Question about Samsung (DSSMBK482448) CD-RW Burner
Cd rom tray open problem
In my PC samsung cd-rw drive it work properly but then i push the eject button cd tray does not open few days.please tell me the solution step by step
    Sergeant:
    Champion:
  • 270 Answers
Normal problem for samsung cd drives . clean the rails of drives that which tray is commin out . it mainly caused due to the change ina laaingnment of drive tray
Posted on Dec 04, 2007
Cd-rom player does not open
There are two ways to open the CD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD disc.
If you still having problem opening with the Eject button, then the CD drive is faulty and needs replacing.
Dec 24, 2012 | Acer Aspire 9500 Notebook
Re: Samsung CD-Rom SC-148C in Dell Dimension 2350 Cannot eject/open tray to CD-Rom - I have tried ejecting tray while re-booting from setup to see if its a software problem of some kind. I've...
  1. Turn off the power to the computer.
  2. Insert a steel rod (about 1.3 mm in diameter) into the emergency eject hole and push hard. (A stiff paper clip may be used).
  3. The disc tray is ejected a short distance. Pull it all the way open by hand. roadfox_2.jpg
Jun 01, 2011 | Samsung SC-148 CD-ROM Drive
The CD rom does not open?
Take a paper clip now straighten it push it in the tiny hole on the front of the CD ROM drive
the drive should open
Apr 12, 2011 | LG (GCC4243N) CD-RW/DVD-ROM (Combo) Burner
My cd rom tray will not eject and the light is
have you manually tried to eject the disc tray? There's a little hole on there somewhere, stick an unbent paperclip or safety pin in it and push until the tray starts to come out, then pull the tray out with your fingers.
Once you've done that, push the button to allow the tray to automatically retract.
Jul 22, 2010 | Teac DW 28E CD-RW/DVD-ROM Burner
Can't open the second cd rom drawer
Does the light flash when you press the button? If so, was there a disk in the drive previously? There is a small hole on the front of the unit. With power off, get a paper clip and open it up halfway. Push the open end into this hole and the drawer should pop open by about half an inch. This will be enough for you to gently pull the drive open and remove anything stuck inside. Ian.
Sep 27, 2009 | E-Machines T3256 PC Desktop
My computer will not eject?
there is a tiny hole in the from of your CD player, take a paper clip and push it into the hole and the cd tray will eject.
the disk may be off track not allowing it to open.
you can also go to My Computer and right click on the drive and eject
Jun 08, 2009 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Eject Problem..
1. right click on the drive. 2. press 'Eject' option. this will intern send the software interrupt to the drive to open it, if your cd-drive 'button' is not working. thanks.
Failure opening the tray
do 1 thing,take a pin and insert it in the small hole below the tray
and then press the eject button
Jun 04, 2008 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
CD Drive not Ejecting properly
Hi, Since the warranty period has expired I will assume that the CD/RW has been in use for some time. Normally a small belt powered by a motor drives a gear that slides the tray out. Sometimes this belt is loose, warped or plain cut. Replacing the belt should solve the problem. You have to open the CD and it is near the front just below the tray. In other instances, the grease on the toothed railing at the sides and/or underneath the tray gets gummed up, cleaning and repacking with new light grease should take care of that. Rarely (but still does happen), the motor itself burns up and replacement (if you can get the part) is in order. An interim fix is to push a small straightened metal paperclip at a small hole below the tray cover/lip and slightly push till the tray partially opens. You can then manually pull it out. Hope this be of some help/idea to you. Good luck and kind regards.
Aug 27, 2007 | Samsung (SH-W08AENB) DVD±RW Burner
CD-RW Problem
There some few tips you can try. Power down the computer then open the cd tray by inserting a sharp object in the small hole near the tray. Look for this hole, then using the sharp object push it pretty hard. With the other hand try to pull the tray out. Once you've pulled it power on the computer (with the cd-rw's tray opened) and watch what the cd-rw is actually doing now. If after it retracts the tray it is doing the same, you will need to dissasemble it. If you are willing to try this, please post another message and also specify there what did the cd-rw drive do when you've applied the method i've told you before.
Mar 11, 2007 | Lite On (LTR-52327S/5238S)...
Samsung (DSSMBK482448) CD-RW Burner Logo
159 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
