Guest
Rank: Apprentice
Rating: 0%, 0 votes
First of all, be aware that the MDA can NOT charge unless the OS is fully loaded. If for whatever reason your battery gets fully depleted, you have to do the following (it involves ruining a 5 $ cable and doing some surgery):
- first, go out and buy a new USB-to-mini-USB cable, unless you have 2 already (or one and the original charger)
- take out the battery
- take the USB-to-mini-USB cable, cut off the mini-USB plug and expose the four wires
- strip the red (+) and black (-) wire and twist the copper ends of each wire now CAREFULLY attach the right wire to the right connector on the battery and tape it there so it stays firmly on
- put the cable in your (running) PC or put the charger in the wall socket let the battery recharge for an hour or so, then put it back in the Wizard and reboot
- now when it is fully rebooted, you need the second cable to charge your Wizard completely, the way you're used to.
Worked for me! I've kept the ruined cable, just in case it happens again.
