Question about Toshiba 32AF43 32" TV
Problem with my Toshiba 32
Help...My 13-year old Toshiba 32" TV with model number CF32D40 acted up.
When I turned on the TV, every thing would be fine for a few minutes; then the pictures would turn red. Sometimes, it would take up to 30 minutes of "warming up" before the colors would turn normal again.
Somebody suggested that some soldering might be loose. But I opened the back and could not find anything loose.
Can somebody help me please. Thanks.
bcl
    Genius:
  • 1,694 Answers
Sorry, probable bad CRT.....check voltages on CRT board
connected and dis-connected.............Let me know.....T.
Posted on Dec 11, 2007
Toshiba TV model 50HPX95 does't Boot and the screen only shows the message Booting... . Anybody knows if it is worth paying to fix it?
worth , is personal thing, but boils down to.
what is the cost in shop to fix it, (not cheap)
against a new TV or used,
only you can can answer any question of economics.
you posted TV to computers, and TVs are not. that.
this TV is 13 years old today,
does the TV part work, at all , even on antenna?
That TV has lots of features, do any work at all?
the home screen is dead, (booting is the clue)
so sounds like to me power supply issue inside, making the brain inside dead or its memory banks.
my guess is used, dead, 13 year old TV is only worth $100
for parts.
and tad more working,
I'd upgrade,
Oct 08, 2018 | Toshiba REGZA 47HL167 TV
I have a 2 year old Toshiba 32
Your panel is defective.Not worth repair.Try calling Toshiba customer support and see if they will help you.
Sep 28, 2009 | Toshiba Televison & Video
My tenplus year old Toshiba 32" TV is stuck in standby mode
You have an old tv so the best problems are bad capacitors and bad grounds. Have someone pull the board and search for high voltage caps [160volts or 250 volts] with 1 to 4.7 microfarads. Should be two or maybe three and check all grounds. If the 4 amp fuse is good than the above will save your TV.
Sep 24, 2009 | Toshiba 32A33 32" TV
We have a Toshiba HDTV model number 57H82. It is
Sounds like a bad tuner/decoder on the Qam analog side of things. You can bypass this with a Clear qam converter box or a analog to digital tuner box or simply having this repaired upwards of $200 bucks.
Thanks for using Fixya.com
You're Toshiba Tv Expert.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Aug 31, 2009 | Toshiba 57H82 57" Rear Projection...
Toshiba 32" Model# 32A33 TV About 5 years old
change tact switches
you have windex syndrom
using too much windex cleaning tube
Aug 26, 2009 | Toshiba 32A33 32" TV
Philips 27 inch TV - Model # 27PT543S37A - Keeps going off!
if you have back ground of tv repair, remove back cover but you need tools and tester, check heater line from crt ckt board going to horizontal section.
Apr 03, 2009 | Philips Magnavox TP3285C 32" TV
Panasonic 36 inch flat screen tv 6 years old (model unknown) just stopped turning on. Act as if it is unplugged. Could it just be the fuse? If so, where is it located and how do i replace?
Fuse sounds right.  Had a Toshiba 32" that did the same thing.  Had to have a repair man come out.  $150 charge all told.  Worth it, because a new TV would be a lot more.  Unless you are some kind of electronics wizard, you don't want to take that thing apart.  They are very delicate-looking inside (and really cheap-looking, actually!).
Nov 15, 2008 | Panasonic Televison & Video
Toshiba CF32D40 Power button stuck-will not come on.
Did it out with a screw driver if you don't mind breaking the power button that most folks don't use thanks to remote. See if that works.
Oct 20, 2008 | Toshiba 32AF43 32" TV
Toshiba 32 inch 8year old tv set
Probably a bad connection on the tube base but your CF32H50 model dates from 1998!
Jan 28, 2018 | Toshiba CF32G40 32" TV
TOSHIBA 32' T.V.
How old is this TV?
My experiance is to not put money into a TV that is over ten years old. TVs stress out their electronic components worse than almost any other electronic product. After 10 years, there are so many parts that are ready to fail that your are probably wasting your money trying to get any more life out of it.
Another option is to wholesale replace the main board from an outfit like Module Exchange at 972-298-1212
Be careful on buying a new one though. Often times, these new technology ones are much worse. Always Google the model number of the set you intend to buy and add the word 'repair' or 'complaint' to see if it is one of the many models that are customer service nightmares being produced by even the most reputable companies today.
Jan 02, 2008 | Toshiba 32AF43 32" TV
Toshiba 32AF43 32" TV Logo
106 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
