Question about Compaq Presario 5000 PC Desktop
Hot flashing i have two mother boards, one has a plcc flash socket and the other dil flash socket. i want to flash the dil socket memory using the plcc motherboard. need pin connection to adapt the dil eeprom to the plcc socket. i have data sheets but haven't been able to figure out 5 connections .need help to continue the project. any other suggestions not requiredthankssudhir paul dsudhirpaul_dhawale@yahoo.com
    Prodigy:
    An expert who has answered 500 questions.
  • 620 Answers
Good day sdpd
WEll, is time to buy the adapter, you have to e-mail the DIL Flash motherboard manufacturer for this, or try to get one on Radio Shack.
Posted on Dec 05, 2007
ThinkCentre model A2U; type 3429, s/n MJFEW89, power button slowly flashes, optical drive light flashes 1 short, 1 long every 4 seconds; fan not running; lcd is blank
ThinkCentre Desktops are very picky about installation of every part. (Your replacement RAM was probably too fast, such as 1600 instead of 1333.) Also, the long product ID numbers on the RAM chips must match.
First, WITH POWER DISCONNECTED, ensure the RAM is seated properly. If the RAM sticks are different brands, switch them in the RAM sockets. If you have 4 sockets, socket 0 (is the first socket) is nearest the processor socket.
OR
Remove the RAM and clean the gold fingers with a soft, lint free cloth. Then use compressed air to ensure no debris is removed from the RAM sockets on the mother board.
BobB
Dec 22, 2016 | Computers & Internet
I have a desktop with an amer megatrend bios.I want to get a new bios that works with win 8.1 and needs to have support for PAE,NX.and SSE2
It's best to simply replace the entire Mother Board than try to replace the BIOS. Replacing a Mother Board vs replacing a BIOS is way easier.
Your current BIOS MIGHT work if you can find a flash file for it, but you have to be careful. If the BIOS your flashing isn't in production it's usually only PATCH flash file, to fix a problem with a BIOS, not upgrade it. And if you use the wrong flash file, it will TRASH your BIOS!
The BIOS, which is a chip, is usually micro-soldered to the Mother Board with high precision, by a robotic arm, and not easily removed or duplicated. The exception is if you happen to have a BIOS chip, that can be replaced, in a socket, but this is unusual instead of common.
The best source for BIOS info such as you are looking for is the American Megatrends Website itself at: AMI American Megatrends Inc Aptio (compatible with Windows 8) however their website is for the Mother Board manufacturer so you can't buy the BIOS as a consumer, but through a reseller, AMI Office, Authorized Representatives, etc (AMI American Megatrends Inc How to Buy).
You can however, buy a replacement Mother Board with a BIOS already installed on it (that's the way you usually buy them - with the BIOS pre-installed on the Mother Board) that's PAE, NX, and SSE2 and whatever else you want compatible. A great website to find computer parts and kits, new, refurbished, out of box, etc is the Tiger Direct Website at: TigerDirect com Electronics Tablets Phones Office Supplies Video Games. Just search for BIOS to find your specs, then check the bottom for possible best Mother Board kits to replace the one you have now. Hope this helps. :-)
Mar 03, 2014 | Computers & Internet
Temp light flashes and then shuts down
hi,
possiblely it is the problem of fan, try to check the radiator fan port.
later use the machine, shut off it, until the lamp fully cool.
regards
Jack
WHOLESALER AND RETAILER FOR BELOW PRODUCTS:
projector color wheel, lens and bulb, remote, lamp power, mother board. all brand and most of model.
computer mother board, memory, harddisk,
HP server, switch, and router.
Nov 21, 2011 | Optoma MovieTime DV10 Multimedia Projector
I have a toshiba LT a205; the LED flashes 6x; what does that mean? the psu is rated at 19vdc, and puts out 18.5 vdc. The end of the power connector that goes to the mb only has 0.5 vdc on it, so I'm...
19volts is a nominal value. The AC Adapter will be fine from 18 volts up to 20volts because the power unit on the motherboard regulates the voltages very accurately.
You say you only have 0,5volts on the Mother Board power input. There's your fault. Between the Mother Board socket and the AC Adapter.
Replace the AC Adapter or Laptop Connection lead if you mean there is 0.5volts actually on the Mother Board but full oiutput from the Adapter.
Dec 15, 2010 | Toshiba Satellite A205-S4777 Notebook
I bought new HP p6000 Series Desktop computer where the driver is not reading Cruzer or any flash drive. What to do.
look on the back of your computer for a hi speed usb port, or just use any back usb port. some computers like mine dont have a "bus" to the mother board to the front usbs or because they are piggy backed to the front they dont pass through.
Oct 10, 2010 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Can't boot, stops right after mem test but before access to setup suspect BIOS chip It's in PLCC socket, need replacement for test thanks
does the post give a audio code before the boot stops..? the plcc chip can be purchased from the manufacturer if they are still available. Does the post stop after the mem test or during..? if during, try replacing or refitting the ram sticks. You could even remove the ram sticks and see if the post continues or if you receive a beep code.if you get a beep code, go to manufacturers website for beep code info. Have you tried to reset the bios. most boards can recover from a bios failure, the boards manual will tell you how to do this if the board supports it. If the plcc has failed, replacing the board may be cheaper and free of hassles. Replacing the plcc is a pain as you must get the correct bios installed. Are you getting the video bios details on the screen ? if no, try another video card. If you are using an on board video chip, try a video expansion card, either AGP or PCIE type, whichever the board supports. If the board only has PCI or AGP, replace the board as it will not have the features for modern software and you will probably not be able to replace the plcc.
Oct 30, 2009 | Abit IC7-G Motherboard
No display; flash busy message is in view finder; new battery
I had the same problem, camera is only 5 months old and still under warrenty. I sent it into cannon for repair...mother board was shot...new board installed...have used the camera 2 times since getting it back...camera has died on me again...same problem. Have to send it back again! Don't recommend this camera to anyone!
Jun 23, 2009 | Canon EOS Rebel XS 35mm SLR Camera
I also have a boot problem with this Mother board (asus p5vd2-vm)
Check for bent pins in the PS2 connector of both keyboard and Mouse jacks. Replace Keyboard with a working one, & The mouse too if possible and retry.............sodeep
Jun 07, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
I want to upgrade my HP BA 600 Mother Board`s RAM Capacity
Most likely your MB is too old for this upgrade although there is a chance you could flash your bios (reprogram your computer's brain to accept the new memory providing hp has a flash for it).
here is a link for the latest bios flash for your computer, use at your own risk.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=32895&swItem=vc3903en&prodNameId=20305&swEnvOID=54&swLang=13&taskId=135&mode=4&idx=0
good luck.
Thank you,
agadycom
Nov 27, 2008 | HP Computers & Internet
Nc6000
Have you tried attaching an external monitor and using the <FN> key with the F? key (mine is F5) to toggle between internal and external video?
If still nothing download latest Bios update and try to flash to that.(if you don't have a multi-bay floppy drive you may have to invest in a USB floppy.
or Try ebay for parts
May 10, 2008 | HP Compaq nc6000 Notebook
Compaq Presario 5000 PC Desktop Logo
65 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
