Garden Logo
Anonymous Posted on Aug 24, 2009
Need Gas Line installation instructions for a McCulloch Lawn Trimmer I bought New Neoprene tubing (Gas line) for My McCulloch trimmer model B400128-11. The old lines hardened over the years, and broke off where they went into the tank. I need the directions as to which lines go to where, or an instruction manual that shows where they go. there are 5 locations where the line should go. One end To the primer, From end from the primer, one end to the Tank, and another one that goes to the tank, and one end to the Carburetor. What goes Where??? Thanks for any help on this matter. A Copy of the original Manual might help. Chuck.
Anonymous
Level 2:
  • Expert 155 Answers
  • Posted on Sep 10, 2009
Anonymous
Expert
Level 2:
Answers
155
Questions
0
Helped
91422
Points
316
Hi Start from the filter in the tank to the bottom of the carby then from the top of the carby to the short primer pipe then from the long pipe on the primer back to the tank. Hope this helps.
How do i disassemble a craftsman string trimmer head to expose the trimmer shaft?
you dont,y7ou need to get the adapter that came with the universal head,if you try to take more than the head off,you will damage it
1helpful
The line that I'm looking for came as stock supplied when I bought the trimmer.I can't believe that Bolens doesn't have a scource for replacement line. Help. Gene
Genuine MTD 791 181460B Reel Line Assy McCulloch Ryobi Troy Bilt Bolens OEM
Reel and Line Assembly
Bolens String Trimmer Spool 791 153577B
the spools come with line already installed,they are all for bolens,line is generic,you buy your own line,there are 2 different sizes,and a bunch of types,like round or star,you buy generic line because bolens wont make any money if they sold "BOLENS" line.
Jul 11, 2015 • Garden
How do you replace the trimmer head on the Craftsman 27cc trimmer (Model 711170)?
U-tube has some good videos on all sorts of replacements on heads , lines...etc.
Fuel line diagram for mcculloch 2816 weed eater
You can find that in your service manual, typically in a new fuel line kit, or possibly in a Youtube video.
I recommend contacting your local service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Where can i buy new gas line(Oregon)? For Sears edger.
its only silicone tube have a look in some model shops for fule line or pet shops that sell "fish!" the tube used in fish tanks to pump air or water through the filters will also work for fule pipe,,so long as its silicone tube it will work fine,, trust me on this i use it all the time
1helpful
Can not start it
1 check to see if the inline gas shut off valve is lined up with either the open position or the gas line (depending on which is used)
Also there could be a nut (actually a bolt head) where the gas line enters the carb. If your model has that type of fuel inlet to the carb take off that bolt and carefully slide it out of the manifold. There is a tiny plastic screen inside that you need to check for buildup of particulate.
So in short verify the gas on position and check the fuel filter.
If your not sure if the gas is on or off then you can gain access to the carb fuel line disconnect it and see if the gas flows freely to the carb itself.
1helpful
How do I use the B & D edger and trimmer
This is for a MCCULLOCH TRIMMAC 210, 21CC (petrol/gas Line Trimmer).
http://safemanuals.com/user-guide-instructions-owner-manual/MCCULLOCH/TRIMMAC%20210-%2021CC-_E
Operation of this and other Line Trimmers are all the same with some exceptions with optional attachments.
3helpful
Need to replace gas line inside mcculloch chain
You need to disassemble the case to get to the fuel tank. Pull out the plug fitting and replace the internals with new factory grade parts.
Jun 30, 2009 • Garden
Top Garden Experts
Jay Finke
Jay Finke
john h
