Question about Maytag MFI2568AE Side by Side French Door Refrigerator
Water not working at all
Had refrig for several months, finally got a water line hooked up and the water doesn't work.
Don't have a manual.
Can anyone help out?
I did notice that there is no filter,
do you need a filter to make this work?
  • 410 Answers
Yes you need a filter for the water system to work. ther is a check valve built into the filter housing..
Posted on Dec 12, 2007
Water dispenser does not dispense water
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door or using a can of computer cleaner ( with nozzle ) has worked ,also , turning on the dispenser light for a while also will thaw . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
If the line is frozen in the door , GE has a heater , pt.# WR49X10173 , to keep this from happening again . Also , turning on the dispensor light for several hours , has been known to thaw the frozen area
Oct 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser does not work
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Jul 31, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser not working,
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , turn on the dispensor light for several hours so the heat will thaw the " hook " , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
May 15, 2010 | GE GSS20IEP Side by Side Refrigerator
May 02, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser will not work Just tried to get water from the dispenser.I heard a clicking when I pushed the lever in with a glass,but no water.I loosened the water line at the compression fitting at...
The ice works off of a different solenoid than the water dispensor . So , I would suggest this action : At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Jan 28, 2010 | Hotpoint Refrigerators
Our water dispenser stopped working we can hear it click but water will not come out?
At the bottom of the freezer door ( remove the kick plate by removing 1 screw on each side ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
If frozen , GE has a water dispensor heater , pt # WR49X10173 , to keep this from happening again . Also , by turning the dispensor light on , for several hours , so it will heat the spout , has worked for several people .
Dec 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water in door not working. I haven't changed the filter in a long time...
Is the ice maker working ? If so , the filter is not the problem . At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Nov 13, 2009 | GE Refrigerators
Model gsl251grb water dispenser stopped working. r&r filter no help. turned temp down in case froze, no help. can hear motor run. ice maker works. help
Nov 13, 2009 | GE GSL25IFR Side by Side Refrigerator
GE REFRIG MODEL GSL25KGRB BS 4 YRS OLD. PROBLEM: WATER IS NOT DISPENSED BUT THE ICEMAKER IS WORKING. CHECKED ALL THE WATER LINES. LIGHT WORKING ON THE CONTROL PANEL. GETTING WATER TO THE QUICK CONNECT...
Found another post that says the water line is froze in the freezer door. They said to turn the night light on for 24 hours and see if that helps. I'll give it a try.
Dec 03, 2008 | Refrigerators
NEW MAYTAG MSD2652KGW 26 CU FT SIDE BY SIDE
disconect water line and make sure you have water pressure.
Mar 30, 2008 | Maytage MSD2652KE 26 cu. ft. Side-By-Side...
Maytag MFI2568AE Side by Side French Door Refrigerator Logo
57 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
