Not spin not agitate
My washer doesn't agitate nor spin
  • 6 more comments
  • Anonymous Jan 23, 2008
    Washer was mid wash cycle, odd noise ,no agitate, no spin. Sounds kind of like a stripped gear not engaging.
  • Anonymous Feb 22, 2008
    i just moved and set up my washer and dryer .now the washing machine wont agitate or spin.whats the problem?
  • Anonymous Apr 16, 2008
    Washer, does't spin,or agitate,belt;motor works great,is there a couppling{lov-joy w/a spider} type or bushing? Is there a break-down parts manual that I can download? I have a Admiral Mod#AAV3000AWW.
  • Anonymous Jun 24, 2008
    not spinning
  • Anonymous Aug 12, 2008
    The motor turns and the belt get hot and shuts off...maybe an idler pulley not working? The washer is less than 2 Y/O and I don't agree with the motor bushings...HELP!!!
  • loulo Sep 27, 2008
    washer fills with water does not aggitate or spin. Makes a funny noise- like something is stuck
  • Anonymous Feb 28, 2009
    washer does everything but agitate
  • Anonymous Mar 06, 2009
    I have an Estate ETW4300SQO it fills up but nothing else!!!
  • 139 Answers
Carbon brushes on the motor need replacing these wear out over time and are very common in my trade
Posted on Dec 04, 2007
MNTECH
  • 1543 Answers
SOURCE: washer doesn,t spin
Looks like chat support session must have timed out. The answer to your last question was, yes, pres. analog switch with a red, a white, and a blue wire to it.
Posted on Oct 27, 2008
jnchahn
  • 252 Answers
SOURCE: I have a Maytag Model
It is your timer. Try manually move the timer forward after it fills.
Posted on May 07, 2011
  • 6277 Answers
SOURCE: Spin cycle or agitate doesn't always engage. I
There is likely to be a problem with either the lid solenoid/lock or the 'lid closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Jun 28, 2011
oldTech2332
  • 2341 Answers
SOURCE: I have a HotPoint washer
Do you here the motor running on the agitation cycle yet it doesn't agitate? If so the agitator coupling is the problem.I have included a youtube video that will show you step by step how to repacle the coupling.The part number in the title of the video(WH49X10042) is the part number that you would need(Hotpoint is made by GE) it could be ordered by simply googling that part number
here is the lik for that video http://youtu.be/N26MCQKuXn0
I hope this helps and if it does please give me 4 thumbs up
Gene
Posted on Jul 28, 2011
  • 31 Answers
SOURCE: Model #: WPRE6150KWT GE Washer fills,
check lid saftey switch
Posted on Aug 25, 2011
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
The washer doesn't spin
Possible that the belt is slipping due to overload, check the capacitor to the motor , check the belt to the motor, check if the spindle is jammed , if so reset the spindle.
Jan 18, 2013 | GE WBSE3120B Top Load Washer
Whirlpool lsq8243h
If it doesn't agitate but will spin it is probably the agitator cams.
http://www.repairclinic.com/PartDetail/Agitator-Repair-Kit/285809/470910
If it doesn't spin it is probably the motor drive coupling
Here is a link to the part and a video on how to replace it.
I would suggest watchine the Video before you order the part then you can check if this is the problem.
http://www.repairclinic.com/PartDetail/Motor-Coupling/285753A/1195967
Oct 07, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag washer doesn't agitate
Google the model number. I had the same problem, Googled it, and found the actual turial on YouTube to fix it.
Dec 11, 2011 | Maytag MAV6200 Top Load Washer
My washer fills, agitates but will not drain
Does your washer spin? If yes, and it doesn't drain it most likely a failed/plugged pump.
If it doesn't spin it could be a belt or timer issue..
Sep 15, 2011 | Maytag MAV2755AWW Dependable Clean Top...
My 110 20862990 kenmore washer doesn't spin, the motor runs, it drains, and the coupling is in good shape. On another DIY page it asked to turn the drive side of the coupling one way to see if the...
My washer was doing the same thing. I had a magic marker on the bottom of the plastic tub below the inner tub. The agitation cam could not release for spin. I remove the magic marker and she took off.
This video shows how to get the inner tub out:
More here
More here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 09, 2011 | Kenmore 24032\24036 Top Load Washer
Washer won't agitate or spin
Hello there and welcome to fixya
there are several things that you will need to check first ok please verrify the following
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Sep 07, 2011 | GE Profile WPRE6100G Top Load Washer
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
Washing Machines Logo
654 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
