QPS Que! Fire CD-RW Burner
Problem for QPS Que! Fire CD-RW Burner
My computer does not recognize it.
By bjbrannan on Aug 24, 2009
my computer does not recognize it.
It used to work, but now it won't do anything when I put a cd or dvd in it. It also has the light scribe feature.
It only came with Nero cd, no intstallation cd.
Comments:
Aug 24, 2009
- It came with no installation cds. I bought it because my internal cd drive died. Like I said, it used to work, but now won't recognize it. Where do I get drivers to install? I have already been ripped off by buy Driver Detective and it didn't do anything for me.
Solution #1
posted on Aug 24, 2009
Not Helpful)
bob_computer
Rank: Guru  Computer Accessories  Expert
Rating: 87%, 1207 votes
I devised these simple steps that tend to remedy quite a few common USB problems.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability.
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again.
If you suspect a cable NEVER get one longer than the one you want to replace
If you checked and fixed anything there and still have issues it may well be due to the device itself or a weakened usb port, a loose usb port.
To remedy the last two consider a new usb card if it for a PC
Comments:
Aug 24, 2009
- http://list.driverguide.com/list/company1665/device3/index.html
select the ones you need and then use the FREE download after viewing advert option
You may want to get them all to make sure you have what you need.
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for QPS Que! Fire CD-RW Burner
Questions and Unsolved Problems for QPS Que! Fire CD-RW Burner
Do you recommend QPS Que! Fire CD-RW Burner?
Answer
Answer
I have an old QPS Que! Fire CD-RW Burner. How do I open the case to upgrade the drive to a DVD-R,RW... (More)
Answer
No Vista driver for model DH-3H20A . Wgere can I download the driver?
Answer
my computer is a dell 545 running on vista. the media player worked ok at first but does not play... (More)
Answer
I have a problem I was able to play and burn cd yesterday but now its saying connect aburner what... (More)
Answer
I use to be able to burn pictures on CD-re writable but I cant find it now in my computer. Why
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For QPS Que! Fire CD-RW Burner:
Top CD and DVD Burner Experts
Rank: Guru Guru
Solutions: 14880
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more CD and DVD Burner Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
