed. It seem that there is a catch in-between the IEEE connector and lip of keyboard.
    Do anyone know the solution? I need to access into the motherboard and check on the condition of video card... Rgd / Dan.
Are you sure you have all the screws out, there is a small plastic disc on the bottom of the laptop underneath the card slot, this needs to be removed to access a screw (obviously take out plastic blank in slot first).
And there is not much reason to dismantle LCD either.
What is it you are trying to do.
Posted on Jan 15, 2008
Apart from all the visible screws in the bottom, there are some below the keyboard. You need to remove the keyboard, it is held on its upper side by 5 plastic tabs that you can pry apart with a thin blade.
After removing these screws, you can open tha case but be careful of the touchpad cable.
Posted on Jul 20, 2009
I have a freevents X62. To open the case, you also need to pull out the DVD tray. Pull it fully out and you will see two small screws that hold the CD to the top half of the laptop clam shell. Remove these, THEN pull out the complete DVD 2 cm or so. This removes the DVD connector from the laptop. (You'ss see what's going on onc you're inside.) The shell should then come apart if you've removed all the rest of the screws. (No need to remove the screws within the LCD panel.)
Posted on Feb 29, 2008
  • redvoler Jun 10, 2009
    I have a freevents X62. (VERY SIMILAR TO TWINHEAD, I BELIEVE) To open the case, you also need to pull out the DVD tray. Pull it fully out and you will see two small screws that hold the CD to the top half of the laptop **** shell. Remove these, THEN pull out the complete DVD 2 cm or so. This removes the DVD connector from the laptop. (You'll see what's going on once you're inside.) The shell should then come apart if you've removed all the rest of the screws. (No need to remove the screws within the LCD panel.)
    HOWEVER... be very careful if you try to prise the motherboard away from the casing - there's a small ribbon cable connecting the touchpad to the motherboard. I'm STILL trying to reconnect that.
Hello, I had the same problem with my x50.
Could not figure it out and the remaining screws that were holding it were underneath the keyboard.
Popped the keyboard out, undid the screws and voila, the case opens enough to do things.
Posted on Nov 08, 2008
I have succesfully taken my x51 apart several times to upgrade parts, there is the screw under the card slot you need to remember and you need to take the screen off. To really get into things there are screws under the keyboard too, the keyboard just clicks right off.
Posted on Feb 09, 2008
    Problem Solver:
  • 23 Answers
Disassembling the LCD is the first thing u must do when takin apart a LAPTOP...
Posted on Dec 04, 2007
  • Micheal Richards Dec 04, 2007
    MAKE SURE THE POWER PACK IS OUT ALSO OK...
Need drivers for Twinhead DURABOOK S14Y
The drivers for your product can be found at: http://www.gammatechusa.com/CSD/download.php?model_id=d14ry
Jun 17, 2011 | Twinhead DURABOOK D14RY
PLS HELP!!! i forgot my bios password.. i could not re format my twinhead E-10 notebook...anymore.. thnx very much
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Feb 09, 2011 | Twinhead (N14PBC15TK20XGB) PC Notebook
Hello, I have a twinhead 12D laptop, its much like the US model N12PI. I would very much like to increase the 512KB of memory I have in it now. The main problem I am having is How do I open the case. I...
sometimes there is a slide lock next to the hatch...
sometimes they hide screws under stickers, its an easy way to varify that the user didnt open the case. use a phillips on that inconspicuos round sticker.
Jun 11, 2010 | Twinhead SlimNote N12PI Notebook PC
How much memory will the N14R1 accept and what are the specs
you can get the specs and a repair manual athe the manufacturers website
Feb 15, 2010 | Twinhead DURABOOK Ruggedized Laptop...
I have a philips freevents 12nb5800 laptop and the keyboard doesnt work properly. Some keys dont work and some only work intermittently
The Philips Freevents 12nb5800 is actually a Twinhead J12S
The XP drivers are hard to find but they are on the Twinhead Austrailia website here;
http://www.twinhead.com.au/downloads.asp?MainCategory=J12S
I installed the intel VGA driver from this which allowed we to use two screens.
Jan 11, 2010 | Computers & Internet
Broken DC in Jack
I agree, the best option is most likely a motherboard replacement.
You can search Ebay, there are several places that advertise DC power jack repair, But from my experience, repair is an iffy proposition.
Jul 07, 2008 | Twinhead SlimNote N12PI Notebook PC
VIDEO CARD DRIVER FOR TWINHEAD A5010
http://ruggednotebooks.com/support.asp
Jan 09, 2008 | Computers & Internet
Open Questions:
Twinhead SlimNote N12PI Notebook PC Logo
3,540 people viewed this question
Top Twinhead Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Alun Cox
Computer Links
Are you a Twinhead Computer and Internet Expert? Answer questions, earn points and help others
