Question about Adobe Photoshop 7.0 for PC
Illustrator I recover Illustrator files but I can't open them, i tried to open it in photoshop and acrobat but still it cant be open. I have a massage that it has been damaged. What can I do to repair them? Thank you ...
  • ronell porras Dec 22, 2007
    thanks a lot gothic angel for your expert advise, sorry i forgot to tell that the problem starts in brown-out, but as i remember i saved it before the brown out. do you think that's the cause of the damaged...
  • 233 Answers
Do you have them saved elsewhere as a back-up file?
If it is IMPORTANT to you, always back it up on another disk.
My Motto: Problems happen, try the simple solutions first.
Posted on Dec 05, 2007
My adobe illustrator image
This method considers acquiring Acrobat (not just the Reader) or you may solve the issue by recovery corrupt illustrator file
Works on (and was tested in) Illustrator version 10 and all CS versions.
>Open the corrupt file in Acrobat.
>Take the arrow tool.
>Click on any element or text in the document.
>Just move the object by hitting one of the directional arrows on your keyboard.
>File, Save.
>Open the file in Illustrator.
>It will say 'this file has been modified outside of Illustrator' or something to that effect. it will ask if you want to keep changes.
>Say 'Yes' (or OK)
Your file will open virtually intact!
This has worked when nothing else has... believe me it is painful to have to recreate a corrupt file....
Nov 29, 2017 | Adobe Computers & Internet
View content of Illustrator?
Download and test third-part software for recovery illustrator documents like a Illustrator Recovery Toolbox from
Please follow instructions if you if you want to try to recover the file itself. :
1. Check a size of file. If it smaller then 50K then projects are empty
2. Attempt to re-create files as describe here:
Sep 11, 2016 | Adobe Computers & Internet
How to repair illustrator file?
And also u can use the same program Illustrator Repair Toolbox
But with working link below:)
Dec 15, 2014 | Adobe Illustrator CS3 - Windows for PC...
Saved illustrator 10 file gets corrupted
Check for a damaged pattern, gradient, or custom color
To determine if the problem is caused by a damaged pattern, gradient, or custom color:
1. Choose Edit > Select All and change the fill and stroke to process black.
2. Perform task 4 again to determine whether the problem occurs in a new file that does not contain the patterns, gradients, or spot colors. If the problem does not recur, re-create the pattern, gradient, or spot color in the original file.
First option:
Second: shareware tool Illustrator Repair Kit
See more about:-
Oct 27, 2014 | Adobe Illustrator 10.0 for PC
Got CS2 running on PC under WinXP, and have been using quite happily for over 3 years. Recently the menu option File | Open Recent... shows an unchanging list of files, irrespective of which files I have...
Save your work and close Illustrator. Double click on My Computer on your desktop and open C:>Documents and Settings > User >Application Data > Adobe > Adobe Illustrator CS2 Settings. (Your version of Illustrator will be in the foldr name.) Inside this folder is a file called AIPrefs. Drag this file to the trash, and restart Illustrator. Reset any custom preferences you want, and when you close Illustrator the preferences file will be regenerated.
You can also reset Illustrator's preferences by holding down Shift + Control + Alt while launching the program. If you get a dialog asking if you want to delete the Adobe Illustrator settings folder, click yes to proceed. Restart Illustrator. Reset any custom preferences you want, and when you close Illustrator the preferences file will be regenerated.
Aug 27, 2010 | Adobe Photoshop CS2 for PC
Help me
Do you mean Adobe Illustrator? If you go to you can download a free trial version that works. If you mean that you want to open an Adobe file like *.psd for Photoshop, *.ai for Illustrator or Adobe *.pdf for Acrobat then you must have an application that can open that file which the aforementioned url will gladly provide. ~Steve Medley
Oct 13, 2008 | Computers & Internet
Illustrator to photoshop
Here is everything you will need. I hope you will find this worthy of a FixYa rating.
Import Illustrator CS2-CS3 artwork into Photoshop CS2-CS3
What's covered In Adobe Photoshop, you can import Adobe Illustrator artwork in several different ways, each of which offers a different level of control. When you open or place AI, EPS, or PDF files created by Illustrator, Photoshop rasterizes vector artwork and removes the ability to edit transparency, fonts, layers, and paths. To retain more control over imported Illustrator artwork, Adobe recommends that you drag or paste it into a Photoshop image or export it in Photoshop format.
Drag Illustrator artwork into Photoshop Dragging Illustrator artwork is the quickest way to import it into Photoshop. By default, Photoshop creates a new layer for the dragged artwork and imports the artwork as a Vector Smart Object. (For more information, see "Smart Objects" in the Photoshop Help.) You can import dragged vector artwork as a work path, however, by holding down Control (Windows) or Command (Mac OS) while dragging. To center imported artwork in the Photoshop image, hold down Shift while dragging.
Note: To import dragged type as a work path, you must first convert it to outlines in Illustrator. For more information, see "Modifying letterforms as graphic objects" in Illustrator Help.
Paste Illustrator artwork into Photoshop When you copy Illustrator artwork, you can paste it into Photoshop and retain many Illustrator features. To do so, however, you must properly configure Clipboard preferences in Illustrator.
The Illustrator Clipboard supports a variety of formats including: PICT, PDF, and AICB. Though Illustrator always copies PICT data to the clipboard, you can configure Illustrator so that it also copies PDF or AICB format. These two formats allow you to retain Illustrator features in artwork pasted in Photoshop. PDF retains Illustrator transparency, while AICB format retains Illustrator paths.
You should only select the AICB format by itself if you are going to be pasting paths in to Photoshop. In all other cases, select the PDF format or the PDF format in conjunction with AICB. The PDF format retains transparency and other features in Illustrator such as extended support for spot colors.
To configure Clipboard preferences in Illustrator:
  1. Choose Edit > Preferences > Files & Clipboard (Windows) or Illustrator > Preferences > Files & Clipboard (Mac OS X).
  2. In the Clipboard section, select the desired format.
  3. If you selected AICB, select either Preserve Paths or Preserve Appearance.
  4. Click OK.
Paste options in Photoshop
When you use the Paste command to import copied Illustrator artwork, Photoshop provides the following options in the Paste dialog box:
  • Paste as Smart Object: Pastes the art as a Vector Smart Object that can be scaled, transformed, or moved without degrading the image before it's placed into the Photoshop document. As the art is placed, its file data is embedded in the Photoshop document and the art is rasterized on a separate layer.
  • Paste as Pixels: Pastes the copied artwork in a new layer and rasterizes it at the resolution of the Photoshop image. Use this option when pasting raster objects.
    Note: When you use this option, clipping masks for raster images are not retained as paths. These masks still clip images, however.
  • Paste as Path: Pastes the copied artwork as a work path.
  • Paste as Shape Layer: Pastes the copied artwork in a new vector shape layer. Compound Illustrator shapes retain their attributes and remain editable. Multiple copied paths and clipping masks are pasted as multiple paths that use the unite attribute .
    Note: When you use this option, pasted objects use the foreground color in Photoshop, not the fill color they use in Illustrator. Likewise, transparent objects become opaque.
Export Illustrator files in Photoshop format Exporting Illustrator documents files in Photoshop format gives you the most control over Illustrator artwork in Photoshop. With this method, you can specify resolution and enable anti-aliasing for rasterized artwork. You can also retain the following Illustrator features:
  • Editable text
  • ICC profiles
  • Layers, including nested and hidden layers
  • Masks
  • Transparency
  • Compound shapes
  • Slices and image maps
Note: A compound shape must have either no stroke or a stroke with a round join that uses whole integers for the stroke weight. However, the compound shape can reside on a layer with other objects. In that situation, Photoshop places the other objects on a separate layer in the same layer set.
For more information about exporting Illustrator files in Photoshop format, see "Photoshop export options" in Illustrator Help.
Open Illustrator (AI) files in Photoshop You can open AI files in Photoshop if you save them using the Create PDF Compatible File option.
To save an AI file using the Create PDF Compatible File option:
  1. Choose File > Save As.
  2. Choose Illustrator (*.AI) as the file format, and click Save.
  3. Click Create PDF Compatible File in the Illustrator Options dialog box, and click OK.
Jun 18, 2008 | Adobe Photoshop 7.0 for PC
Copy and paste issue
Why not export the image as a jpeg or tiff and the open it in photoshop, that's what I do, It works fine.
Feb 05, 2008 | Adobe Photoshop 7.0 for PC
Adobe Photoshop 7.0 for PC Logo
Top Adobe Computers & Internet Experts
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
