I have custom build PC of Intel pentium 4 - 2.4ghz prescot edition running on Intel 865GBF motherboard and a 512MB of RAM with 40GB Seagate barrakuda HDD. Its been three years of usage and no problem were found until recently the PC just shuts down just like that and wheni start over again it gives out siren and say it has shutdown previously due to a thermal event. The PC get hanged at times and nothing works not even the num lock lights get turned off. Please help me on this as i love this baby.
Comments:
Dec 04, 2007
- Thnks for the reply to this i really appreciate it. Well i had already tried all those methods, the area is good as new. But still how can the sensors be bad, if it does what can i do about that?
first, try to check the heatsink of the processor if it is full of dust and the air flow from the processor fun cannot penetrate to the processor.
second, double check the brackets that holds the heatsink to the motherboard, bcoz in most cases for socket 478, those bracket will easily get cracked due to aging, the reason the heatsink will not totally hit the processor.
third, remove the thermal pad on the heatsink and replace new one.
if you're done with the above mentioned, and still the same problem exist, may be there is something wrong with the sensor of the motherboard the reason it registered a wrond temp of the processor, but this cases rarely happens, but still it does.
I have installed Win 7 on a separate partition, dual booting with my previous XP. I find that, to...
(More)
I have installed Win 7 on a separate partition, dual booting with my previous XP. I find that, to get any audio output in Win 7, I have to connect my 'line out' jack to the pink 'microphone' socket instead of the green 'line out' socket. When working with XP the connection has to revert to the original green socket. Can you give any advice please. J.A.C.
how do I do a manual reset to factory defaults. I overclocked in bios without thinking.
Soyo...
(More)
Soyo SY-K7VME motherboard.
GA-MA785GM-US2H motherboard wont boot. using PNY DDR2 PC2-6400 RAM. Power supply works fans on just...
(More)
GA-MA785GM-US2H motherboard wont boot. using PNY DDR2 PC2-6400 RAM. Power supply works fans on just wont boot. DOes this RAM work with this MB.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
