Question about Gigabyte Slot 1 GA-6VXE+ Motherboard
Motherboard no display
I have connected all the connections still there is no display from the mother board at the bios bootup screen. what can i do? how should i solve the problem? please send the pin configuration . i think it would help for me.
Display ic motherboard
A> Check you Power all connection proper connected.
B> Check you SMPS power proper working or not.
C> If direct display not coming then sec option is external display card connect in mother board and check display come or not. if display come then you internal display cheap damage. If both option used or display no then you mother board problem.
D> Check you RAM, section if RAM problem then display no.
E> And finally one time mother board bios batter disconnect and few sec wait and re-connect bios batter. Remember batter disconnect before all power cut.
Thanks...
Aug 26, 2013 | Dell OptiPlex Computers & Internet
Smps working indivudually but motherboad no disply and when i conect to board in that time smps and cpu fan also not working why
1.) Use alternative SMPS
2.) Use alternative motherboard
3.) Unplug HDD, check if BIOS screen is displayed
4.) Check if your input voltage power to the SMPS is sufficient
Feb 26, 2013 | Intel DG31PR Motherboard
I have homebuilt PC that will not boot. When I press the power button the CPU fan spins up, mother board lights, HD's spin up, etc. However, I do not get any display to the monitors (no BIOS self test,...
Press F2 at bootup to enter BIOS. Reset everything as if it a brand new computer. Sitting idle for sevenmonths any computer could have gone dead. Reset HDD, bootup sequence, keyboard etc etc. everything.
Sep 19, 2009 | Computers & Internet
I have asus p5p800-mx mother board morboard working fine and also start but on monitor no display and i also try to install additional graphics card then also no display
Have you tested the monitor to see if it is working? Is the vga cable good? Are you getting the BIOS start-up display screens when computer is booting up or no display at all? It is odd that both the on board video and video card would be bad I would double check the cable connection and the monitor. If the cable is good and the monitor is working properly than the board might be bad. You should at least get the BIOS start-up screen display.
Sep 07, 2009 | ASUS P5P800-MX Motherboard
D865GVHZ mother board Doesnt boots
If everything was working fine before, and you flashed bios unsuccessfully, then yes, if would be a bios problem.
If you didn't flash the bios you should check the connections on your monitor. If that's okay then check your memory, hard drive and cpu.
Good luck,
Hank
Aug 17, 2009 | Intel D865GVHZ Motherboard
Unable to boot up
The problem is of the display side so if possible connect the pci
display card or can repaire the mother board, If not then only solution is to change the mother board.
Thanks
Sep 08, 2008 | ASUS P5B-E Motherboard
Problem at boot
There is a mechanical switch connector available to determine if someone has opened the chassis.
You can bypass this through the BIOS by entering the BIOS on bootup (DEL? message at bootup? F1?) then look for the system chassis intruder alarm and DISABLE
Another option is to find the pins that the switch is supposed to be connected to (documentation on the ASUS P4B motherboard) and jumper them.
Jul 03, 2008 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Intel D945GTP Motherboard
1)reset your bios with the help of the bios resetting jumper located around front pannel connecter,
2)Reset the mother board battery
3) Open the memory and switch it up. if you do not get a long beep sound this is possiblly a mother board problem
Jun 24, 2008 | Intel Motherboard
No display but cpu fan is working condition
check the connection of your video card, this is the common problem of cpu's specially if you are moving from one place to another. try to uninstall the connector of your monitor to the video card. if you have an extra video card try to replace the existing then power on. loose connection of your video will give you a rapid beep sound. if you are using the on board vga you try to install a video card or try to tighten up the connector.
Oct 24, 2007 | Intel Motherboard
Computers & Internet Logo
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
