looking for wilton scroll saw manual, for wilton model 99166 part # 3016-3045 havn't been able to...
(More)
looking for wilton scroll saw manual, for wilton model 99166 part # 3016-3045 havn't been able to find anywhere
I cut through too deep a piece of wood and the result is the head which holds the blade is now bent...
(More)
I cut through too deep a piece of wood and the result is the head which holds the blade is now bent with the result the blade sits at an angle. Can this be fixed?
Ryobi EJS500QEO Jigsaw: The blade release mechanism has an inherent design problem. The yellow...
(More)
Ryobi EJS500QEO Jigsaw: The blade release mechanism has an inherent design problem. The yellow plastic trigger often springs apart and causes the disintegration of the entire mechanism.Any remedies? I have considered drilling a 2mm hole through the trigger and fitting a 2mm set screw and nut. Ideally it should be a metal trigger
