Question about Gateway FPD2275W LCD Monitor
My monitor is monkeying around
IT STARTS TO SHOW GOOD THEN, IT GOES CONCAVE PICTURE. THEN SOMETIMES, IN THE CENTER OF THE SCREEN,MONITOR ON FULL PICTURE AND SUDDENLY YOU SEE A 3 INCH RED AND BLUE SQUARE SITTING PERFECTLY IN THE CENTER OF THE SCREEN,ALONG WITH THE PICTURE, STILL SHOWING, WITH THE WORDS IN THE SQUARE --- CONTROL LOCK. NOW WHAT IN HEAVENS NAME IS CAUSING THIS? I TRIED EVERYTHING AS A TECH, WHOW WORRIES. ////// HELP HELP HELP.
  • Tomar82403 Dec 29, 2007
    I get a blue screen with a red 1 inch square in the lower right corner. Had this with my old desktop - so I purchased a new desktop (Dell) - same issue. Will the monitor cause a blue screen error? NEC monitor.
  • 106 Answers
The problem is with your Memory IC. Replace it.
Posted on Dec 05, 2007
My crt acer ac512 monitar only centre line view,c"not full view why?
there are several reasons why picture of crt monitors did not display good picture. if your monitor had horizontal line at the center of the screen?...the faulty is in the vertical deflection, check the vertical oscillator also the fusible resistors & capacitors around that section. if there had vertical line at the center of the screen?..check the horizontal deflection, horizontal output transistor also check the YOKE.
Jul 31, 2014 | Acer Computers & Internet
My screen is turning black sometimes halfway sometimes full.. it would be gone if i tap some part of the back of the monitor
The picture board on your monitor is bad, since it turns black atimes, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself. in order not to complicate issues.
Take care.
Apr 21, 2010 | Samsung SyncMaster 793DF 17" CRT Monitor
My 29" LG golden eye T.v is view pictures in concave
Thyere is a fault in the horizontal stage or supply, I suggest Horizontal, if electronically minded check capacitors around the HO stage, could also be a ceramic cap....Phil
May 19, 2009 | RCA TruFlat 27F520T 27" TV
While play a game (red alert 2) the game screen does not fill to the edge of the monitor like it should. There is a black border all the way around.
Hey
its a very simple and easy to solve problem. The display driver is not set to scale the picture to full monitor. instead it shows it on the center you have two options
1. change the resolution in red alert 2 to higher (1024x768)
2. or find from your display properties -> advanced -> scaleing settings. the picture needs to be scaled to full screen instead of shown on the center.
it is somewhere in the settings, I don't know exactly where because it varies from laptop to laptop.
go and try to find it, if you really can't find it we can do a remote support session and I'll fix it for you.
Thanks and good luck.
Ekse
May 03, 2009 | Dell Inspiron 1000 Notebook
The l226wtq goes black
Try shining a flashlight on the screen, or without the flashlight, try to see if you can distinguish anything on the screen at all, if you do, the backlight is dead, or the monitor has an internal most likely unfixable problem.
May 01, 2009 | Computers & Internet
Shows half screen only!
if you can't expand your screen size from the pulldown menu or vertically or horizontally center the picture one or two of the centering coils could be partially burned out. the monitor uses electromagnets around the crt neck to center the picture. varying the center controls apply or take away voltage from the coils to center the image. may be time for a new monitor
Jun 08, 2008 | Compaq MV 540 15" CRT Monitor
Viewsonic E70f,concave picture
Problem related to pincussion correction circuit.Normally dry solder near horizontal output / EHt section.
Feb 15, 2008 | Computers & Internet
Toshiba 46h83 tv projection not full orizontal pic
if you go to the menu on your tv it should show picture you may need to snoop around for it but its there and when you do find it adjust it untill you got a nice picture about the tv not being full on the screen try buying wide sceen movies it should help but the adjustments should help the most
Jul 30, 2007 | Toshiba 46H83 46" Rear Projection...
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
Screen Image is Concave
sony trinitron colour 29ins tv its black and white not colour but the teletext is colour
Sep 01, 2006 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Gateway FPD2275W LCD Monitor Logo
89 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
