Question about Jensen CD3610 CD Player
Jensen JCD-9800 the screen of my CD player doesn't display numbers and other writings in full;although it's plays quite well;it like the screen doesn't receive the required power!any help will be much apreciated.many thanks
4 Suggested Answers
SOURCE: to set the clock on a jensen cd 2010x cd in car player
1. Press DISP for approx. 3 seconds until you see the clock flashing. 2. Use the up and down to change the values and the right and left (<< >>) to change from hours to minutes. Then hit the Disp to exit.
Posted on Sep 18, 2007
  • 148 Answers
SOURCE: Error Code Displayed When CD Inserted
Error 01 is normally on most machines to say it cannot read the discs. Could be dirty laser or a defective one. Must open to make better diagnosis.
Posted on May 12, 2009
  • 54 Answers
SOURCE: Jensen KDC 9520 Car CD player lost speaker conection
sound chip inside is fried
Posted on Sep 25, 2009
  • 944 Answers
SOURCE: Jensen CD3720 CD Player All of
Hi Sonia,
There are many internal fuse that controls the flow of current it is being blown so you have to replace the one accordingly.You should do continuity test to find out the which fuse is blown using ohm-multimeter.Check for any burn sign or for the fuse which is getting to heated.That is the defective one you have to replace the one.It will be of this shape.
In some fuse the internal lining will be broken so you can easily find it out.
The reason why the internal fuse blows out is due to the following reasons.
Make sure power wire is not pinched.
Make sure speaker wires are not pinched.
Install fuse of correct rating and size.
Sometimes The battery and ignition wires are not connected properly. The yellow wire is for the battery and the red wire is for the ignition/ACC.
The volume reaches upto some level and it is not able to supply the required volts because of the defective fuse.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 05, 2010
0 characters
1 Points
Why wont my jensen 9510ts in dash player play dvds but not cds?
Quite often in Jensen units, there is a separate laser for each. Odds are that the CD laser has died. Jensen does not sell replacement parts.
Jul 01, 2011 | Jensen Car Audio Receivers
My jensen wont play cds wen it dose it skips
use a common cd/dvd optic cleaner .... they are cheap .. what is going on is your cd player cant find a track so it shuts off ..
Feb 10, 2010 | Jensen Car Audio Receivers
it is a very common problem with the recoton/namsung companies. which make jensen,dual,qwestar,and etc. the cd player was built cheap and the cd player of course is not the best. inother words you need to replace the cd drive or send it back to jensen if still under warranty
Sep 07, 2009 | Jensen Car Audio Receivers
May 12, 2009 | Jensen MSR4050G CD Player
Jensen 2006 7" indash touch screen: CD player wont work
Try a lens cleaner . If that doesn't work then it would have to be repaired.
May 07, 2009 | Jensen MP7610 CD Player
Jensen cd 615x
order from jensen or go to a local audio store, ie sound creations,
or a store that installs car stereos, I have had pretty good luck with circut city, best buy is a bit cheaper, but then again you get what you pay for.
Mar 05, 2008 | Jensen CD-615X CD Player
Display ok, no audio
poor connection somewhere or heat problem causing cold solder joint as such to lose conductivity. Time to look for it using cold spray. Good luck
Mar 05, 2006 | Jensen MP5620 CD Player
The CD has quit playing and an ER 4 message
I had it too. - when I bought the used vehicle and was elated that it had a Jensen sound system in it. The sound was good - played a CD the first time I put it in. We listened to the radio after an hour and then attempted to replay the same CD. The ER-4 message showed up. The man who sold me the vehicle had given me the paperwork on the unit and I reset it. I've had to do this at least 4 times which means you have to reset all your favorite stations, time, etc.
Nov 29, 2005 | Jensen KDC-9520 CD / Cassette Player
Jensen CD3610 CD Player Logo
Top Jensen Car Audio Receivers Experts
Tygh Duval
Tygh Duval
xxxxxx xxx
Are you a Jensen Car Audio Receiver Expert? Answer questions, earn points and help others
