Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Malfunction Detected Error c-0211
I got this error(c-0211) on bizhub c250. Can anyone tell me what this means? Is there a way to reset the machine?
Thanks
  • 1 more comment
  • paperplus Dec 07, 2007
    I have not tried this solution but it seems to me that it should work since it resets the trouble messages.
  • Anonymous Mar 15, 2014
    can anyone tell me what this means?
  • Omoigui Patrick
    Omoigui Patrick Jun 24, 2017
    i try clearing error code c-0211 on bizhub 250, but still is still occure whenever i want to print through bypass
  • 146 Answers
C0211 Manual Tray Rise Descent Error
• The Bypass Lift-Up Sensor is not blocked even when the Tray 2 Vertical Transport Motor has turned for a given number of pulses after the sequence to move the Paper Lifting Plate from the standby position to the feed position was started.
• The Bypass Lift-Up Sensor is not unblocked even when the Tray 2 Vertical Transport Motor has turned for a given number of pulses after the sequence to move the Paper Lifting Plate from the feed position to the standby position was started.
This is a rank B error. To reset follow these steps:
Open and close the front door.
If error recurrs check the manual bypass again or call for service.
Posted on Jan 04, 2008
    New Friend:
Do you know how to do error code c-0211 ?
Posted on Jan 18, 2014
Thank you for your reply. :)
Posted on Dec 07, 2007
C0211: Manual Tray Rise Descent Error
reboot machine, when rebooting hold on utility key, then it takes you to trouble reset. then reboot again, maybe it helps, if not, then you have to call some technical person
Posted on Dec 05, 2007
Konica Minoltra Bizhub C250 Malfunction detected C-2451 This message I got after I changed fuse on transfer unit. How to solve it, or at least what this error code means?
hi, from the service manual:
C2451:
Item:
Transfer Cleaner Unit New
Article Release
Description:
A new installation is not detected when a new
Transfer Cleaner Unit (Image Transfer Belt Unit) is
installed.
for the solution, SM says you should try refitting Transfer Cleaner Unit(misplacing could occur) or change the PWB-M board.
Feb 09, 2010 | Konica Minolta bizhub C250 All-In-One...
Hi there!!! My printer displays error message: malfunction detected call representative - c3751. Kind regards
hi this is a high temp code, you need to replace the fixing unit then get a service tech to reset the machine
si
Jun 05, 2009 | Konica Minolta bizhub C250 All-In-One...
Error Message C-2253
C2253: Color PC Drum Motor’s failure to turn
try to turn these IU's manually, and reset the error, sometimes helps, because usually motors works fine. also you may try to change IUs
Oct 29, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta Error code C-D351 on a Bizhub C250
Hi
I have come across this kind of problem.
Is your BizHub on the network? If yes, please switch it off completely, and take the Ethernet cable out of the BizHub.
Wait for atleast 30 seconds and reconnect the cable. Now start the printer again and see if the error message goes away.
Hope this helps!
May 12, 2008 | Konica Minolta bizhub C250 All-In-One...
are you sure that you have a correct model and malfunction ccode ??? i cant find this code on bizhub C250
May 01, 2008 | Konica Minolta bizhub C250 All-In-One...
Copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
Feb 10, 2008 | Konica Minolta bizhub C250 All-In-One...
i think that your fax is not set up right, or maybe the machine is missing admin and machine e-mail address, that can cause too this problem.
Dec 12, 2007 | Konica Minolta bizhub C250 All-In-One...
Error message C4551 anyone? pretty please.
C3451: Heat. Heater Trouble
You have to check machine fuser unit .
May be paper on the fuser unit. Check fuser unit rollers.
After check fuser unit you have to ececute a "trouble reset".
Turn on your machine by press and hold "utility counter" botton, after some seconds press to display "TROUBLE RESET" and turn off and on machine.
C4551: Cyan laser Malfunction
Check cyan laser connection and execute trouble reset.
Bye.
Oct 03, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
7,471 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
