Question about Zenith ZPA-314 Portable DVD Player
When playing dvd the screen has fuzzy horizontal lines on the picture?
  • jamco73 Dec 04, 2007
    Im using a Zenith Portable Dvd Player model # ZPA-314.
  • Erik Granroth
    Erik Granroth Jul 15, 2008
    I am having the same issue. It worked fine for a while and now I get fuzzy horizontal lines. Audio is good but not picture.
Fuzzy Display in bottom 2/3 of screen
Power supply is probably going out. Not likely the video card in this case.
Nov 18, 2012 | Viore " 24"" Class - LED - 1080p - 60Hz -...
I have owned an emerson tv for two years now. All of a sudden the picture has become very blurry and white. It is not the cable connection and a DVD is also white and blurry. Even the input channels are...
you must open the back cover of tv, and then things you should do is set "SCREEN" adjustment on the flyback transformer. you must turn it counterclockwise to reduce and decrease the level of screen brightness. turn screen adjustment gradually until the horizontal blanking lines disappear from the screen. and blurred images will be sharp again
Aug 11, 2010 | Emerson EWF2004 20" TV
TV shows on half screen. other half fuzzy
You have some cold solder joints on the PC board. Flux and re-flow all of the electrolytic capacitors connections..
Aug 29, 2009 | Televison & Video
Red vertical lines and horizontal flashing lines on viewing screen plus fuzzy picture.
Its bad ccd imager problem in your Sony DSC-T1 camera and Sony will repair it free of cost.
Click Sony CCD Imager Support for details.
May 02, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Toshiba 32" tv wont give sharp picture (other tv does)
try to replace filter capacitor from power supply and in horizontal section.
Jan 26, 2009 | Toshiba 36A50 36" TV
Panasonic DMR-EZ47V Fuzzy horizontal line in VHS mode
Dirty heads or the recording was from a different brand VCR and the Panasonic cant get the right tracking. Try manual tracking just a little in either direction to you get the right one.
May 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Line in picture
Send me a Digi-pic of the screen please.. Good starting point..
ken@ikenfixit.com
Jan 09, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Interlaced comes in fuzzy & with lines
you need to check if the dvd or games are doing the same thing on different inputs. if they have the same problems you might be looking at the single board or the focus block.
Dec 01, 2007 | Akai PT5598HD 55" Rear Projection...
Video input
Needs Hyper board repair = replace bad caps
PCB not available to buy outright........................T.
Nov 10, 2007 | Toshiba 42H81 42" Rear Projection...
Zenith ZPA-314 Portable DVD Player Logo
78 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
