Question about HP OfficeJet 6110 All-In-One InkJet Printer
Hp officejet 6110 malfunctioning
When the printer is switched on, paper jam signal comes even without any paper in the tray.
  • 89 Answers
The paper sensor flag is probably stuck or broken. The part number is C7309-40013.
Posted on Dec 05, 2007
First check the sensor then from the printer maintenance, try to clean the roller.
Posted on Dec 09, 2007
HP 6110 Officejet all-in-one will not print from the glass top. It will make prints coming from the computer after I press "enter" from message "paper jam". I also can fax. Please help.
You will need to open the top and look inside where the paper travels through and attempt to free any paper pieces that have gotten stuck in the pathway. You probably have a bad board in your control panel, since you are able to print from the computer.
Feb 20, 2013 | HP OfficeJet 6110 All-In-One InkJet...
Have a HP Laserjet 2840..error reads "paper jam tray 1" there is no paper jam I can find. Help !!!
There are paper sensing switches above the paper tray. Most likely the actuator has fallen out .
Mar 30, 2010 | Xerox Phaser 6110 Laser Printer
Hp printers continue to jam
Print a self-test report Use the following steps to print a self-test report.
  1. Load plain white paper in the input tray.
  2. Press Setup , and then press 2 . The Print Report menu displays.
  3. Press 1 to select and print a Self-Test Report .
IMPORTANT! Try to print a self-test report after every solution even if the solution resolves the issue. Solution one: Clear the paper jam Follow these steps in the order presented to resolve the paper jam. Step one: Remove loose paper from the tray Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism
Sep 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
MY HP officejet 6110 says it has a paper jam.
its the problem of the sensor which detects the paper inthe printer,that sensor is moved from its position and so this problem.
Dec 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Copy problem
try cleaning the pickup rollers and seperation pad with oil like WD40 or even acetone, thiswill probably help. If not, you have a blue plastic strip behind the roller mechanism. Remove this strip and make sure that no paper or staples etc are jammed there.
May 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
136 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
