sounds like the battery memory (lithium) is nearly out and wont read. you may need to purchase a new battery, or try draining out the current battery to where it shuts itself off, then charge it, but dont use the computer while it is charging. Using the computer while charging doesnt give the battery full charge for it's being drained at the same time your charging it causing the memory for power storage to be less.
Try starting the laptop with no battery inside and only the power adapter connected. If it does not start , then you have a faulty dc adapter, or the socket on motherboard has a broken soder joint.
If the laptop starts with DC adapter, then usually you have a faulty battery. There are a couple of other faults on battery charger circuit, but they are quite uncommon.
Dash light don't read and have werid symbols. Also when over 100 degrees out shifts are like it is...
(More)
Dash light don't read and have werid symbols. Also when over 100 degrees out shifts are like it is running out of gas or transmisson is slipping
hai i have a problem with my hp530 notebook.it no longer reads dvds but is able to read cds and cd...
(More)
hai i have a problem with my hp530 notebook.it no longer reads dvds but is able to read cds and cd roms.help!!!
I am trying to burn to a dual layer disc using my HP 530i drive, I have tried several different...
(More)
I am trying to burn to a dual layer disc using my HP 530i drive, I have tried several different programs, such as 1ClickDVDCopy, Sonic, and so on...it keeps freezing up! The discs are Memorex, does anyone know what's going on?
hi i have a hp 530 laptop, the dvd drive does not work all the time. the problem is intermittent. i...
(More)
HI I HAVE A HP 530 LAPTOP, THE DVD DRIVE DOES NOT WORK ALL THE TIME. THE PROBLEM IS INTERMITTENT. I AM USING WINDOWS VISTA, PLEASE HELP annathan@webmail.co.za. thanks
