Question about Hughes SD-DVR40 210-Hours Video Recorder
Welcome. powering up" screen freezes
Hi - my power went off yesterday, and now when i try to reboot and/or turn on my tivo, i just get either the 'welcome, powering up' screen or the 'almost there...just a few more seconds screen.' I let it power up for 20 hours to no avail. I unplugged it to no avail. Anything else I can try? Note that I have NOT dialed in for years (literally). Thanks!
    Sniper:
  • 59 Answers
Well it sounds like the tivo is trying to re aquire the information needed or it was damaged during the power outage.If you can get into the menu settings make sure that you are getting a satellite signal on both tuners or both cables coming from the satellite.If you have the same tivo thats in the picture then you can go to directv central "the blue button at the top of the remote" then once you get there go to "read new messages and setup,then settings then satellite signal.once you go to the signal testing screen make sure you have a signal on both of the signal meter bars.If you dont one of the cables may have been damged.another way to test to see if the cables are ok is to take another receiver from another room and see if if will work on BOTH the cables that plugged into the tivo.If you discover that one or both cables are not working you can go to a website called satellitescoop.com and there is a section that will explain how to fix the cable/If you are unable to get to the setup screen then something internal may be wrong with the tivo.You will have to call Directv and have the tivo replaced with the new DVR,not tivo anymore.Or you can replace it yourself.Once again the website i mentioned will help ALOT.GOOD LUCK rate me fixya if this helps.OH yeah not dialing out will not cause any problems.Mine is the same way and it will just prompt you to make a phone call.
Posted on Dec 04, 2007
  • 38 Answers
Most likely, it's your hard drive if it's doing the reboot loop. It COULD be the power supply failing, but 99% of the time, it's hard drive related. Replace the hard drive and all should be okay.
Posted on Dec 05, 2007
TIVO is stuck on start up on a sony svr-3000
It sounds like you need a new hard drive. I'd recommend you visit this TiVo repair website.
Sep 04, 2009 | Sony SVR-3000 TiVo
How to unfreeze mp3 player
I would recommend you to upgrade your device firmware.
This will fix the issue.
Jul 04, 2008 | SanDisk Sansa e250 MP3 Player
Tivo gets stuck, freezes and powers up reapeatedly
Hi!
maybe the HD box is not compatible to your TV! or you need the setting right! may i know the model of the TV and the HD box?
Nov 01, 2007 | Televison & Video
Powering up
Leave the box unplugged from the wall for an hour then try to power up again.
If it doesn't please post back.
Good luck
Jun 01, 2009 | Toshiba SD-H400
Humax Tivo Stuck on the welcome screen
I just had the same problem with mine and found another post that at least fixed mine.
I had a DVD in the unit as it was restarting. I took a flathead screwdriver and opened up the DVD slot by inserting at the top right corner and opening the door. On the inside, at the bottom right, is a button that ejects the DVD player (the eject button on the outside won't work while it's booting up). I ejected the DVD that was in it, unplugged the unit for 30 seconds, and then it rebooted just fine.
Hope it works out for you too...
Jan 02, 2009 | Humax DRT800 TiVo 80-Hours Video Recorder
"Welcome. Powering-up " on screen and cannot turn it off manually or remotely
If you have a TiVo that is stuck on powering up, you likely have a bad hard drive. See this page for more information about a TiVo that is stuck on powering up.
Oct 05, 2008 | Sony SVR-3000 TiVo
Continuous reboot problem
Most likely, if your unit is not powering up to the TiVo Central screen, you have a hard drive problem. You might consider a replacement TiVo hard drive.
Jul 30, 2008 | Sony SVR-3000 TiVo
Video failure...
Check the interlace/progressive switch on the back.
Sep 21, 2007 | Toshiba SD-H400
The Screen shows "welcome. Powering up....." and is stuck
Direct TV has been working on numerous software issues. Some patches have been downloaded for TiVo that in some cases have caused problems. In your case, it is more possibly an indication that the hard drive is not running and you have a possible hardware failure. When you rebooted and became stuck on the "welcome, powering up screen", it could be an indication of a software glitch or a hard drive failure. I would go with a hard drive failure. Since this is a Hughes Receiver like mine and you own it, you could try a drive swap with another TiVo drive out of a like receiver. If one is not available, you may have to purchase one. Pre-configured and initialized drives are available from www.weaknees.com. I have no interest in them, but that is where I buy Tivo pre-configured Hard Drives from. You can get replacement or upgrade Maxtor Drives preconfigured from them for this specific brand and model of TiVo DVR. A drive swap would be cheaper troubleshooting. There is also a possibility of a problem with the built-in IDE controller or the power supply on your receiver which can't be determined until you do swap out with a Known Good Drive to eliminate a hard drive problem. If you are able to swap it out and If the good drive works, then your old one has corrupted data and would need to be re-initialiaed and reloaded. If it is an older smaller (35 hour) drive, you would be better off with a new replacment since the loading is a somewhat lengthy process and must be done on a computer running the Linux Operating System.
Nov 09, 2006 | Hughes HDVR2 with 105 Hrs DirecTV DTV...
Hughes SD-DVR40 210-Hours Video Recorder Logo
987 people viewed this question
Top Hughes Televison & Video Experts
jason
Jim London
Jim London
Edward Talavera
Edward Talavera
Are you a Hughes Televison and Video Expert? Answer questions, earn points and help others
