Question about Pioneer PureVision PDP-V402 40 in. Plasma Television
Pioneer pdp-v402 40"
I need input and output connectors for TV pioneer pdp-v402
please let me
  • 22 Answers
Posted on Jan 12, 2008
I got a new tv and dvd player and all the wires were pulled out and now i do not know how to reconnect it...
Basically all analog audio inputs and outputs are complementary of each other, such as audio output mates with audio input or viceversa. Video output mates with video input. You typically should have a composite video connector on your both DVD and TV set. Reconnect them directly. As you can imagine, DVD audio and video outputs should go to audio and video inputs of your TV receiver. Good luck.
Mar 15, 2014 | Pioneer VSX-455 Receiver
How do i connect head phones to pioneer pdp 5071pu TV
This model has no headphone out put. In the rear panel there are two monitor audio outputs which could drive headphones, but I think the volume output to a possible monitor matches the tv loudspeaker output, and may not turn off the audio separately.
Mar 09, 2014 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Hdmi inputs
Yes, it has two HDMI inputs on the rear of the TV.
Jul 28, 2013 | Pioneer PDP-5071HD 50 in. Plasma HDTV
Can't seem to get the av and hdmi inputs to work ?n my pioneer pdp 507xd plasma
Make sure the cable is plugged into input 5 if your tv is on input 5. Make sure that you don't need to be on the AV input. I suggest using a hdmi cable also to bring the resolution up to 1080p. Make sure the wire isn't shorted also.
Apr 11, 2013 | Televison & Video
How to replace the mainboard on my pioneer pdp 5080hd? i think its the mainboard. all my HDMI inputs and component inputs wont work but everything else will. anything will help!
Lay the TV on a soft flat surface, then you just have to remove the stand and all the screws on the back, then the board mounting screws and connectors. Best thing to do is to take a lot of pictures so you will know how it goes back together. Mark the connectors with marking pen also.
Also look for any bad caps with domed tops when you are at it as well.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors pictures:
Learn about bad caps:
Capacitors kit: he can make you a set of caps.
Or, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 23, 2011 | Pioneer PDP-5080HD 50 in. Plasma HDTV
Is there an spdif plug on this tv, if so where is it
Sorry - no digital audio input / outputs (spdif, optical, coaxial, etc.) on this TV. Standard analog "RCA" type audio connections only.
AV Input & Output RCA Terminals
S-Video Input Mini Din 4 Pin Terminal
1 Set of Left and Right Stereo RCA Terminals:
Audio Input for D-Sub 15 Pin & DVI Connector
Audio Input for S-Video
Audio Input for YCbCr
Audio Input for YPbPr
I hope this helps. Please rate my reply - thank you.
Feb 23, 2011 | Akai PDP-5016H 50 in. HD-Ready Plasma...
(Pioneer PDP-4340HD Plasma with PDP-R04U Receiver) My HDMI input works, however having a computer or Xbox connected via HDMI I do not have the optical output signal thus I can not hear audio through my...
I don't have a direct solution but I am having the same problem when connecting (1) my Apple TV (2) my Blu-Ray player, etc. via HDMI. I also have a digital camera that puts out HDMI, and when I hook it up, I get the same story -- video only, no sound through the optical digital output of the TV receiver.
I am guessing that the HDMI inputs were an afterthought on this model, especially since the printed manual doesn't even show or mention the HDMI inputs at all! So my guess is that the TV's receiver does not convert the sound from the HDMI to the optical digital output. It does, however, send the amplified HDMI sound to the stereo speaker outputs on the monitor. It appears that only the digital tuner's 5.1 sound comes out on the optical digital output.
This is what I have observed, for what it's worth.
Nov 04, 2010 | Televison & Video
Pc connect to plasma tv pioneer pdp hd5070
Depending on your graphics card you may want to try a digital lead hdmi/dvi.
Also remember you will have to change settings for your graphics card.
If it will do dual view or clone desktop then select it but set your resolution to 800x600 just to start.
If you go too high the tv or computer may not display or say out of range
vga to tc vga has been known to be a bit of a mixed bag in terms of results but for the most part they are good esp if you use a good quality cable and not one of the many cheap ones that are about..
Aug 14, 2009 | Pioneer PDP-5070HD 50 in. Plasma...
Pioneer 503mxe cant wire it up
To connect as you describe you will need a tuner card as the 503MXE is a monitor rather than a receiver. Otherwise the only option is to connect a scart to the 5xBNC connectors (Input 2) but you will need to be sure that your digi box outputs RGB over scart. If you have the optional video card (PDA 5002) fitted then you can connect via the s-video connection (Input 3) assuming your digi box has an s-video output.
Dec 14, 2008 | Pioneer PureVision PDP-503MXE 50 in....
Pioneer PDP-503PU
Very possible,but yet,this might be the manufacturer defect power supply which they will fix it for you free;but before we jump to this conclusion,you need to test it first:
-Unplug the power cords.
-Unplug the media video cable from the box to the tv.
-Check all the pins on the video cable are in place as well as the connectors both behind the TV and the media box.
-Reconnect the media box and TV with the video cable(DVI+VGA in one) and have at least a video component hook up to it(ex. dvd player/VCR or comcast box) be sure this video player is turn on and running,at the same time,be sure it is under the right video input.
If you have tried the above steps but still doesn't work,call 1-800-pioneer Tuesday-Thursday at7amPST and address your issue to them.
Let me know if you have any additional questions!
Oct 07, 2008 | Pioneer PureVision PDP-4340HD 43 in....
Pioneer PureVision PDP-V402 40 in. Plasma Television Logo
352 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
